03/06/2007, 05h29
Sujet 16f84 à 16f877 - Message #1
16f84 à 16f877
salut
est ce que vous pouvez m'aider à adapter ce code à 16f877.
RESET_V EQU 0x0000 ; Address of RESET Vector
ISR_V EQU 0x0004 ; Address of Interrupt Vector
OSC_FREQ EQU D'4000000' ; Oscillator Frequency is 4 MHz
LCD_DATA EQU PORTB ; LCD data lines interface
LCD_DATA_TRIS EQU TRISB
LCD_CTRL EQU PORTA ; LCD control lines interface
LCD_LINE0 EQU 0x000
LCD_LINE1 EQU 0x040
LCD_LINE2 EQU 0x014
LCD_LINE3 EQU 0x054
; PORTA bits
LCD_E EQU 2 ; LCD Enable control line
LCD_RW EQU 1 ; LCD Read/Write control line
LCD_RS EQU 0 ; LCD Register-Select control line
; PORTB bits
DB7 EQU 7 ; LCD dataline 7 (MSB)
DB6 EQU 6 ; LCD dataline 6
DB5 EQU 5 ; LCD dataline 5
DB4 EQU 4 ; LCD dataline 4
DB3 EQU 3 ; LCD dataline 3
DB2 EQU 2 ; LCD dataline 2
DB1 EQU 1 ; LCD dataline 1
DB0 EQU 0 ; LCD dataline 0 (LSB)
; misc.
LCD_TEMP EQU 0x020 ; LCD subroutines internal use
TABLE_INDEX EQU 0x021 ; Index to table strings
COUNT EQU 0x022 ; A counter
DELAY equ 0x023 ; Used in DELAYxxx routines
X_DELAY equ 0x024 ; Used in X_DELAYxxx routines
ORG 0x000 ; processor reset vector
nop ; nop required for icd
goto START ; go to beginning of program
TABLE_MSG
MOVLW 0 ; Startindex of table message
DISP_MSG
MOVWF TABLE_INDEX ; Holds message address
CALL MSG1
ANDLW 0x0FF ; Check if at end of message
BTFSC STATUS, Z ; (zero returned at end)
GOTO TABLE_MSG_END
CALL LCDPUTCHAR ; Display character
MOVF TABLE_INDEX, W ; Point to next character
ADDLW 1
GOTO DISP_MSG
TABLE_MSG_END RETURN
TABLE_MSG1
DISP_MSG1
CALL MSG2
GOTO TABLE_MSG_END1
ADDLW 1
GOTO DISP_MSG1
TABLE_MSG_END1 RETURN
TABLE_MSG2
DISP_MSG2
CALL MSG3
GOTO TABLE_MSG_END2
ADDLW 1
GOTO DISP_MSG2
TABLE_MSG_END2 RETURN
TABLE_MSG3
DISP_MSG3
CALL MSG1
GOTO TABLE_MSG_END3
ADDLW 1
GOTO DISP_MSG3
TABLE_MSG_END3 RETURN
TABLE_VIT
VIT
CALL MSG5
GOTO TABLE_VIT_END3
ADDLW 1
GOTO VIT
TABLE_VIT_END3 RETURN
; LCDINIT
; Initilize LC-Display Module
; Should be modified to your needs (i.e. display type, cursor on/off, etc.)
; OK
LCDINIT
; Busy-flag is not yet valid
CLRF LCD_CTRL ; ALL PORT output should output Low.
; power-up delay
MOVLW 0x01E
CALL X_DELAY500 ; 30 * 0.5mS = 15mS
; Busy Flag should be valid from here
MOVLW 0x038 ; 8-bit-interface, 2-lines
CALL LCDPUTCMD
MOVLW 0x000 ; disp.off, curs.off, no-blink
CALL LCDDMODE
CALL LCDCLEAR
MOVLW 0x004 ; disp.on, curs.off
CALL LCDDMODE
MOVLW 0x002 ; auto-inc (shift-cursor)
CALL LCDEMODE
RETURN
; LCD_ENABLE
; Pulses LCD enable pin
; OK
LCD_ENABLE
BSF LCD_CTRL, LCD_E ; LCD E-line High
BCF LCD_CTRL, LCD_E ; LCD E-line Low
RETURN
; LCDBUSY
; Returns when LCD busy-flag is inactive
; OK
LCDBUSY
BSF STATUS,RP0 ; Select Register page 1
MOVLW 0x0FF ; Set PORTB for input
MOVWF LCD_DATA_TRIS
BCF STATUS, RP0 ; Select Register page 0
BCF LCD_CTRL, LCD_RS; Set LCD for command mode
BSF LCD_CTRL, LCD_RW; Setup to read busy flag
MOVF LCD_DATA, W ; Read busy flag + DDram address
ANDLW 0x80 ; Check Busy flag, High = Busy
BTFSS STATUS, Z
GOTO LCDBUSY
LCDNOTBUSY BCF LCD_CTRL, LCD_RW
BSF STATUS, RP0 ; Select Register page 1
MOVLW 0x000
MOVWF LCD_DATA_TRIS ; Set PORTB for output
RETURN
; LCDCLEAR
; Clears display and returns cursor to home position (upper-left corner).
