Important : à l'intention des désireux de poursuivre en thèse
Affichage des résultats 1 à 30 sur 55
Vue hybride
    invite17a570c1
    Depuis un petit moment, les discussions ayant pour sujet la question existentielle "Thèse ou pas thèse?" sont fréquentes
    Voici un petit Guide (de survie ) paru dans Nature Jobs lequel résume très bien les choses. Bonne lecture
    Doing a PhD should be fun and rewarding, because you can spend all your working time discovering things and pursuing ideas — and getting paid for it, without any administrative responsibilities. Those who stick with a career in science do so because, despite the relatively poor pay, long hours and lack of security, it is all we want to do.
    Unfortunately most new PhD students are ill-prepared, and as a consequence very few will fulfil their aspirations to be independent scientists. The main reasons for this are the 'grade creep' inherent at most universities, making it difficult to identify the really talented first-class graduates from the rest, and the pressure on universities to graduate as many PhD students as possible. The consequence is that we enrol far too many of them without telling them clearly what doing a doctorate should entail. We therefore set ourselves, and the students, on a path of frustration and disappointment.
    So what should we be telling prospective PhD students?
    * Choose a supervisor whose work you admire and who is well supported by grants and departmental infrastructure.
    * Take responsibility for your project.
    * Work hard — long days all week and part of most weekends. If research is your passion this should be easy, and if it isn't, you are probably in the wrong field. Note who goes home with a full briefcase to work on at the end of the day. This is a cause of success, not a consequence.
    * Take some weekends off, and decent holidays, so you don't burn out.
    * Read the literature in your immediate area, both current and past, and around it. You can't possibly make an original contribution to the literature unless you know what is already there.
    * Plan your days and weeks carefully to dovetail experiments so that you have a minimum amount of downtime.
    * Keep a good lab book and write it up every day.
    * Be creative. Think about what you are doing and why, and look for better ways to go. Don't see your PhD as just a road map laid out by your supervisor.
    * Develop good writing skills: they will make your scientific career immeasurably easier.
    * To be successful you must be at least four of the following: smart, motivated, creative, hard-working, skilful and lucky. You can't depend on luck, so you had better focus on the others!
    Ca vient d'ici.
    invite3998e665
    Re : Important : à l'intention des désireux de poursuivre en thèse
    MaliciaR, ton lien n'est pas correct
    Pourrais-tu le remettre en bonne forme, s'il te plaît?
    Merci.
    invite17a570c1
    Pardon, j'avais oublié de le mettre tout à l'heure et ai fait trop vite
    Je pense que c'est mieux ainsi :
    http://www.nature.com/naturejobs/200...#related-links
    invite03272457
    Intéressant, mais est-ce que ca ne concerne pas plus les futurs-PhD aux Etats-Unis ? Je ne sais pas si les problèmes des thésards sont les mêmes partout dans le monde, ou si la situation en France est particulière
    invite17a570c1
    Citation Envoyé par quentinlb1 Voir le message
    Pourquoi ça ne devrait concerner que les thésards aux USA?
    invite03272457
    Citation Envoyé par MaliciaR Voir le message
    C'était juste une question, j'imagine que Nature Jobs est un site américain donc j'ai pensé que cela s'adressait aux thésards qui travaillaient dans le système américain; mais c'est vrai que ces conseils sont plutôt du genre "universels".
    invite17a570c1
    Je ne fais que remonter le sujet, histoire qu'il ne tombe pas trop vite aux oubliettes
    invite9c9b9968
    Cette discussion mériterait d'être étiquettée "Important", un petit appel à la gentillesse de nos modos ?
    inviteafe1cd13
    Ceci étant, c'est un article de Nature, donc écrit par des gens qui ont tout intérêt à avoir des thésards motivés ; j'ai bien aimé le message subliminal "bossez, bossez encore, ramenez des trucs à bosser chez vous sinon vous ne réussirez pas"
    Un point important qu'ils ne poussent pas assez, bien qu'ils le mettent en premier point (ce dont je les félicite) : l'importance du flair tactique/politique. Trouver un encadrant de thèse qui apporte plein de sous, c'est souvent se trouver un encadrant qui saura jouer de ses contacts pour recaser le doctorant par derrière. C'est beaucoup trop souvent sous-estimé par les thésards, qui pensent que le talent et le travail jouent le rôle le plus important (ce qui est faux).
    invitec9f0f895
    Citation Envoyé par bratisla Voir le message
    C'est exactement pour cela que je disais que c'etait caricatural. Il y a des choses vrais, maintenant je n'ai jamais cru qu'une these réussi passait inévitablement par une vie de monastere pendant 3/4ans! Certes il faut travailler, mais bon l'image du chercheur qui passe sa vie au labo et qui est une personne n'a aucune vie sociale est quand meme d'un autre age.
