L'arme climatique et tsunamis ? - Page 2
Affichage des résultats 31 à 40 sur 40
    invite9c9b9968
    Re : L'arme climatique et tsunamis?
    J'avoue que dans l'article de Petit qui est cité, il est assez aberrant de vouloir se prétendre "scientifique" quand on en arrive à confondre antimatière et plasma !!
    Merci aux modérateurs pour le travail, car il est vrai que les vacances arrivant, les discussions irrationnelles fleurissent (c'est peut-être l'arrivée du printemps en avance ? )
    invite995693c1
    Citation Envoyé par bardamu
    est-ce que objectivement tu as accès à des informations classées secret défense de l'armée américaine ?
    En tout cas, sur le site du HAARP, ils disent ( http://www.haarp.alaska.edu/haarp/tech.html ) :
    "When complete, the transmitter will be capable of producing up to 3.6 million Watts to an antenna system consisting of 180 crossed dipole antennas arranged as a rectangular, planar array (...)
    During active ionospheric research, the signal generated by the transmitter system is delivered to the antenna array, transmitted in an upward direction, and is partially absorbed, at an altitude between 100 to 350 km (depending on operating frequency), in a small volume a few hundred meters thick and a few tens of kilometers in diameter over the site. The intensity of the HF signal in the ionosphere is less than 3 microwatts per cm2, tens of thousands of times less than the Sun's natural electromagnetic radiation reaching the earth and hundreds of times less than even the normal random variations in intensity of the Sun's natural ultraviolet (UV) energy which creates the ionosphere. The small effects that are produced, however, can be observed with the sensitive scientific instruments installed at the HAARP facility and these observations can provide new information about the dynamics of plasmas and new insight into the processes of solar-terrestrial interactions. "
    3,6 millions de Watt réagissant à plus de 100 km sur un volume de plusieurs kilomètres cubes, ça ne fait pas beaucoup d'énergie au cm2.
    Dans un premier temps, cette installation comportait 50 antennes. Si on consulte le site militaire officiel, en 2002, cette installation devrait comporter 180 antennes dipôles d'une vingtaine de mètres de hauteur. Elles sont alignées sur une zone plane et rectangulaire. L'installation devrait atteindre la puissance de 3,6 millions de Watt (3,6 MW). Selon un brevet déposé, la puissance doit atteindre 27 millions de Watt. Pour d'autres sources, elle devrait être équivalente à 3 milliards de Watt, soit 3 térawatts, ce qui semble élevé, mais pas impossible techniquement. L'ensemble est complété par des dispositifs de mesure et d'observation de l'ionosphère et du sol. Le tout est relié à Internet pour pouvoir communiquer ou échanger des informations avec d'autres centres d'observation de l'ionosphère ou du climat. Cette installation d'émission est capable d'émettre une énergie qui peut atteindre 3 µW/cm² (microwatts par centimètre carré).
    Cette installation peut être qualifiée de polyvalente, comme le prouve les séries de brevets déposés. Elle peut aussi bien être utilisée pour:
    * L'interdiction de l'espace aérien, utilisation comme bouclier antimissile par exemple.
    * La manipulation du climat, créer des perturbations atmosphériques sur d'autres continents.
    * La manipulation du comportement humain, puisque ce système admet une modulation de 0 à 50 KHz, on est donc capable d'interférer sur le spectre cérébral.
    * Maintenir en l'air d'une façon stable des nuages artificiels. Cela peut expliquer le largage par des avions militaires de produits dans le ciel à haute altitude. Ils peuvent servir de réflecteur pour prolonger une couverture radar ou de communication.
    Les installations du système HAARP sont visibles sur le site:
    http://w3.nrl.navy.mil/projects/haarp/photos.html
    http://w3.nrl.navy.mil/projects/haarp/twrview.html
    On voit en premier plan deux groupes d'alimentation électrique chargés d'alimenter les émetteurs haute fréquence.
    invite4251c47f
    Citation Envoyé par Jarod
    Sinon en ce qui concerne haarp,je ne pense pas que la puissance actuelle permette de mofifier le climat...maintenant qu'il fasse des recherches, c'est tout à fait possible.
