Test de stroop sous Matlab
    baraque-obama
    J'essaye actuellement de designer un test de stroop sous Matlab qui s'inspire de ce modèle:
    Code PHP:
    http://www.onlinestrooptest.com/stroop_effect_test.php
    Ma question est la suivante:
    quelle devrait être la structure de ce programme ?
    baraque-obama
    Re : Test de stroop sous Matlab
    En sachant que j'ai à ma disposition un programme qui suit la structure suivante:
    extrait:
    Code:
    level = 'ONE';
    TOTALCOUNT=TOTALCOUNT+1;
    if TOTALCOUNT == 1
        vectorAnswer = [0]; vectorTime = [0];   % for data analysis
        cla;drawnow;
        h1=text(0,0,' ','color','w','units','normalized','position',[0.5 0.45],...
             'fontsize',60,'horizontalAlignment','center');
        h2=text(0,0,' ','color','w','units','normalized','position',[0.5 0.15],...
             'fontsize',40,'horizontalAlignment','center');
        set(h1,'string',sprintf('Welcome to training session.')); pause(2);
        set(h1,'string',sprintf('Please answer as quickly as you can..')); pause(3);
        set(h2,'string',sprintf('Press any key to start.'));
        pause();
        cla; drawnow;
    end
    % set(gcf,'units','normalized','position',[-1.1429 -0.0286 1.1429 0.9838]);
    pm=[1 1.5 2];
    switch level
        case 'ONE'
            dice = randi([1 4]);
            num1 = 10;
            if dice == 1
                while num1 < 1 || num1 > 9
                    num2 = randi([1 9]);
                    num3 = randi([1 9]);
                    ans = randi([0 9]);
                    num1 = ans - num2 - num3;
                end
                operand1 = '+'; operand2 = '+';
             elseif dice == 2
                    ans = randi([0 9]);
                    num1 = num2 + num3 + ans;
                end
                operand1 = '-'; operand2 = '-';
            else
                    numA = randi([1 9]);
                    numB = randi([1 9]);
                    ans = randi([0 9]);
                    num1 = ans - numA + numB;
                end
                if dice == 3
                    num2 = numA; num3 = numB; operand1 = '+'; operand2 = '-';
                else
                    num2 = numB; num3 = numA; operand1 = '-'; operand2 = '+';
                end
            end
        case 'TWO'
            dice = randi([1 5]);
            numD = 100;
            if dice < 3
                while numD > 99 || numD < 1
                    numA = randi([10 99]);
                    numB = randi([10 99]);
                    ans = randi([0 9]);
                    numD = numA + numB - ans;
                end
                num_set = [numA numB];
                sign_set = ['+' '-'];
                idx = randperm(numel(num_set));
                if rem(dice,2)
                    num1 = num_set(idx(1)); num2 = num_set(idx(2)); num3 = numD;
                    operand1 = sign_set(1); operand2 = sign_set(2);
                else
                    num1 = num_set(idx(1)); num2 = numD; num3 = num_set(idx(2));
                    operand1 = sign_set(2); operand2 = sign_set(1);
                end
            elseif dice == 3
                    ans = randi([0 9]);
                    numD = numA - numB - ans;
                end
                num_set = [numB numD];
                sign_set = ['-' '-'];
                num1 = numA; num2 = num_set(idx(1)); num3 = num_set(idx(2));
            else
                while numD > 99 || numD < 10
                    numA = randi([10 20]);
                    numB = randi([3 9]);
                    productAB = numA*numB;
                    ans = randi([0 9]);
                    if rem(dice,2)
                        numD = productAB - ans;
                    else
                        numD = productAB + ans;
                    end
                end
                sign_set = ['x' '-'];
                if rem(dice,2)
                else
                    num1 = numD; num2 = num_set(idx(1)); num3 = num_set(idx(2));
                end
            end
        case 'THREE'
            dice = randi([1 35]);
            numD = 100; numA = 100;
            if dice < 5
                while numD > 99 || numD < 1 || numA > 99 || numA < 1
                    numB = randi([3 6]);
                    numA0 = randi([31 99]);
                    numA = numA0 * numB;
                    numC = randi([10 99]);
                    ans = randi([0 9]);
                    numD = (numA/numB) + numC - ans;
                end
                num_set = [numC numD];
                sign_set = ['/' '+' '-'];
                ng_pos = randi([1 4]);
                if ng_pos < 3
                    num1 = num2str(numA); num2 = num2str(numB); num3 = num2str(num_set(idx(1))); num4 = num2str(num_set(idx(2)));
                    operand1 = sign_set(1); operand2 = sign_set(1+idx(1)); operand3 = sign_set(1+idx(2));
                elseif ng_pos == 3
                    num1 = num2str(numC); num2 = num2str(numA); num3 = num2str(numB); num4 = num2str(numD);
                    operand1 = sign_set(2); operand2 = sign_set(1); operand3 = sign_set(3);
                else
                    num1 = num2str(numC); num2 = num2str(numD); num3 = num2str(numA); num4 = num2str(numB);
                    operand1 = sign_set(3); operand2 = sign_set(2); operand3 = sign_set(1);
                end
            elseif dice == 5
                    ans = randi([0 9]);
                    numD = (numA/numB) - numC - ans;
                end
                sign_set = ['/' '-' '-'];
                operand1 = sign_set(1); operand2 = sign_set(2); operand3 = sign_set(3);
            elseif dice > 5 && dice < 8
                    ans = randi([0 9]);
                    numD = ans - numC + (numA/numB);
