Problème avec RTC 1307 : Le programme 'essai' (ci-joint) fonctionne parfaitement.
Code:
#include <Wire.h>
#include "RTClib.h"
   #include "TM1637.h"
   #define ON 1
   #define OFF 0
   int8_t TimeDisp[] = {0x00,0x00,0x00,0x00};
   unsigned char ClockPoint = 1;
   #define CLK 2//pins definitions for TM1637
   #define DIO 3
   TM1637 tm1637(CLK,DIO);
#if defined(ARDUINO_ARCH_SAMD)
// for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
#define Serial SerialUSB
#endif
RTC_DS1307 rtc;
//char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
void setup () {
    tm1637.set();
    tm1637.init();
#ifndef ESP8266
 while (!Serial); // for Leonardo/Micro/Zero
#endif
  Serial.begin(9600);
  if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
  if (! rtc.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
    // This line sets the RTC with an explicit date & time, for example to set
    // January 21, 2014 at 3am you would call:
    // rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
void loop () {
    DateTime now = rtc.now();
    //Serial.print(now.year(), DEC);
    //Serial.print('/');
    //Serial.print(now.month(), DEC);
    //Serial.print(now.day(), DEC);
    //Serial.print(" (");
    //Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
    //Serial.print(") ");
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    Serial.print(now.minute(), DEC);
    //Serial.print(':');
    //Serial.print(now.second(), DEC);
    Serial.println();
   // Serial.print(" since midnight 1/1/1970 = ");
   // Serial.print(now.unixtime());
   // Serial.print("s = ");
   // Serial.print(now.unixtime() / 86400L);
   // Serial.println("d");
   // Serial.println();
   // delay(5000);
      tm1637.point(POINT_ON);
      TimeDisp[0] = now.hour() / 10;
      TimeDisp[1] = now.hour() % 10;
      TimeDisp[2] = now.minute() / 10;
      TimeDisp[3] = now.minute() % 10;
      tm1637.display(TimeDisp);
      delay(500);
      tm1637.point(POINT_OFF);
      delay(500);
Lorsque je greffe ce programme au programme 'essai_sauv' que je veux utiliser pour mon bateau (affichage de l'heure, pression, température air et eau), il y a un 'bug'. L'afficheur se met à l'heure, le ":" clignote une fois, puis plus rien (l'affichage des températures et pression sur LCD 16x2 fonctionne correctement).
Code:
#include <Wire.h>
#include "RTClib.h"
#define DS1307_I2C_ADDRESS 0x68 // essai avec et sans cette instruction
   // initialisation de l'afficheur
   #include "TM1637.h"
   #define ON 1
   #define OFF 0
   #define DIO 3
#endif
RTC_DS1307 rtc; // initialisation du RTC
 // initialisation LCD
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,16,2);
uint8_t hausse[8]  = {0x7, 0x3, 0x5, 0x8, 0x10, 0x0, 0x0}; // création caractères spéciaux
uint8_t baisse[8]  = {0x0, 0x0, 0x10, 0x8, 0x5, 0x3, 0x7};
#include <Adafruit_BMP085.h>
// Connect VCC of the BMP085 sensor to 3.3V (NOT 5.0V!)
// Connect GND to Ground
// Connect SCL to  Analog 5
// Connect SDA to  Analog 4
Adafruit_BMP085 bmp;
//thermometre etanche
// which analog pin to connect
#define THERMISTORPIN A0
// resistance at 25 degrees C
#define THERMISTORNOMINAL 10000
// temp. for nominal resistance (almost always 25 C)
#define TEMPERATURENOMINAL 25
// how many samples to take and average, more takes longer
// but is more 'smooth'
#define NUMSAMPLES 5
// The beta coefficient of the thermistor (usually 3000-4000)
#define BCOEFFICIENT 3950
// the value of the 'other' resistor
#define SERIESRESISTOR 10000
int samples[NUMSAMPLES];
int T = 0;
int P = 0;
int TE = 0;
int avant = 0; // ces quatre instructions sont utilisées pour une extension du programme
unsigned long N;
unsigned long t;
boolean alarme = false;
void setup () {
 lcd.begin();  // initialize the lcd
  lcd.backlight();
  lcd.createChar(0, hausse);
  lcd.createChar(1, baisse);
  lcd.home ();
   analogReference(EXTERNAL);// précision du thermomètre étanche
  Serial.begin(9600);
  if (!bmp.begin()) {
	Serial.println("Could not find a valid BMP085 sensor, check wiring!");
	while (1) {}
   tm1637.set();
   tm1637.init();
#ifndef ESP8266
#endif
  Serial.begin(9600);
    while (1);
void loop () {
 // pour le bmp 180
     T = Arrondi(bmp.readTemperature());
     Serial.println(T);
     P = Arrondi(bmp.readPressure()/100);
 // pour le thermometre étanche
  uint8_t i;
  float average;
 int j = 0;
 // take N samples in a row, with a slight delay
  for (i=0; i< NUMSAMPLES; i++) {
   samples[i] = analogRead(THERMISTORPIN);
   delay(500);
 // average all the samples out
  average = 0;
     average += samples[i];
 average /= NUMSAMPLES;
 // convert the value to resistance
  average = 1023 / average - 1;
  average = SERIESRESISTOR / average;
  float steinhart;
  steinhart = average / THERMISTORNOMINAL;     // (R/Ro)
  steinhart = log(steinhart);                  // ln(R/Ro)
  steinhart /= BCOEFFICIENT;                   // 1/B * ln(R/Ro)
  steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
  steinhart = 1.0 / steinhart;                 // Invert
  steinhart -= 273.15;
  TE = Arrondi(steinhart);
 // fin des calculs du thermomètre étanche
 // affichage des résultats
  lcd.setCursor(0,0);
  lcd.print("Air ");
  lcd.setCursor(4,0);
  lcd.print(T);
  lcd.setCursor(6,0);
  lcd.write(0xDF); // utilise l'adresse hexa du caractère à afficher (prg customchar de la librairie)
  lcd.setCursor(9,0);
  lcd.print("Eau ");
  lcd.setCursor(13,0);
  lcd.print(TE);
  lcd.setCursor(15,0);
  lcd.write(0xDF);
  lcd.setCursor(4,1);
  lcd.print(P);
  lcd.print("  hPa");
 // récupération de l'heure et affichage
 Serial.print(now.hour());
 Serial.print(":");
 Serial.print(now.minute());
 Serial.print(":");
 Serial.print(now.second());
 Serial.println();
      delay(500);
      delay(500);
// Sous programme arrondi
int Arrondi(float nombre_float)
  float nombre;
  nombre = nombre_float - int(nombre_float);
  if (nombre >= 0.5) { nombre = int(nombre_float) + 1; }
  else { nombre = int(nombre_float); }
  return nombre;
Nouveau en programmation Arduino, je soupçonne un problème de bus I2C, mais c'est juste une idée.
Appel à l'aide !
Et merci d'avance !
