problème avec hexvpn
    barhoumti
    lorsque je lance hexvpn il ne connecte pas il m'a affiché la permiere
    fois
    mer. déc. 17 15:32:55 2014 Hex VPN+ v1.1 by alphastatusv01 - Republic
    of the Philippines
    Wed Dec 17 15:32:55 2014 OpenVPN 2.1_rc19 i686-pc-mingw32 [SSL] [LZO2]
    built on Nov 23 2011
    Wed Dec 17 15:32:55 2014 WARNING: No server certificate verification
    method has been enabled. See http://openvpn.net/howto.html#mitm for
    more info.
    Wed Dec 17 15:32:55 2014 NOTE: the current --script-security setting
    may allow this configuration to call user-defined scripts
    Wed Dec 17 15:32:55 2014 UDPv4 link local (bound): [undef]:53
    Wed Dec 17 15:32:55 2014 UDPv4 link remote: 0.0.0.0:0
    Wed Dec 17 15:34:55 2014 [UNDEF] Inactivity timeout (--ping-restart),
    restarting
    Wed Dec 17 15:34:55 2014 SIGUSR1[soft,ping-restart] received, process
    restarting
    Wed Dec 17 15:35:05 2014 WARNING: No server certificate verification
    more info.
    Wed Dec 17 15:35:05 2014 NOTE: the current --script-security setting
    Wed Dec 17 15:35:05 2014 Re-using SSL/TLS context
    Wed Dec 17 15:35:05 2014 TCP/UDP: Preserving recently used remote
    address: 0.0.0.0:0
    Wed Dec 17 15:35:05 2014 UDPv4 link local (bound): [undef]:53
    Wed Dec 17 15:35:05 2014 UDPv4 link remote: 0.0.0.0:0
    Wed Dec 17 15:37:05 2014 [UNDEF] Inactivity timeout (--ping-restart),
    restarting
    Wed Dec 17 15:37:05 2014 SIGUSR1[soft,ping-restart] received, process
    restarting
    Wed Dec 17 15:37:15 2014 WARNING: No server certificate verification
    more info.
    Wed Dec 17 15:37:15 2014 NOTE: the current --script-security setting
    Wed Dec 17 15:37:15 2014 Re-using SSL/TLS context
    Wed Dec 17 15:37:15 2014 TCP/UDP: Preserving recently used remote
    address: 0.0.0.0:0
    Wed Dec 17 15:37:15 2014 UDPv4 link local (bound): [undef]:53
    Wed Dec 17 15:37:15 2014 UDPv4 link remote: 0.0.0.0:0
    Wed Dec 17 15:39:15 2014 [UNDEF] Inactivity timeout (--ping-restart),
    restarting
    Wed Dec 17 15:39:15 2014 SIGUSR1[soft,ping-restart] received, process
    restarting
    Wed Dec 17 15:39:25 2014 WARNING: No server certificate verification
    more info.
    Wed Dec 17 15:39:25 2014 NOTE: the current --script-security setting
    Wed Dec 17 15:39:25 2014 Re-using SSL/TLS context
    Wed Dec 17 15:39:25 2014 TCP/UDP: Preserving recently used remote
    address: 0.0.0.0:0
    Wed Dec 17 15:39:25 2014 UDPv4 link local (bound): [undef]:53
    Wed Dec 17 15:39:25 2014 UDPv4 link remote: 0.0.0.0:0
    Wed Dec 17 1525 2014 [UNDEF] Inactivity timeout (--ping-restart),
    restarting
    Wed Dec 17 1525 2014 SIGUSR1[soft,ping-restart] received, process
    restarting
    Wed Dec 17 1535 2014 WARNING: No server certificate verification
    more info.
    Wed Dec 17 1535 2014 NOTE: the current --script-security setting may
    Wed Dec 17 1535 2014 Re-using SSL/TLS context
    Wed Dec 17 1535 2014 TCP/UDP: Preserving recently used remote address:
    0.0.0.0:0
    Wed Dec 17 1535 2014 UDPv4 link local (bound): [undef]:53
    Wed Dec 17 1535 2014 UDPv4 link remote: 0.0.0.0:0
    Wed Dec 17 15:43:35 2014 [UNDEF] Inactivity timeout (--ping-restart),
    restarting
    Wed Dec 17 15:43:35 2014 SIGUSR1[soft,ping-restart] received, process
    restarting
    Wed Dec 17 15:43:45 2014 WARNING: No server certificate verification
    more info.
    Wed Dec 17 15:43:45 2014 NOTE: the current --script-security setting
    Wed Dec 17 15:43:45 2014 Re-using SSL/TLS context
    Wed Dec 17 15:43:45 2014 TCP/UDP: Preserving recently used remote
    address: 0.0.0.0:0
    Wed Dec 17 15:43:45 2014 UDPv4 link local (bound): [undef]:53
    Wed Dec 17 15:43:45 2014 UDPv4 link remote: 0.0.0.0:0
    Wed Dec 17 15:45:45 2014 [UNDEF] Inactivity timeout (--ping-restart),
    restarting
    Wed Dec 17 15:45:45 2014 SIGUSR1[soft,ping-restart] received, process
    restarting
    Wed Dec 17 15:45:55 2014 WARNING: No server certificate verification
    more info.
    Wed Dec 17 15:45:55 2014 NOTE: the current --script-security setting
    Wed Dec 17 15:45:55 2014 Re-using SSL/TLS context
    Wed Dec 17 15:45:55 2014 TCP/UDP: Preserving recently used remote
    address: 0.0.0.0:0
    Wed Dec 17 15:45:55 2014 UDPv4 link local (bound): [undef]:53
    Wed Dec 17 15:45:55 2014 UDPv4 link remote: 0.0.0.0:0
    et la deuxieme fois il affiche
    mer. déc. 17 17:09:53 2014 Hex VPN+ v1.1 by alphastatusv01 - Republic
    of the Philippines
    Wed Dec 17 17:09:53 2014 OpenVPN 2.1_rc19 i686-pc-mingw32 [SSL] [LZO2]
    Wed Dec 17 17:09:54 2014 WARNING: No server certificate verification
    more info.
    Wed Dec 17 17:09:54 2014 NOTE: the current --script-security setting
    Wed Dec 17 17:09:54 2014 UDPv4 link local (bound): [undef]:53
    Wed Dec 17 17:09:54 2014 UDPv4 link remote: 0.0.0.0:0
    JPL
    Responsable des forums
    Re : problème avec hexvpn
    Tu n'as pas lu la charte du forum :
    La courtoisie est de rigueur sur ce forum : pour une demande de renseignements bonjour et merci devraient être des automatismes.
    JPL
    Le sujet à été recréé sous une forme plus acceptable. Celui-ci est donc fermé.
  1. problème avec l'utilisation de multimetre avec carte mère
    Par sidouo dans le forum Électronique
    Réponses: 22
    Dernier message: 11/11/2015, 13h02
  2. Problème avec google chrome (et avec mon ordinateur en général)
    Par ceci_est_un_nom dans le forum Logiciel - Software - Open Source
    Dernier message: 03/02/2013, 17h29
  3. Problème avec Inéquation avec valeur absolue et racine
    Par inviteda7b675e dans le forum Mathématiques du collège et du lycée
    Dernier message: 23/09/2011, 18h48
  4. Réponses: 0
    Dernier message: 26/04/2011, 21h25
  5. Réponses: 10
    Dernier message: 22/03/2009, 10h34