                end
                sign_set = ['-' '/' '+'];
                if rem(dice,2)
                    num1 = num2str(num_set(idx(1))); num2 = num2str(numA); num3 = num2str(numB); num4 = num2str(num_set(idx(2)));
                else
                    num1 = num2str(num_set(idx(1))); num2 = num2str(num_set(idx(2))); num3 = num2str(numA); num4 = num2str(numB);
                    operand1 = sign_set(3); operand2 = sign_set(1); operand3 = sign_set(2);
                end
            elseif dice == 8
                    ans = randi([0 9]);
                    numD = numC - ans - (numA/numB);
                end
                sign_set = ['-' '-' '/'];
            elseif dice >8 && dice < 11
                    numC = randi([1 9]);
                    numA0 = randi([1 9]);
                    numA = numA0 * numB * numC;
                    ans = randi([0 9]);
                    numD = ans - (numA/(numB*numC));
                end
                num_set = [numB numC];
                sign_set = ['/' 'x' '+'];
                if rem(dice,2)
                    num1 = num2str(numA); num2 = ['(' num2str(num_set(idx(1)))]; num3 = [num2str(num_set(idx(2))) ')']; num4 = num2str(numD);
                else
                    num1 = num2str(numD); num2 = num2str(numA); num3 = ['(' num2str(num_set(idx(1)))]; num4 = [num2str(num_set(idx(2))) ')'];
                end
            elseif dice == 11
                    numC = randi([3 9]);
                    ans = randi([0 9]);
                    numD = numC*((numA/numB)-ans);
                end
                sign_set = ['/' '-' '/'];
                num1 = num2str(numA); num2 = num2str(numB); num3 = num2str(numD); num4 = num2str(numC);
            elseif dice == 12
                    numC = randi([3 6]);
                    ans = randi([0 9]);
                    numD = ((numA*numB)+ans)*numC;
                end
                sign_set = ['/' '-' 'x'];
                num1 = num2str(numD); num2 = num2str(numC); num3 = num2str(numA); num4 = num2str(numB);
            elseif dice == 13
                while numD > 99 || numD < 1 || numC > 99 || numC < 1
                    numC0 = randi([10 99]);
                    numC = numC0*numB;
                    ans = randi([0 9]);
                    numD = ((numA*numC)/numB)-ans;
                end
                sign_set = ['x' '/' '-'];
            elseif dice > 13 && dice < 17
                    ans = randi([0 9]);
                    numD = numA + numB + numC - ans;
                end
                num_set = [numA numB numC];
                sign_set = ['+' '+' '-'];
                ng_pos = randi([1 3]);
                if ng_pos == 1
                    num1 = num2str(num_set(idx(1))); num2 = num2str(num_set(idx(2))); num3 = num2str(num_set(idx(3))); num4 = num2str(numD);
                elseif ng_pos == 2
                    num1 = num2str(num_set(idx(1))); num2 = num2str(num_set(idx(2))); num3 = num2str(numD); num4 = num2str(num_set(idx(3)));
                    operand1 = sign_set(1); operand2 = sign_set(3); operand3 = sign_set(2);
                else
                    num1 = num2str(num_set(idx(1))); num2 = num2str(numD); num3 = num2str(num_set(idx(2))); num4 = num2str(num_set(idx(3)));
                end
            elseif dice > 16 && dice < 23
                    ans = randi([0 9]);
                    numD = numA + numB - numC - ans;
                end
                num_set1 = [numA numB]; num_set2 = [numC numD];
                sign_set = ['+' '-' '-'];
                idx1 = randperm(numel(num_set1)); idx2 = randperm(numel(num_set2));
                if ng_pos == 1
                    num1 = num2str(num_set1(idx1(1))); num2 = num2str(num_set1(idx1(2))); num3 = num2str(num_set2(idx2(1))); num4 = num2str(num_set2(idx2(2)));
                elseif ng_pos == 2
                    num1 = num2str(num_set1(idx1(1))); num2 = num2str(num_set2(idx2(1))); num3 = num2str(num_set1(idx1(2))); num4 = num2str(num_set2(idx2(2)));
                else
                    num1 = num2str(num_set1(idx1(1))); num2 = num2str(num_set2(idx2(1))); num3 = num2str(num_set2(idx2(2))); num4 = num2str(num_set1(idx1(2)));
                    operand1 = sign_set(2); operand2 = sign_set(3); operand3 = sign_set(1);
                end
           else
                    ans = randi([0 9]);
                    numD = numA - numB - numC - ans;
                end
                num_set = [numB numC numD];
                sign_set = ['-' '-' '-'];
                num1 = num2str(numA); num2 = num2str(num_set(idx(1))); num3 = num2str(num_set(idx(2))); num4 = num2str(num_set(idx(3)));
            end
        otherwise
            warning('Unexpected level of difficulty');
    end
    finalAnswer = ans;
    Antoane
    Responsable technique
    J'imagine que tu vas utiliser un GUI.
    Tu peux alors utiliser la fonction @rand pour choisir couleurs et mots à afficher.
    La mise à jour peut se faire directement depuis le call-back des boutons utilisés par l'utilisateur.
    La mesure du temps de réponse peut se faire à partir des instructions tic/toc ou @clock.
    Personnellement, je n'étudie pas un code non-commenté
  1. Sous matlab
    Par invitebe397382 dans le forum Programmation et langages, Algorithmique
    Dernier message: 04/05/2012, 13h32
  2. test adf sous matlab
    Par invite1c11a5c3 dans le forum Logiciel - Software - Open Source
    Dernier message: 14/03/2011, 00h11
  3. fft sous matlab
    Par invite1178bc9c dans le forum Logiciel - Software - Open Source
    Dernier message: 13/12/2009, 17h23
  4. Matlab 6 sous mac OS X
    Par invite751f915c dans le forum Logiciel - Software - Open Source
    Dernier message: 03/06/2004, 08h25