LCDCLEAR
MOVLW 0x001
CALL LCDPUTCMD
RETURN
; LCDHOME
; Returns cursor to home position.
; Returns display to original position (when shifted).
LCDHOME
MOVLW 0x002
CALL LCDPUTCMD
RETURN
; LCDEMODE
; Sets entry mode of display.
; Required entry mode must be set in W
; b0 : 0 = no display shift 1 = display shift
; b1 : 0 = auto-decrement 1 = auto-increment
; b2-7 : don't care
; OK
LCDEMODE
ANDLW 0x003 ; Strip upper bits
IORLW 0x004 ; Function set
CALL LCDPUTCMD
RETURN
; LCDDMODE
; Sets display control.
; Required display mode must be set in W
; b0 : 0 = cursor blink off 1 = cursor blink on
; b1 : 0 = cursor off 1 = cursor on
; b2 : 0 = display off 1 = display on (display data remains in DDRAM)
; b3-7 : don't care
; OK
LCDDMODE
ANDLW 0x007 ; Strip upper bits
IORLW 0x008 ; Function set
CALL LCDPUTCMD
RETURN
; LCDSCGA
; Sets Character-Generator-RAM address. CGRAM is read/written after
; this setting.
; Required CGRAM address must be set in W
; b0-5 : required CGRAM address
; b6-7 : don't care
LCDSCGA
ANDLW 0x03F ; Strip upper bits
IORLW 0x040 ; Function set
CALL LCDPUTCMD
RETURN
; LCDSDDA
; Sets the Display-Data-RAM address. DDRAM data is read/written after
; this setting.
; Required DDRAM address must be set in W
; b0-6 : required DDRAM address
; b7 : don't care
; OK
LCDSDDA
IORLW 0x080 ; Function set
CALL LCDPUTCMD
RETURN
; LCDGADDR
; Returns address counter contents, used for both DDRAM and CGRAM.
; RAM address is returned in W
LCDGADDR
MOVWF LCD_DATA_TRIS
MOVF LCD_DATA, W ; Read busy flag + RAM address
ANDLW 0x07F ; Strip upper bit
MOVLW 0x000
RETURN
; LCDPUTCHAR
; Sends character to LCD
; Required character must be in W
; OK
LCDPUTCHAR
MOVWF LCD_TEMP ; Character to be sent is in W
CALL LCDBUSY ; Wait for LCD to be ready
BCF LCD_CTRL, LCD_RW; Set LCD in read mode
BSF LCD_CTRL, LCD_RS; Set LCD in data mode
MOVF LCD_TEMP, W
MOVWF LCD_DATA ; Send data to LCD
RETURN
; LCDPUTCMD
; Sends command to LCD
; Required command must be in W
; OK
LCDPUTCMD
MOVWF LCD_TEMP ; Command to be sent is in W
BCF LCD_CTRL, LCD_RS; Set LCD in command mode
MOVF LCD_TEMP, W
RETURN
; Delay_time = ((DELAY_value * 3) + 4) * Cycle_time
; DELAY_value = (Delay_time - (4 * Cycle_time)) / (3 * Cycle_time)
; i.e. (@ 4MHz crystal)
; Delay_time = ((32 * 3) + 4) * 1uSec
; = 100uSec
; DELAY_value = (500uSec - 4) / 3
; = 165.33
; = 165
DELAY500 MOVLW D'165' ; +1 1 cycle
MOVWF DELAY ; +2 1 cycle
DELAY500_LOOP DECFSZ DELAY, F ; step 1 1 cycle
GOTO DELAY500_LOOP ; step 2 2 cycles
DELAY500_END RETURN ; +3 2 cycles
X_DELAY500 MOVWF X_DELAY ; +1 1 cycle
X_DELAY500_LOOP CALL DELAY500 ; step1 wait 500uSec
DECFSZ X_DELAY, F ; step2 1 cycle
GOTO X_DELAY500_LOOP ; step3 2 cycles
X_DELAY500_END RETURN ; +2 2 cycles
; Table message to display
MSG1
addwf PCL ,F ;Jump to char pointed to in W reg
retlw '+'
retlw '+'
retlw '+'
retlw '+'
retlw '+'
retlw '+'
retlw '+'
retlw '+'
retlw '+'
retlw '+'
retlw '+'
retlw '+'
retlw '+'
retlw '+'
retlw '+'
retlw '+'
retlw '+'
retlw '+'
retlw '+'
MSG1_END
retlw 0
IF ( (MSG1 & 0x0FF) >= (MSG1_END & 0x0FF) )
MESSG "Warning - User Definded: Table 'MSG1' crosses page boundry in computed jump"
ENDIF
return
MSG2
retlw '+'
retlw ' '
retlw ' '
retlw ' '
retlw 'R'
retlw 'O'
retlw 'B'
retlw 'O'
retlw 'T'
retlw 'O'
retlw 'S'
retlw ' '
retlw ' '
retlw '.'
