FreeRTOS
FreeRTOS
    invite14c97c22
    FreeRTOS
    J'ai une question qui peux vous parraître débile mais allez j'ose
    J'aimerais savoir et comprendre comment dans un FreeRTOS une fonction puisse devenir une tâche, puis ajouter cette tâche au scheduleur.
    Je vous pose cette question car le principe est de faire du multitâche, dans mon cas, une communication telnet et une communication série. Le problème est qu'elle ne sont pas simultanée mais l'une après l'autre. L'idée est d'ajouter une tâche dans mon freeRTOS.
    Je vous remercie.
    Voici le code de mon FreeRTOS.h
    Code:
    /* This header file is part of the ATMEL AVR-UC3-SoftwareFramework-1.7.0 Release */
        FreeRTOS V6.0.0 - Copyright (C) 2009 Real Time Engineers Ltd.
        * If you are:                                                             *
        *    + New to FreeRTOS,                                                   *
        *    + Wanting to learn FreeRTOS or multitasking in general quickly       *
        *    + Looking for basic training,                                        *
        *    + Wanting to improve your FreeRTOS skills and productivity           *
        * then take a look at the FreeRTOS eBook                                  *
        *        "Using the FreeRTOS Real Time Kernel - a Practical Guide"        *
        *                  http://www.FreeRTOS.org/Documentation                  *
        * A pdf reference manual is also available.  Both are usually delivered   *
        * to your inbox within 20 minutes to two hours when purchased between 8am *
        * and 8pm GMT (although please allow up to 24 hours in case of            *
        * exceptional circumstances).  Thank you for your support!                *
        This file is part of the FreeRTOS distribution.
        FreeRTOS is free software; you can redistribute it and/or modify it under
        the terms of the GNU General Public License (version 2) as published by the
        Free Software Foundation AND MODIFIED BY the FreeRTOS exception.
        ***NOTE*** The exception to the GPL is included to allow you to distribute
        a combined work that includes FreeRTOS without being obliged to provide the
        source code for proprietary components outside of the FreeRTOS kernel.
        FreeRTOS is distributed in the hope that it will be useful, but WITHOUT
        ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
        FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for
        more details. You should have received a copy of the GNU General Public
        License and the FreeRTOS license exception along with FreeRTOS; if not it
        can be viewed here: http://www.freertos.org/a00114.html and also obtained
        by writing to Richard Barry, contact details for whom are available on the
        FreeRTOS WEB site.
        1 tab == 4 spaces!
        http://www.FreeRTOS.org - Documentation, latest information, license and
        contact details.
        http://www.SafeRTOS.com - A version that is certified for use in safety
        critical systems.
        http://www.OpenRTOS.com - Commercial support, development, porting,
        licensing and training services.
    #ifndef INC_FREERTOS_H
    #define INC_FREERTOS_H
     * Include the generic headers required for the FreeRTOS port being used.
    #include <stddef.h>
    /* Basic FreeRTOS definitions. */
    #include "projdefs.h"
    /* Application specific configuration options. */
    #include "FreeRTOSConfig.h"
    /* Definitions specific to the port being used. */
    #include "portable.h"
    /* Defines the prototype to which the application task hook function must
    conform. */
    typedef portBASE_TYPE (*pdTASK_HOOK_CODE)( void * );
     * Check all the required application specific macros have been defined.
     * These macros are application specific and (as downloaded) are defined
     * within FreeRTOSConfig.h.
    #ifndef configUSE_PREEMPTION
    	#error Missing definition:  configUSE_PREEMPTION should be defined in FreeRTOSConfig.h as either 1 or 0.  See the Configuration section of the FreeRTOS API documentation for details.
    #endif
    #ifndef configUSE_IDLE_HOOK
    	#error Missing definition:  configUSE_IDLE_HOOK should be defined in FreeRTOSConfig.h as either 1 or 0.  See the Configuration section of the FreeRTOS API documentation for details.
    #endif
    #ifndef configUSE_TICK_HOOK
    	#error Missing definition:  configUSE_TICK_HOOK should be defined in FreeRTOSConfig.h as either 1 or 0.  See the Configuration section of the FreeRTOS API documentation for details.
