Hello
Arriverez-vous à trouver pourquoi ça ne marcherait pas?
Source: groupsrv sci physicsDiamond has a negative electron work function into vacuum. Tungsten
has a positive electron work function, 4.6 eV, into vacuum. One need
only oppose a diamond point anode and a tungsten cathode in vacuum for
a spontaneous current to flow. The diamond cools from electron
evaporation as the tungsten heats from electron impact. Extract
energy from the spontaneous current flow while using the temp gradient
to drive a Peltier effect generator in the other direction. Infinite
energy is extracted from an otherwise closed system.
Find the fallacy. (If you don't like diamond, cesium has the lowest
positive work function.)
