Trad FR en fin de post :
Citation:
(idea) by Qeyser (1.8 wk) (print) http://www.google.fr/url?sa=t&ct=res...vQbShep9RLoALQ ? Sat Jun 09 2001 at 19:38:39
C! info: 4 C!s given by: Stride, mat catastrophe, Accipiter, hramyaegr
This research was done by the Matthew Wilson research team at the MIT department of Brain and Cognitive Sciences.
From studies in rats it has been known for a while that certain cells in the hippocampus can encode for the location of the animal during a maze task. These are called "place cells" because, in the most robust examples, the cells are active when and only when the animal is at a single location in the maze or task field - while other cells are exclusively active at other locations in the maze. Matt Wilson and friends repeated this type of experiment with a few variations.
First, they recorded activity from multiple hippocampal cells at once (called ensemble recording) and ran the rats through portions of a very simple circular track several times. Thus, instead of a location in the maze being linked to the activity of one cell in the hippocampus, locations were linked to temporal activity patterns distributed over several cells - unique temporal patterns that were confirmed through many repetitions of the same trial in the maze.
Second (the neat part), when they observed the activity in the same cells while the animals were sleeping, they found that the unique patterns of hippocampus activity seen in the maze were *replayed during REM sleep*.
Were the rats really dreaming about their day in the lab? That much is not known (and, frankly, were I a rat I *know* I'd be dreaming about sex,) but what this experiment does is lend support to a relatively old theory that hippocampal activity during REM sleep is responsible for memory encoding - a theory that has not had much experimental support so far, but is none-the-less very intuitive and attractive to some neuroscientists.
The original article is "Temporally structured Replay of Awake Hippocampal Ensemble Activity during Rapid Eye Movement Sleep", in the journal Neuron, volume 29, pp 145-56.
SOit : Cette recherche fut faite par MatthewWilson et son equipe au MIT, departement Cerveau, sciences cognitives
D' etudes de rats, on a su depuis longtemps que certaines cellules de l' hippocampe peuvent encoder la location de l' animal pendant un test-labyrinthe.
Elles sont appelées "cellules d' emplacement" car dans les exemples les plus concrets, les cells sont actives ssi le rat se trouve à une location précise, pendant que les autres cellules sont exclusivement actives à d' autres endroits du labyrinthe. (
une sorte de gps organique, une modelisation 3d interne de notre environnement)
Matt et ses amis reproduisirent ce type d' experimentations avec qq variations
1) Ils ont enregistré l' activité de plusieurs cells hippocampales en 1 seule fois (enregistrement d' ensemble) et ont fait courir les rats sur des portions d' 1 circuit circulaire trés simple plusieurs fois.
2eme partie) (la cool), Qd ils ont observé l' activité des même cellules durant le sommeil des rats, ils ont constaté que les groupes uniques d' activité hippocampale étaient "rejouées pendant le sommeil paradoxal"
Les rats rêvaient-ils de leur journée au laby ?On ne peut l' affirmer (et franchement si gt 1 rat , je reverais erotiq), mais cette exp. apporte de l' eau au moulin de la vieille théorie du sommeil paradoxal comme encodeur de mémoire, theorie peu experimentée mais pour autant attractive pour qq neuroscientiF et intuitive.
L' article original est : "Temporally structured Replay of Awake Hippocampal Ensemble Activity during Rapid Eye Movement Sleep", in the journal Neuron, volume 29, pp 145-56.
Bref g vu le zapping, ils sensationnalisent à outrance, g preferé le zapping avec l' extrait de Tf1 sur les chinois telecommandés et les centres de la peur dans le cerveau ou la souris mentale... on dirait que la science interessera les medias le jour ou elle concretisera la fiction (science-fiction, regardes Jules Verne, lui ct un bon vulgarisateur prophète
, ou leur rapportera de l' argent en publi-info.
La preuve ils en font un docu sur ARte... Arte canal direct d' expression scientifique ? Ils sont plus sérieux que le JT, même si bon, tout celà n' eclaire pas vraiment les problematiques de la recherche , de l' éducation ,la paupérisation de la conscience collective
Michel Drucker, jainiste sans le savoir se vante d' avoir fait sa vie dans un km²
A sa mort, examinons son hippocampe ? Les jainistes (une des dix religions principales , celle-ci venant d' inde) comporte un commandement (ils appellent ça un voeu) qui est de limiter ses deplacements à une aire geographique definie... la sedentarisation religieuse
(ca fait plaisir)