    #endif
    #ifndef configUSE_CO_ROUTINES
    	#error  Missing definition:  configUSE_CO_ROUTINES should be defined in FreeRTOSConfig.h as either 1 or 0.  See the Configuration section of the FreeRTOS API documentation for details.
    #endif
    #ifndef INCLUDE_vTaskPrioritySet
    	#error Missing definition:  INCLUDE_vTaskPrioritySet should be defined in FreeRTOSConfig.h as either 1 or 0.  See the Configuration section of the FreeRTOS API documentation for details.
    #endif
    #ifndef INCLUDE_uxTaskPriorityGet
    	#error Missing definition:  INCLUDE_uxTaskPriorityGet should be defined in FreeRTOSConfig.h as either 1 or 0.  See the Configuration section of the FreeRTOS API documentation for details.
    #endif
    #ifndef INCLUDE_vTaskDelete
    	#error Missing definition:  INCLUDE_vTaskDelete		 should be defined in FreeRTOSConfig.h as either 1 or 0.  See the Configuration section of the FreeRTOS API documentation for details.
    #endif
    #ifndef INCLUDE_vTaskCleanUpResources
    	#error Missing definition:  INCLUDE_vTaskCleanUpResources should be defined in FreeRTOSConfig.h as either 1 or 0.  See the Configuration section of the FreeRTOS API documentation for details.
    #endif
    #ifndef INCLUDE_vTaskSuspend
    	#error Missing definition:  INCLUDE_vTaskSuspend	 should be defined in FreeRTOSConfig.h as either 1 or 0.  See the Configuration section of the FreeRTOS API documentation for details.
    #endif
    #ifndef INCLUDE_vTaskDelayUntil
    	#error Missing definition:  INCLUDE_vTaskDelayUntil should be defined in FreeRTOSConfig.h as either 1 or 0.  See the Configuration section of the FreeRTOS API documentation for details.
    #endif
    	#error Missing definition:  INCLUDE_vTaskDelay should be defined in FreeRTOSConfig.h as either 1 or 0.  See the Configuration section of the FreeRTOS API documentation for details.
    #endif
    #ifndef configUSE_16_BIT_TICKS
    	#error Missing definition:  configUSE_16_BIT_TICKS should be defined in FreeRTOSConfig.h as either 1 or 0.  See the Configuration section of the FreeRTOS API documentation for details.
    #endif
    #ifndef configUSE_APPLICATION_TASK_TAG
    	#define configUSE_APPLICATION_TASK_TAG 0
    #endif
    #ifndef INCLUDE_uxTaskGetStackHighWaterMark
    	#define INCLUDE_uxTaskGetStackHighWaterMark 0
    #endif
    #ifndef configUSE_RECURSIVE_MUTEXES
    	#define configUSE_RECURSIVE_MUTEXES 0
    #endif
    #ifndef configUSE_MUTEXES
    	#define configUSE_MUTEXES 0
    #endif
    #ifndef configUSE_COUNTING_SEMAPHORES
    	#define configUSE_COUNTING_SEMAPHORES 0
    #endif
    #ifndef configUSE_ALTERNATIVE_API
    	#define configUSE_ALTERNATIVE_API 0
    #endif
    #ifndef portCRITICAL_NESTING_IN_TCB
    	#define portCRITICAL_NESTING_IN_TCB 0
    #endif
    #ifndef configMAX_TASK_NAME_LEN
    	#define configMAX_TASK_NAME_LEN 16
    #endif
    #ifndef configIDLE_SHOULD_YIELD
    	#define configIDLE_SHOULD_YIELD		1
    #endif
    #if configMAX_TASK_NAME_LEN < 1
    	#undef configMAX_TASK_NAME_LEN
    #endif
    #ifndef INCLUDE_xTaskResumeFromISR
    	#define INCLUDE_xTaskResumeFromISR 1
