salut
est ce que vous pouvez m'aider à adapter ce code à 16f877.
Code:RESET_V EQU 0x0000 ; Address of RESET Vector ISR_V EQU 0x0004 ; Address of Interrupt Vector OSC_FREQ EQU D'4000000' ; Oscillator Frequency is 4 MHz LCD_DATA EQU PORTB ; LCD data lines interface LCD_DATA_TRIS EQU TRISB LCD_CTRL EQU PORTA ; LCD control lines interface LCD_LINE0 EQU 0x000 LCD_LINE1 EQU 0x040 LCD_LINE2 EQU 0x014 LCD_LINE3 EQU 0x054 ; PORTA bits LCD_E EQU 2 ; LCD Enable control line LCD_RW EQU 1 ; LCD Read/Write control line LCD_RS EQU 0 ; LCD Register-Select control line ; PORTB bits DB7 EQU 7 ; LCD dataline 7 (MSB) DB6 EQU 6 ; LCD dataline 6 DB5 EQU 5 ; LCD dataline 5 DB4 EQU 4 ; LCD dataline 4 DB3 EQU 3 ; LCD dataline 3 DB2 EQU 2 ; LCD dataline 2 DB1 EQU 1 ; LCD dataline 1 DB0 EQU 0 ; LCD dataline 0 (LSB) ; misc. LCD_TEMP EQU 0x020 ; LCD subroutines internal use TABLE_INDEX EQU 0x021 ; Index to table strings COUNT EQU 0x022 ; A counter DELAY equ 0x023 ; Used in DELAYxxx routines X_DELAY equ 0x024 ; Used in X_DELAYxxx routines ORG 0x000 ; processor reset vector nop ; nop required for icd goto START ; go to beginning of program TABLE_MSG MOVLW 0 ; Startindex of table message DISP_MSG MOVWF TABLE_INDEX ; Holds message address CALL MSG1 ANDLW 0x0FF ; Check if at end of message BTFSC STATUS, Z ; (zero returned at end) GOTO TABLE_MSG_END CALL LCDPUTCHAR ; Display character MOVF TABLE_INDEX, W ; Point to next character ADDLW 1 GOTO DISP_MSG TABLE_MSG_END RETURN TABLE_MSG1 MOVLW 0 ; Startindex of table message DISP_MSG1 MOVWF TABLE_INDEX ; Holds message address CALL MSG2 ANDLW 0x0FF ; Check if at end of message BTFSC STATUS, Z ; (zero returned at end) GOTO TABLE_MSG_END1 CALL LCDPUTCHAR ; Display character MOVF TABLE_INDEX, W ; Point to next character ADDLW 1 GOTO DISP_MSG1 TABLE_MSG_END1 RETURN TABLE_MSG2 MOVLW 0 ; Startindex of table message DISP_MSG2 MOVWF TABLE_INDEX ; Holds message address CALL MSG3 ANDLW 0x0FF ; Check if at end of message BTFSC STATUS, Z ; (zero returned at end) GOTO TABLE_MSG_END2 CALL LCDPUTCHAR ; Display character MOVF TABLE_INDEX, W ; Point to next character ADDLW 1 GOTO DISP_MSG2 TABLE_MSG_END2 RETURN TABLE_MSG3 MOVLW 0 ; Startindex of table message DISP_MSG3 MOVWF TABLE_INDEX ; Holds message address CALL MSG1 ANDLW 0x0FF ; Check if at end of message BTFSC STATUS, Z ; (zero returned at end) GOTO TABLE_MSG_END3 CALL LCDPUTCHAR ; Display character MOVF TABLE_INDEX, W ; Point to next character ADDLW 1 GOTO DISP_MSG3 TABLE_MSG_END3 RETURN TABLE_VIT MOVLW 0 ; Startindex of table message VIT MOVWF TABLE_INDEX ; Holds message address CALL MSG5 ANDLW 0x0FF ; Check if at end of message BTFSC STATUS, Z ; (zero returned at end) GOTO TABLE_VIT_END3 CALL LCDPUTCHAR ; Display character MOVF TABLE_INDEX, W ; Point to next character ADDLW 1 GOTO VIT TABLE_VIT_END3 RETURN ;========================================================= ; LCDINIT ; Initilize LC-Display Module ; Should be modified to your needs (i.e. display type, cursor on/off, etc.) ; OK ;========================================================= LCDINIT ; Busy-flag is not yet valid CLRF LCD_CTRL ; ALL PORT output should output Low. ; power-up delay MOVLW 0x01E CALL X_DELAY500 ; 30 * 0.5mS = 15mS ; Busy Flag should be valid from here MOVLW 0x038 ; 8-bit-interface, 2-lines CALL LCDPUTCMD MOVLW 0x000 ; disp.off, curs.off, no-blink