retlw ' '
retlw ' '
retlw ' '
retlw ' '
retlw ' '
MSG2_END
retlw 0
IF ( (MSG2 & 0x0FF) >= (MSG2_END & 0x0FF) )
ENDIF
return
MSG3
retlw '+'
retlw ' '
retlw ' '
retlw 'F'
retlw '4'
retlw ' '
retlw 'p'
retlw 'o'
retlw 'u'
retlw 'r'
retlw ' '
retlw 'E'
retlw 'N'
retlw 'T'
retlw 'R'
retlw 'E'
retlw 'R'
retlw ' '
retlw ' '
MSG3_END
retlw 0
IF ( (MSG3 & 0x0FF) >= (MSG3_END & 0x0FF) )
ENDIF
return
MSG5
retlw 'L'
retlw 'a'
retlw ' '
retlw 'V'
retlw 'i'
retlw 't'
retlw 'e'
retlw 's'
retlw 's'
retlw 'e'
retlw ' '
retlw 'e'
retlw 's'
retlw 't'
retlw ':'
retlw ' '
retlw ' '
retlw ' '
retlw ' '
MSG5_END
retlw 0
IF ( (MSG5 & 0x0FF) >= (MSG5_END & 0x0FF) )
ENDIF
return
INDEX
call LCDCLEAR
MOVLW '+' ; ASCII '0'
MOVWF COUNT
MOVLW LCD_LINE0
CALL LCDSDDA ; Position cursor leftmost on first line
CALL TABLE_MSG ; Display message
MOVLW LCD_LINE0 + 0x013
MOVF COUNT, W
CALL LCDPUTCHAR ; Display line number
MOVWF COUNT
MOVLW LCD_LINE1
CALL TABLE_MSG1 ; Display message
MOVLW LCD_LINE1 + 0x013
MOVF COUNT, W
MOVWF COUNT
MOVLW LCD_LINE2
CALL TABLE_MSG2 ; Display message
MOVLW LCD_LINE2 + 0x013
MOVF COUNT, W
MOVWF COUNT
MOVLW LCD_LINE3
CALL TABLE_MSG3 ; Display message
MOVLW LCD_LINE3 + 0x013
MOVF COUNT, W
RETURN
VITESSE
CALL LCDCLEAR
MOVLW ' ' ; ASCII '0'
MOVWF COUNT
MOVLW LCD_LINE0
MOVF COUNT, W
MOVWF COUNT
MOVLW LCD_LINE2
CALL TABLE_VIT ; Display message
MOVF COUNT, W
RETURN
Niveau
step1
call DELAY500
btfss PORTA,3
goto step1
step2
call DELAY500
btfsc PORTA,3
goto step2
step3
call DELAY500
btfss PORTA,3
goto step3
return
; Initialize processor registers
START ; POWER_ON Reset (Beginning of program)
CLRF STATUS ; Do initialization, Select bank 0
CLRF INTCON ; Clear int-flags, Disable interrupts
CLRF PCLATH ; Keep in lower 2KByte
CLRF PORTA ; ALL PORT output should output Low.
CLRF PORTB
BSF STATUS, RP0 ; Select bank 1
MOVLW 0x0F8 ; RA2-0 outputs, RA4-3 inputs
MOVWF TRISA
MOVLW 0x000 ; RB7-0 outputs
MOVWF TRISB
BSF OPTION_REG, NOT_RBPU ; Disable PORTB pull-ups
BCF STATUS, RP0 ; Select bank 0
CALL LCDINIT ; Initialize LCDisplay
loop
CALL INDEX
call Niveau
call VITESSE
call Niveau
goto loop
END
Aujourd'hui
Liens sponsorisés
03/06/2007, 15h45
Sujet 16f84 à 16f877 - Message #2
Re : 16f84 à 16f877
Il manque les 3/4 du programme...
Sinon, pour la partie du code que tu présentes dans le post #1, il n'y a rien à changer pour passer du 16F84 au 16f877.
David.