    #endif
    #ifndef INCLUDE_xTaskGetSchedulerState
    	#define INCLUDE_xTaskGetSchedulerState 0
    #endif
    #if ( configUSE_MUTEXES == 1 )
    	/* xTaskGetCurrentTaskHandle is used by the priority inheritance mechanism
    	within the mutex implementation so must be available if mutexes are used. */
    	#undef INCLUDE_xTaskGetCurrentTaskHandle
    	#define INCLUDE_xTaskGetCurrentTaskHandle 1
    #else
    	#ifndef INCLUDE_xTaskGetCurrentTaskHandle
    		#define INCLUDE_xTaskGetCurrentTaskHandle 0
    	#endif
    #endif
    #ifndef portSET_INTERRUPT_MASK_FROM_ISR
    	#define portSET_INTERRUPT_MASK_FROM_ISR() 0
    #endif
    #ifndef portCLEAR_INTERRUPT_MASK_FROM_ISR
    	#define portCLEAR_INTERRUPT_MASK_FROM_ISR( uxSavedStatusValue ) ( void ) uxSavedStatusValue
    #endif
    #ifndef configQUEUE_REGISTRY_SIZE
    	#define configQUEUE_REGISTRY_SIZE 0
    #endif
    #if configQUEUE_REGISTRY_SIZE < 1
    	#define vQueueAddToRegistry( xQueue, pcName )
    	#define vQueueUnregisterQueue( xQueue )
    #endif
    /* Remove any unused trace macros. */
    #ifndef traceSTART
    	/* Used to perform any necessary initialisation - for example, open a file
    	into which trace is to be written. */
    	#define traceSTART()
    #endif
    #ifndef traceEND
    	/* Use to close a trace, for example close a file into which trace has been
    	written. */
    	#define traceEND()
    #endif
    #ifndef traceTASK_SWITCHED_IN
    	/* Called after a task has been selected to run.  pxCurrentTCB holds a pointer
    	to the task control block of the selected task. */
    	#define traceTASK_SWITCHED_IN()
    #endif
    #ifndef traceTASK_SWITCHED_OUT
    	/* Called before a task has been selected to run.  pxCurrentTCB holds a pointer
    	to the task control block of the task being switched out. */
    	#define traceTASK_SWITCHED_OUT()
    #endif
    #ifndef traceBLOCKING_ON_QUEUE_RECEIVE
    	/* Task is about to block because it cannot read from a
    	queue/mutex/semaphore.  pxQueue is a pointer to the queue/mutex/semaphore
    	upon which the read was attempted.  pxCurrentTCB points to the TCB of the
    	task that attempted the read. */
    	#define traceBLOCKING_ON_QUEUE_RECEIVE( pxQueue )
    #endif
    #ifndef traceBLOCKING_ON_QUEUE_SEND
    	/* Task is about to block because it cannot write to a
    	upon which the write was attempted.  pxCurrentTCB points to the TCB of the
    	task that attempted the write. */
    	#define traceBLOCKING_ON_QUEUE_SEND( pxQueue )
    #endif
    #ifndef configCHECK_FOR_STACK_OVERFLOW
    	#define configCHECK_FOR_STACK_OVERFLOW 0
    #endif
    /* The following event macros are embedded in the kernel API calls. */
    #ifndef traceQUEUE_CREATE
    	#define traceQUEUE_CREATE( pxNewQueue )
    #endif
    #ifndef traceQUEUE_CREATE_FAILED
    	#define traceQUEUE_CREATE_FAILED()
    #endif
    #ifndef traceCREATE_MUTEX
    	#define traceCREATE_MUTEX( pxNewQueue )
    #endif
    #ifndef traceCREATE_MUTEX_FAILED
    	#define traceCREATE_MUTEX_FAILED()
    #endif
    #ifndef traceGIVE_MUTEX_RECURSIVE
    	#define traceGIVE_MUTEX_RECURSIVE( pxMutex )