    YOyo
    inviteafe1cd13
    Citation Envoyé par Yoyo Voir le message
    YOyo
    (HS : pourtant certains moines apportèrent aux sciences des contributions inestimables )
    Un autre point que j'applaudis dans l'article : souligner la nécessité d'un cahier de laboratoire. Ca paraît idiot, mais le nombre de thésards qui foncent bille en tête, sans écrire ce qu'ils font, et qui se retrouvent à refaire trois fois la même chose ... Je le sais, j'ai longtemps fait cette erreur
    invite0aa1883c
    J'y crois pas du tout. J'ai fait ma thèse dans un labo dirigé par une "célébrité", financièrement c'était pas la dèche loin s'en faut, et pourtant quand on regarde ce que sont devenus les thésards du labo, bin c'est pas brillantissime, les gens en poste c'est a vue de nez 25% des ex-thésard. L'histoire des patrons connus qui recase leur jeune grace a leur appuis politique, dans ma discipline, en eco/evo, ca me semble plus etre vrai, si celà a été vrai un jour (je ne sais pas). Le marché de l'emplois est devenu trop tendu, c'est trop la guerre pour les postes.
    J
    invite17a570c1
    Il y a aussi une autre chose à voir, surtout en ce qui concerne les USA. Un cha "célèbre" peut prendre un grand nombre de thésards, mais étant très occupé, ils sont souvent confiés à des post-docs... En revanche, en France une telle situation est a priori impossible vu qu'un HDR ne peut avoir que 2 (parfois 3).
    Enfin, je rejoins John : c'est mieux d'avoir été avec une célébrité qui a de l'argent, mais ensuite il y a des concours pour les postes fixes... Et là, on y arrive ou pas, chef de thèse célèbre ou pas
    invite9c9b9968
    Ça concerne tout le monde, il n'y a rien dans ce que l'article a donné qui ne soit spécifique à un quelconque pays.
    invitec9f0f895
    Meme si c'est caricaturale, je pense que c'est assez vrai au final. et surtout c'est vrai aussi bien pour la france que pour les US.
    YOyo
    invite17a570c1
    Je ne suis pas tout à fait d'accord avec le mot "caricatural", Yoyo
    Disons que la manière dont c'est écrit peut paraître un peu simplette et un peu naïve, mais j'ai trouvé que ça remettait bien les choses à leurs places, surtout dans cette phrase : "you can spend all your working time discovering things and pursuing ideas".
    Ce que je veux dire par là c'est que dans toutes les discussions qui ont eu lieu jusqu'ici, les gens parlaient de la paie et de la précarité de l'emploi; mais personne (ou très peu) est (sont) venu(s) dire que finalement, c'était un moment où on s'épanouit dans sa passion parce qu'on découvre ou invente. Et c'est pour ça que je l'ai mis, parce qu'on aime ou on n'aime pas la recherche, on aime ou on n'aime pas les sciences et ce sans pathos ni niaiseries.
    invite1c3dc18e
    je suis tout à fait d'accord avec la présentation des choses. C'est vrai partout et n'est en aucun cas caricatural quand on veut faire une "bonne" thèse...
  1. Poursuivre ses études de médecine dentaire en France
    Par invitef1bd1457 dans le forum Orientation après le BAC
    Dernier message: 01/07/2010, 18h12
  2. poursuivre ses etudes à l'etranger
    Par invited30c97f8 dans le forum Orientation après le BAC
    Dernier message: 20/11/2007, 18h15
  3. Comment poursuivre d'étude?
    Par invite5b27b6d6 dans le forum Orientation avant le BAC
    Dernier message: 24/11/2005, 10h07