03/06/2007, 17h00
Sujet 16f84 à 16f877 - Message #3
Re : 16f84 à 16f877
salut le code que je te présente ici fonction très bien avec 16f84
mais pas avec 877
03/06/2007, 17h11
Sujet 16f84 à 16f877 - Message #4
Re : 16f84 à 16f877
Voir la page 29 du datasheet
pour mettre toute les pins du portA en digital
A+, pat
03/06/2007, 17h16
Sujet 16f84 à 16f877 - Message #5
Re : 16f84 à 16f877
Dans "START",
Il faut invalider les entrées analoqiques du 16f877 présentent sur le portA, qui n'existe pas sur le 16F84.
David.
Edit : pas vu la réponse de pat...
Dernière modification par DavidDB 03/06/2007 à 17h20.
Motif: trop lent...
03/06/2007, 18h56
Sujet 16f84 à 16f877 - Message #6
Re : 16f84 à 16f877
dans le start je met
movlw 6
movwf ADCON1
mais ça ne fonctionne pas
03/06/2007, 19h30
Sujet 16f84 à 16f877 - Message #7
Re : 16f84 à 16f877
ADCON1 est en bank1...
David.
03/06/2007, 20h11
Sujet 16f84 à 16f877 - Message #8
Re : 16f84 à 16f877
ça ne marche pas
03/06/2007, 23h06
Sujet 16f84 à 16f877 - Message #9
Re : 16f84 à 16f877
ne pas oublier bank1 puis le retour bank0 après le adcon1.
voir la vitesse du delay aussi si l'on passede 4mhz à 20 mhz
A+, pat
04/06/2007, 00h17
Sujet 16f84 à 16f877 - Message #10
Re : 16f84 à 16f877
CLRF PORTB
MOVWF TRISA
MOVWF TRISB
movlw 6
movwf ADCON1
loop
CALL INDEX
call Niveau
call VITESSE
call Niveau
goto loop
END
04/06/2007, 01h14
Sujet 16f84 à 16f877 - Message #11
Re : 16f84 à 16f877
Je ne comprends pas comment ce programme peut fonctionner sur 16F84...
Jusqu'à la FIN de la phase d'initialisation du LCD, il est INTERDIT de vérifier BUSY FLAG...
Or, dans l'init du LCD dès la première commande, tu testes BUSY FLAG ce qui empêche une initialisation correct du LCD...
Donc, il est impossible que ce programme fonctionne tel quel sur 16F84!
David.
04/06/2007, 02h45
Sujet 16f84 à 16f877 - Message #12
Re : 16f84 à 16f877
Pourrais-tu ajouter les lignes dans mon code, car je ne comprends pas.
04/06/2007, 14h38
Sujet 16f84 à 16f877 - Message #13
Re : 16f84 à 16f877
Non, je ne corrige pas ton code...
Tu ouvres le datasheet d'un LCD, et tu adaptes ton programme en suivant à la lettre la procédure d'initialisation!
Je n'apprécie pas le fait que tu dises que ton programme fonctionne sur 16F84, alors qu'une lecture rapide de ton code montre des erreurs flagrantes rendant impossible la mise en service du LCD.
Et ceci n'a rien avoir avec la migration du programme d'un 16f84 vers 16f877 (Pat a donné l'unique modification à faire dans ton cas)
David.
04/06/2007, 16h53
Sujet 16f84 à 16f877 - Message #15
Re : 16f84 à 16f877
Non, cela ne fonctionne pas!
Un extrait d'un datasheet LCD (idem au HDxxx):
During the initialization, the following instructions are executed, and BF (Busy Flag) is kept “High” (busy state) to
the end of initialization.
Il faut utiliser des tempos jusqu'a la fin de l'initialisation comme mentionné dans le datasheet pour un fonctionnement correct du LCD.
David.
04/06/2007, 18h40
Sujet 16f84 à 16f877 - Message #16
Re : 16f84 à 16f877
LCDINIT
; power-up delay
MOVLW 0x01E
CALL LCDPUTCMD
MOVLW 0x01E
CALL LCDDMODE
MOVLW 0x01E
CALL LCDCLEAR
MOVLW 0x01E
CALL LCDDMODE
MOVLW 0x01E
CALL LCDEMODE
MOVLW 0x01E
RETURN
04/06/2007, 19h04
Sujet 16f84 à 16f877 - Message #17
Re : 16f84 à 16f877
C'est bien essayé, mais ce n'est juste...
Le test de Busy Flag se fait par l'intermédiaire de la routine "LCDPUTCMD" et donc les delais que tu as rajouté ne servent à rien et ne corrige pas le problème.
Est-ce que tu comprends le code de ce programme ?
David.
04/06/2007, 19h22
Sujet 16f84 à 16f877 - Message #18
Re : 16f84 à 16f877
donc je met un delais dans la fonction LCDPUTCMD
Bienvenue |
Publicité |