    #endif
    #ifndef traceGIVE_MUTEX_RECURSIVE_FAILED
    	#define traceGIVE_MUTEX_RECURSIVE_FAILED( pxMutex )
    #endif
    #ifndef traceTAKE_MUTEX_RECURSIVE
    	#define traceTAKE_MUTEX_RECURSIVE( pxMutex )
    #endif
    #ifndef traceCREATE_COUNTING_SEMAPHORE
    	#define traceCREATE_COUNTING_SEMAPHORE()
    #endif
    #ifndef traceCREATE_COUNTING_SEMAPHORE_FAILED
    	#define traceCREATE_COUNTING_SEMAPHORE_FAILED()
    #endif
    #ifndef traceQUEUE_SEND
    	#define traceQUEUE_SEND( pxQueue )
    #endif
    #ifndef traceQUEUE_SEND_FAILED
    	#define traceQUEUE_SEND_FAILED( pxQueue )
    #endif
    #ifndef traceQUEUE_RECEIVE
    	#define traceQUEUE_RECEIVE( pxQueue )
    #endif
    #ifndef traceQUEUE_PEEK
    	#define traceQUEUE_PEEK( pxQueue )
    #endif
    #ifndef traceQUEUE_RECEIVE_FAILED
    	#define traceQUEUE_RECEIVE_FAILED( pxQueue )
    #endif
    #ifndef traceQUEUE_SEND_FROM_ISR
    	#define traceQUEUE_SEND_FROM_ISR( pxQueue )
    #endif
    #ifndef traceQUEUE_SEND_FROM_ISR_FAILED
    	#define traceQUEUE_SEND_FROM_ISR_FAILED( pxQueue )
    #endif
    #ifndef traceQUEUE_RECEIVE_FROM_ISR
    	#define traceQUEUE_RECEIVE_FROM_ISR( pxQueue )
    #endif
    #ifndef traceQUEUE_RECEIVE_FROM_ISR_FAILED
    	#define traceQUEUE_RECEIVE_FROM_ISR_FAILED( pxQueue )
    #endif
    #ifndef traceQUEUE_DELETE
    	#define traceQUEUE_DELETE( pxQueue )
    #endif
    #ifndef traceTASK_CREATE
    	#define traceTASK_CREATE( pxNewTCB )
    #endif
    #ifndef traceTASK_CREATE_FAILED
    	#define traceTASK_CREATE_FAILED( pxNewTCB )
    #endif
    #ifndef traceTASK_DELETE
    	#define traceTASK_DELETE( pxTaskToDelete )
    #endif
    #ifndef traceTASK_DELAY_UNTIL
    	#define traceTASK_DELAY_UNTIL()
    #endif
    	#define traceTASK_DELAY()
    #endif
    #ifndef traceTASK_PRIORITY_SET
    	#define traceTASK_PRIORITY_SET( pxTask, uxNewPriority )
    #endif
    #ifndef traceTASK_SUSPEND
    	#define traceTASK_SUSPEND( pxTaskToSuspend )
    #endif
    #ifndef traceTASK_RESUME
    	#define traceTASK_RESUME( pxTaskToResume )
    #endif
    #ifndef traceTASK_RESUME_FROM_ISR
    	#define traceTASK_RESUME_FROM_ISR( pxTaskToResume )
    #endif
    #ifndef traceTASK_INCREMENT_TICK
    	#define traceTASK_INCREMENT_TICK( xTickCount )
    #endif
    #ifndef configGENERATE_RUN_TIME_STATS
    	#define configGENERATE_RUN_TIME_STATS 0
    #endif
    #if ( configGENERATE_RUN_TIME_STATS == 1 )
    	#ifndef portCONFIGURE_TIMER_FOR_RUN_TIME_STATS
    		#error If configGENERATE_RUN_TIME_STATS is defined then portCONFIGURE_TIMER_FOR_RUN_TIME_STATS must also be defined.  portCONFIGURE_TIMER_FOR_RUN_TIME_STATS should call a port layer function to setup a peripheral timer/counter that can then be used as the run time counter time base.
    	#endif /* portCONFIGURE_TIMER_FOR_RUN_TIME_STATS */
    	#ifndef portGET_RUN_TIME_COUNTER_VALUE
    		#error If configGENERATE_RUN_TIME_STATS is defined then portGET_RUN_TIME_COUNTER_VALUE must also be defined.  portGET_RUN_TIME_COUNTER_VALUE should evaluate to the counter value of the timer/counter peripheral used as the run time counter time base.