    C'est tout simplement parce que comme beaucoup vous confondez puissance de déclenchement directe et puissance de stimulation
    invite995693c1
    Hello !
    Désolé, ces sites :
    ont été retirés effectivement pour qu'on ne peut plus citer comme référence. Je vais essayer de faire un lien pour vous montrer ces installations.
    invite4251c47f
    Citation Envoyé par JPL
    Tu donnes dans la nuance ! Et je te rappelle que les scientifiques disent que sauf rares exceptions on ne sait pas prévoir un tremblement de terre actuellement. Donc ils ne sont pas si imbus que cela de leur savoir, ceux qui disent qu'ils ne savent pas.
    DAns le principe de précaution il ne faut jamais être nuancé. D'autant que dans le cas de HAARP ça s'est discuté très sérieusement en commission européenne.
    JPL
    Je ne vois pas ce que le principe de précaution vient faire ici. Quelle précaution prendre ? Je vois plutôt un principe de suspicion.
    invite995693c1
    Citation Envoyé par melchisedec
    Voici un extrait de la résolution européenne qui concerne l'installation HAARP, et démontre s'il le faut les inquiétudes des institutions européennes envers ce système. Extrait de la résolution: A4-0005/99
    Considère que le projet HAARP (High Frequency Active Auroral Research Project), en raison de son impact général sur l'environnement, est un problème d'une portée mondiale et demande que ses implications juridiques, écologiques et éthiques soient examinées par un organe international indépendant avant la poursuite des travaux de recherche et la réalisation d'essais; déplore que le gouvernement des États-Unis ait à maintes reprises refusé d'envoyer un représentant pour apporter un témoignage sur les risques que comporte pour l'environnement et la population le projet HAARP financé actuellement en Alaska, durant l'audition publique ou à l'occasion d'une réunion subséquente de sa commission compétente;
    25. demande à l'organe chargé de l'évaluation des choix scientifiques et techniques (STOA) d'accepter d'examiner les preuves scientifiques et techniques fournies par tous les résultats existants de la recherche sur le programme HAARP aux fins d'évaluer la nature et l'ampleur exactes du danger que HAARP représente pour l'environnement local et mondial et pour la santé publique en général;
    26. invite la Commission à examiner les incidences éventuelles sur l"environnement et la santé publique du programme HAARP pour l"Europe arctique et à lui faire rapport sur le résultat de ses investigations;
    27. demande que soit établi un accord international visant à interdire à l'échelle mondiale tout développement et déploiement d"armes qui pourraient ouvrir la porte à toute forme de manipulation de l'homme;
    28. demande au Conseil et à la Commission d'oeuvrer à la conclusion de traités internationaux visant à protéger l'environnement contre des destructions inutiles en cas de conflit;
    invite995693c1
    Citation Envoyé par annecy
    Hello !
    Désolé, ces sites :
    Voilà ....
    invite995693c1
    JPL
    Je prends mes responsabilités. On parle ici de deux catastrophes de violence élevée, mais pas du tout hors norme. Ces deux catastrophes s'expliquent parfaitement par des phénomènes naturels sauf pour les amateurs de mystère et de grand complot. En termes gentils c'est "pourquoi faire simple quand on peut faire compliqué". En termes plus nets, c'est préférer la construction paranoïaque à l'étude scientifique.
    On est totalement incapable actuellement de provoquer ces phénomènes à l'heure actuelle et, pour prendre l'exemple de la tempête de 99 on ne sait absolument pas déclencher un phénomène qui implique une telle quantité d'énergie, et encore moins le diriger précisément vers une cible.
    Quant à HAARP, s'il est évident qu'il y a derrière bien plus que les déclarations officielles, il ne faut pas tout mélanger.
    Donc j'estime que nous avons été assez patients sur ce sujet qu'il a déjà fallu modérer plusieurs fois et je clos cette discussion.
  1. L'armé Italie ou Belgique
    Par invitee8568f57 dans le forum Orientation après le BAC
    Dernier message: 24/07/2005, 21h33