CALL LCDDMODE CALL LCDCLEAR MOVLW 0x004 ; disp.on, curs.off CALL LCDDMODE MOVLW 0x002 ; auto-inc (shift-cursor) CALL LCDEMODE RETURN ;========================================================= ; LCD_ENABLE ; Pulses LCD enable pin ; OK ;========================================================= LCD_ENABLE BSF LCD_CTRL, LCD_E ; LCD E-line High BCF LCD_CTRL, LCD_E ; LCD E-line Low RETURN ;========================================================= ; LCDBUSY ; Returns when LCD busy-flag is inactive ; OK ;========================================================= LCDBUSY BSF STATUS,RP0 ; Select Register page 1 MOVLW 0x0FF ; Set PORTB for input MOVWF LCD_DATA_TRIS BCF STATUS, RP0 ; Select Register page 0 BCF LCD_CTRL, LCD_RS; Set LCD for command mode BSF LCD_CTRL, LCD_RW; Setup to read busy flag BSF LCD_CTRL, LCD_E ; LCD E-line High MOVF LCD_DATA, W ; Read busy flag + DDram address BCF LCD_CTRL, LCD_E ; LCD E-line Low ANDLW 0x80 ; Check Busy flag, High = Busy BTFSS STATUS, Z GOTO LCDBUSY LCDNOTBUSY BCF LCD_CTRL, LCD_RW BSF STATUS, RP0 ; Select Register page 1 MOVLW 0x000 MOVWF LCD_DATA_TRIS ; Set PORTB for output BCF STATUS, RP0 ; Select Register page 0 RETURN ;========================================================= ; LCDCLEAR ; Clears display and returns cursor to home position (upper-left corner). ; ;========================================================= LCDCLEAR MOVLW 0x001 CALL LCDPUTCMD RETURN ;========================================================= ; LCDHOME ; Returns cursor to home position. ; Returns display to original position (when shifted). ; ;========================================================= LCDHOME MOVLW 0x002 CALL LCDPUTCMD RETURN ;========================================================= ; LCDEMODE ; Sets entry mode of display. ; Required entry mode must be set in W ; b0 : 0 = no display shift 1 = display shift ; b1 : 0 = auto-decrement 1 = auto-increment ; b2-7 : don't care ; OK ;========================================================= LCDEMODE ANDLW 0x003 ; Strip upper bits IORLW 0x004 ; Function set CALL LCDPUTCMD RETURN ;========================================================= ; LCDDMODE ; Sets display control. ; Required display mode must be set in W ; b0 : 0 = cursor blink off 1 = cursor blink on ; b1 : 0 = cursor off 1 = cursor on ; b2 : 0 = display off 1 = display on (display data remains in DDRAM) ; b3-7 : don't care ; OK ;========================================================= LCDDMODE ANDLW 0x007 ; Strip upper bits IORLW 0x008 ; Function set CALL LCDPUTCMD RETURN ;========================================================= ; LCDSCGA ; Sets Character-Generator-RAM address. CGRAM is read/written after ; this setting. ; Required CGRAM address must be set in W ; b0-5 : required CGRAM address ; b6-7 : don't care ; ;========================================================= LCDSCGA ANDLW 0x03F ; Strip upper bits IORLW 0x040 ; Function set CALL LCDPUTCMD RETURN ;========================================================= ; LCDSDDA ; Sets the Display-Data-RAM address. DDRAM data is read/written after ; this setting. ; Required DDRAM address must be set in W ; b0-6 : required DDRAM address ; b7 : don't care ; OK ;========================================================= LCDSDDA IORLW 0x080 ; Function set CALL LCDPUTCMD RETURN ;========================================================= ; LCDGADDR ; Returns address counter contents, used for both DDRAM and CGRAM. ; RAM address is returned in W ; ;========================================================= LCDGADDR BSF STATUS,RP0 ; Select Register page 1 MOVLW 0x0FF ; Set PORTB for input MOVWF LCD_DATA_TRIS BCF STATUS, RP0 ; Select Register page 0 BCF LCD_CTRL, LCD_RS; Set LCD for command mode BSF LCD_CTRL, LCD_RW; Setup to read busy flag BSF LCD_CTRL, LCD_E ; LCD E-line High MOVF LCD_DATA, W ; Read busy flag + RAM address BCF LCD_CTRL, LCD_E ; LCD E-line Low ANDLW 0x07F ; Strip upper bit BCF LCD_CTRL, LCD_RW BSF STATUS, RP0 ; Select Register page 1 MOVLW 0x000 MOVWF LCD_DATA_TRIS ; Set PORTB for output BCF STATUS, RP0 ; Select Register page 0 RETURN ;========================================================= ; LCDPUTCHAR ; Sends character to LCD ; Required character must be in W ; OK ;========================================================= LCDPUTCHAR MOVWF LCD_TEMP ; Character to be sent is in W CALL LCDBUSY ; Wait for LCD to be ready BCF LCD_CTRL, LCD_RW; Set LCD in read mode BSF LCD_CTRL, LCD_RS; Set LCD in data mode BSF LCD_CTRL, LCD_E ; LCD E-line High MOVF LCD_TEMP, W MOVWF LCD_DATA ; Send data to LCD BCF LCD_CTRL, LCD_E ; LCD E-line Low RETURN ;========================================================= ; LCDPUTCMD ; Sends command to LCD ; Required command must be in W ; OK ;========================================================= LCDPUTCMD MOVWF LCD_TEMP ; Command to be sent is in W CALL LCDBUSY ; Wait for LCD to be ready BCF LCD_CTRL, LCD_RW; Set LCD in read mode BCF LCD_CTRL, LCD_RS; Set LCD in command mode BSF LCD_CTRL, LCD_E ; LCD E-line High MOVF LCD_TEMP, W MOVWF LCD_DATA ; Send data to LCD BCF LCD_CTRL, LCD_E ; LCD E-line Low RETURN ;********************************************************* ; Delay_time = ((DELAY_value * 3) + 4) * Cycle_time ; DELAY_value = (Delay_time - (4 * Cycle_time)) / (3 * Cycle_time) ; ; i.e. (@ 4MHz crystal) ; Delay_time = ((32 * 3) + 4) * 1uSec ; = 100uSec ; DELAY_value = (500uSec - 4) / 3 ; = 165.33 ; = 165 ;********************************************************* DELAY500 MOVLW D'165' ; +1 1 cycle MOVWF DELAY ; +2 1 cycle DELAY500_LOOP DECFSZ DELAY, F ; step 1 1 cycle GOTO DELAY500_LOOP ; step 2 2 cycles DELAY500_END RETURN ; +3 2 cycles ; ; X_DELAY500 MOVWF X_DELAY ; +1 1 cycle X_DELAY500_LOOP CALL DELAY500 ; step1 wait 500uSec DECFSZ X_DELAY, F ; step2 1 cycle GOTO X_DELAY500_LOOP ; step3 2 cycles X_DELAY500_END RETURN ; +2 2 cycles ;========================================================= ; Table message to display ;========================================================= MSG1 addwf PCL ,F ;Jump to char pointed to in W reg retlw '+' retlw '+' retlw '+' retlw '+' retlw '+' retlw '+' retlw '+' retlw '+' retlw '+' retlw '+' retlw '+' retlw '+' retlw '+' retlw '+' retlw '+' retlw '+' retlw '+' retlw '+' retlw '+' MSG1_END retlw 0 ; IF ( (MSG1 & 0x0FF) >= (MSG1_END & 0x0FF) ) MESSG "Warning - User Definded: Table 'MSG1' crosses page boundry in computed jump" ENDIF return MSG2 addwf PCL ,F ;Jump to char pointed to in W reg retlw '+' retlw ' ' retlw ' ' retlw ' ' retlw 'R' retlw 'O' retlw 'B' retlw 'O' retlw 'T' retlw 'O' retlw 'S' retlw ' ' retlw ' ' retlw '.' retlw ' ' retlw ' ' retlw ' ' retlw ' ' retlw ' ' MSG2_END retlw 0 ; IF ( (MSG2 & 