    	#endif /* portGET_RUN_TIME_COUNTER_VALUE */
    #endif /* configGENERATE_RUN_TIME_STATS */
    	#define portCONFIGURE_TIMER_FOR_RUN_TIME_STATS()
    #endif
    #ifndef configUSE_MALLOC_FAILED_HOOK
    	#define configUSE_MALLOC_FAILED_HOOK 0
    #endif
    #ifndef portPRIVILEGE_BIT
    	#define portPRIVILEGE_BIT ( ( unsigned portBASE_TYPE ) 0x00 )
    #endif
    #ifndef portYIELD_WITHIN_API
    	#define portYIELD_WITHIN_API portYIELD
    #endif
    #ifndef pvPortMallocAligned
    	#define pvPortMallocAligned( xSize, pvBuffer ) pvPortMalloc( xSize ); ( void ) pvBuffer
    #endif
    #ifndef vPortFreeAligned
    	#define vPortFreeAligned( pvBlockToFree ) vPortFree( pvBlockToFree )
    #endif
    #endif /* INC_FREERTOS_H */
    lou_ibmix_xi
    Re : FreeRTOS
    Ce n'est pas la question qui paraît "débile", mais bien ta méthode de travail qui semble légère, il me semble t'avoir conseillé par 2 fois lors de ton précédent post d'aller lire la documentation de FreeRTOS, et visiblement tu ne l'as pas fait... De plus, FreeRTOS est livré avec des exemples, je pense qu'il doit y avoir des exemples pour le "multi-tâche"...
    Si tu n'as pas compris quelque chose dans la doc, pose une question précise sur ce qui te pose problème.
    invite14c97c22
    Re : FreeRTOS
    Oui j'ai lu mais je ne comprend pas très bien :s
    Ce que je comprend pas c'est que dans un freeRTOS une tache en enchaine une autre suite au "sautement" de la clock.
    Comment faire poru que 2 tâche s'execute en même temps en évitant cette clock
    lou_ibmix_xi
    Re : FreeRTOS
    Arf... Je penses que tu n'as pas compris le concept de "multi-tâches". Il n'y a que sur des processeurs multi-coeurs qui permettent un multi-tâche au sens litéral, et encore si il y a moins de tâches que de coeurs, et que l'OS le permet. Mais, du côté de l'utilisateur (et/ou des applications), tout se passe comme si. Le principe est assez simple:
    -la plupart du temps une appli est en attente d'une entrée/sortie (par exemple pour la com sur liaison série, de données dispo), pendant ce temps là, l'ordonanceur laisse la CPU (ou un de ses coeurs) pour executer des applications qui le peuvent.
    -pour éviter qu'une application ne monopolise le processeur, l'ordonanceur le partage en allouant des morceaux de temps (time slice, tick) à chacune des applications "ordonançable" (schedulable), i.e. aux applications qui ne sont pas bloquées en attente d'une entrée/sortie. Cette tranche de temps est, en général, de l'ordre de la ms, donc suffisament grande pour que l'application "avance" suffisament, mais assez courte pour que l'utilisateur "humain" s'imagine que tous fonctionnent en même temps.
    Le principe est là, mais dans la pratique ça peux se compliquer énormément (temps-réel dur, multi-processeur, systèmes "tickless"...)
    Un conseil: une culture informatique (aspect logiciel et matériel) est indispensable lorsqu'on programme, et plus tu touches au bas niveau, plus ta culture doit être poussée... Et FreeRTOS c'est très bas niveau...
  1. [Offre] Projet "FreeRTOS" Eclipse/gcc/gdb sur Coldfire
    Par invite2562e666 dans le forum Projets électroniques
    Dernier message: 18/04/2013, 12h04
  2. Utilisation de freeRTOS
    Par invite14c97c22 dans le forum Programmation et langages, Algorithmique
    Dernier message: 22/05/2012, 09h23
  3. [ARM] FreeRTOS et SIP
    Par sylfurd dans le forum Électronique
    Dernier message: 22/03/2012, 15h27
  4. FreeRTOS sur STM32F4xx
    Par kronanberg dans le forum Électronique
    Dernier message: 03/01/2012, 14h09
  5. freeRTOS TCPIP
    Par inviteec7e9182 dans le forum Électronique
    Dernier message: 15/01/2011, 09h39
