erreur timer+interruption
    invite5e12a73c
    j'ai écris un programme avec un timer et interruption, j'arrive pas à le compiler, normalement il doit permettre de déclencher le porta par le LATA. Rien de se passe en simulation.
    Merci de m'aider
    Voici le programme :
    #include <p18cxxx.h>
    #ifndef _XTAL_FREQ
    #define _XTAL_FREQ 4000000 /*4MHz*/
    //#pragma config SOSCSEL = DIG /* Digital (SCLKI) mode*/
    #pragma config FOSC = XT
    #pragma config PLLCFG = ON
    #pragma config PWRTEN = OFF
    #pragma config WDTEN = OFF
    void Int_Hight(void);
    #pragma code HighVector=0x08
    void HighVector(void)
    _asm goto Int_Hight _endasm
    /*ooooooooooooooooooooooooooooo oooooo*/
    #pragma code LowVector=0x18
    void LowVector(void)
    #pragma code
    #pragma interruptlow Int_Hight
    void Int_Hight(void){
    unsigned char i;
    TRISA = 0x00;
    if(INTCONbits.TMR0IF){ /*==1*/
    INTCONbits.TMR0IF=0; /*: Clr Overflow Interrupt Flag bit*/
    TMR0L=0xFE;
    i=LATA;
    i^=i|0x01;
    LATA=i;
    void main (void){
    TRISA=0b11111110; /* Bit 0 out*/
    /**********************TIMER 0 INIT************************** *****************/
    T0CONbits.TMR0ON=1; /*: Timer0 On/Off Control bit
    1 = Enables Timer0*/
    T0CONbits.T08BIT=1; /*: Timer0 8-Bit/16-Bit Control bit
    1 = Timer0 is configured as an 8-bit timer/counter
    0 = Timer0 is configured as a 16-bit timer/counter*/
    T0CONbits.T0CS=0; /*Timer0 Clock Source Select bit
    1 = Transition on T0CKI pin input edge
    0 = Interna clock (FOSC/4)*/
    T0CONbits.PSA=0; /* Timer0 Prescaler Assignment bit
    1 = Timer0 prescaler is not assigned; Timer0 clock input bypasses the prescaler
    0 = Timer0 prescaler is assigned; Timer0 clock input comes from the prescaler output*/
    T0CONbits.T0PS=0x1; /*<2:0>: Timer0 Prescaler Select bits
    111 = 1:256 Prescale value
    110 = 1:128 Prescale value
    101 = 1:64 Prescale value
    100 = 1:32 Prescale value
    011 = 1:16 Prescale value
    010 = 1:8 Prescale value
    001 = 1:4 Prescale value
    000 = 1:2 Prescale value*/
    INTCON2bits.TMR0IP=1; /*TMR0 Overflow Interrupt Priority bit
    1 = High priority
    0 = Low priority*/
    INTCONbits.TMR0IF=0; /*: TMR0 Overflow Interrupt Flag bit
    1 = TMR0 register has overflowed (must be cleared in software)
    0 = TMR0 register did not overflow*/
    INTCONbits.TMR0IE=1; /*: TMR0 Overflow Interrupt Enable bit
    1 = Enables the TMR0 overflow interrupt
    0 = Disables the TMR0 overflow interrupt*/
    RCONbits.IPEN = 1; /*When IPEN = 1:
    1 = Enables all high-priority interrupts
    0 = Disables all interrupts*/
    INTCONbits.GIE=1; /*Global Interrupt Enable bit
    When IPEN = 0:
    1 = Enables all unmasked interrupts
    TMR0L=0xFE; /*Timer0 Register Low Byte*/
    while(1){
    bird12358
    Re : erreur timer+interruption
    Bonjour ,
    A part le fait que les deux vecteurs d'interruption ne doivent pas pointer vers la mémé fonction je crois. Tout me semble bon sinon.