0x0FF) >= (MSG2_END & 0x0FF) ) MESSG "Warning - User Definded: Table 'MSG1' crosses page boundry in computed jump" ENDIF return MSG3 addwf PCL ,F ;Jump to char pointed to in W reg retlw '+' retlw ' ' retlw ' ' retlw 'F' retlw '4' retlw ' ' retlw 'p' retlw 'o' retlw 'u' retlw 'r' retlw ' ' retlw 'E' retlw 'N' retlw 'T' retlw 'R' retlw 'E' retlw 'R' retlw ' ' retlw ' ' MSG3_END retlw 0 ; IF ( (MSG3 & 0x0FF) >= (MSG3_END & 0x0FF) ) MESSG "Warning - User Definded: Table 'MSG1' crosses page boundry in computed jump" ENDIF return MSG5 addwf PCL ,F ;Jump to char pointed to in W reg retlw 'L' retlw 'a' retlw ' ' retlw 'V' retlw 'i' retlw 't' retlw 'e' retlw 's' retlw 's' retlw 'e' retlw ' ' retlw 'e' retlw 's' retlw 't' retlw ':' retlw ' ' retlw ' ' retlw ' ' retlw ' ' MSG5_END retlw 0 ; IF ( (MSG5 & 0x0FF) >= (MSG5_END & 0x0FF) ) MESSG "Warning - User Definded: Table 'MSG1' crosses page boundry in computed jump" ENDIF return INDEX call LCDCLEAR MOVLW '+' ; ASCII '0' MOVWF COUNT MOVLW LCD_LINE0 CALL LCDSDDA ; Position cursor leftmost on first line CALL TABLE_MSG ; Display message MOVLW LCD_LINE0 + 0x013 CALL LCDSDDA ; Position cursor MOVF COUNT, W CALL LCDPUTCHAR ; Display line number MOVLW '+' ; ASCII '0' MOVWF COUNT MOVLW LCD_LINE1 CALL LCDSDDA ; Position cursor leftmost on first line CALL TABLE_MSG1 ; Display message MOVLW LCD_LINE1 + 0x013 CALL LCDSDDA ; Position cursor MOVF COUNT, W CALL LCDPUTCHAR ; Display line number MOVLW '+' ; ASCII '0' MOVWF COUNT MOVLW LCD_LINE2 CALL LCDSDDA ; Position cursor leftmost on first line CALL TABLE_MSG2 ; Display message MOVLW LCD_LINE2 + 0x013 CALL LCDSDDA ; Position cursor MOVF COUNT, W CALL LCDPUTCHAR ; Display line number MOVLW '+' ; ASCII '0' MOVWF COUNT MOVLW LCD_LINE3 CALL LCDSDDA ; Position cursor leftmost on first line CALL TABLE_MSG3 ; Display message MOVLW LCD_LINE3 + 0x013 CALL LCDSDDA ; Position cursor MOVF COUNT, W CALL LCDPUTCHAR ; Display line number RETURN VITESSE CALL LCDCLEAR MOVLW ' ' ; ASCII '0' MOVWF COUNT MOVLW LCD_LINE0 CALL LCDSDDA ; Position cursor leftmost on first line CALL TABLE_MSG1 ; Display message MOVLW LCD_LINE0 + 0x013 CALL LCDSDDA ; Position cursor MOVF COUNT, W CALL LCDPUTCHAR ; Display line number MOVLW ' ' ; ASCII '0' MOVWF COUNT MOVLW LCD_LINE2 CALL LCDSDDA ; Position cursor leftmost on first line CALL TABLE_VIT ; Display message MOVLW LCD_LINE2 + 0x013 CALL LCDSDDA ; Position cursor MOVF COUNT, W CALL LCDPUTCHAR ; Display line number RETURN Niveau step1 call DELAY500 btfss PORTA,3 goto step1 step2 call DELAY500 btfsc PORTA,3 goto step2 step3 call DELAY500 btfss PORTA,3 goto step3 return ;***************************************************************************** ; Initialize processor registers ;***************************************************************************** START ; POWER_ON Reset (Beginning of program) CLRF STATUS ; Do initialization, Select bank 0 CLRF INTCON ; Clear int-flags, Disable interrupts CLRF PCLATH ; Keep in lower 2KByte CLRF PORTA ; ALL PORT output should output Low. CLRF PORTB BSF STATUS, RP0 ; Select bank 1 MOVLW 0x0F8 ; RA2-0 outputs, RA4-3 inputs MOVWF TRISA MOVLW 0x000 ; RB7-0 outputs MOVWF TRISB BSF OPTION_REG, NOT_RBPU ; Disable PORTB pull-ups BCF STATUS, RP0 ; Select bank 0 CALL LCDINIT ; Initialize LCDisplay loop CALL INDEX call Niveau call VITESSE call Niveau goto loop END