    Essayes:
    Code:
    #pragma code
    #pragma interrupt Int_Hight
    unsigned char i;
    TRISA = 0x00;
    TMR0L=0xFE;
    i=LATA;
    i^=i|0x01;
    LATA=i;
    Tu le mets dans l'interruption haute parce que tu as mis INTCON2bits.TMR0IP=1;
    invite5e12a73c
    Merci bcp, je l'ai modifié, mais ca change toujours pas le bit O du port A, comme indique la simution ci joint.
    #ifndef _XTAL_FREQ
    #pragma code
    unsigned char i;
    TRISA = 0x00;
    TMR0L=0xFE;
    i=LATA;
    i^=i|0x01;
    LATA=i;
    void main (void){
    1 = High priority
    0 = Low priority*/
    When IPEN = 0:
    while(1){
    bird12358
    Rebonjour,
    c'est peutetre a cause ce passage:
    Code:
    i=LATA;
    i^=i|0x01;
    LATA=i;
    Tout d'abord LAT c'est pour faire du write pas du read.Ensuite je comprend pas ce que tu veux faire. Si tu veux inverser l'etat du bit0 fait plutot ca.
    Code:
    LATA=PORTA^0x01;
    Aurélien
    Citation Envoyé par bird12358 Voir le message
    Partiellement faux...
    LATA stocke la valeur des latch de sortie. Tu peux le lire et y ecrire, sans te soucier de l'etat réel de la sortie (en court circuit ou pas).
    Si tu fais "LATA=PORTA^0x01", alors tu fous en l'air tout l'interet du registre LATA.
    Tu peux tres bien faire un LATA=LATA^0x01, et c'est fait pour ça.
    Aurélien
    Aurélien
    Par contre, vu qu'on ne connait pas le modele de PIC sur lequel tu travailles, il est fort possible que RA0 soit configuré comme entrée ANALOGIQUE au démarrage.
    Il faut donc désactiver d'eventuels ADC ou comparateurs.
    Lis bien la datasheet de ton PCI et le chapitre sur les ports.
    Aurélien
    bird12358
    Ah ouia desolé.
    J'avais pas pensé au coup de l'analogique.
    bird12358
    Par contre en quoi le fait de faire ca LATA=PORTA^0x01 mets en l'air tout l'intérêt du registre LATA?
    RISC
    Voir le cours de Bigonoff...
    Quand on lit le LATA on lit le registre de sortie
    Quand on lit le PORTA on lit les broches
    Pas tu tout pareil...
    a+
    Aurélien
    Parce que le registre LAT est là pour éviter de faire l'opération PORTA = PORTA^0x01, susceptible de subir le bug du read-modify-write.
    Si tu fais LATA = PORTA ^0x01, le résultat sera exactement le meme, et on n'aurait alors plus besoin du registre LAT. Il est la, il est donc utile, donc on l'utilise
    Aurélien
    bird12358
    Ok ca marche.
    electron22
    J'ai effectué ce que vous m'avez dit, et ça marche très bien.
    1- J'ai copié collé la ligne : LATB=LATB^0x01;
    2- J'ai vérifié le PORT A, et j'ai constaté que juste les bit 0xD0 qui sont disponible pour les sortie et j'ai pris le bit 0 du PORT B.
    Programme, simulation et datasheet des port ci joint
    Maintenant, je dois procéder à mon but est de contrôler la durer de chaque carré, si vous avez des conseils, s'il vous plaît
    Merci beaucoup c'est gentil
  1. Programmation en C avec Timer 0 et Timer 1
    Par invite6844fe5f dans le forum Électronique
    Réponses: 43
    Dernier message: 20/04/2010, 13h27
  2. [PIC]-Interruption / Timer / Led
    Par jorg1n dans le forum Électronique
    Dernier message: 24/04/2008, 14h55
  3. Réponses: 2
    Dernier message: 08/10/2007, 12h59
  4. Interruption Timer avec PIC16F876A
    Par invite5d1bc976 dans le forum Électronique
    Dernier message: 28/07/2007, 21h57
  5. interruption ( timer )
    Par invite42dae262 dans le forum Électronique
    Dernier message: 13/03/2007, 19h50
