code source en vhdl [déplacé]
    invite4add737e
    svp je recherche le code source en langage vhdl d'un cicuit electronique realisant la fonction comptage et affichage sur quatre afficheurs 7 segments.j'attend vos reponseset merci d'avance.
    KOKO
    inviteacb3e291
    Re : code source en vhdl
    LIBRARY ieee;
    USE ieee.std_logic_1164.all;
    USE work.std_arith.all;
    entity DEC7SEG4 is
    port (DEC :in std_logic_vector(3 downto 0);
    SEGut std_logic_vector(0 to 6));
    end DEC7SEG4;
    architecture ARCH_DEC7SEG4 of DEC7SEG4 is
    begin
    SEG <= "1111110" WHEN DEC = 0
    ELSE "0110000" WHEN DEC = 1
    ELSE "1101101" WHEN DEC = 2
    ELSE "1111001" WHEN DEC = 3
    ELSE "0110011" WHEN DEC = 4
    ELSE "1011011" WHEN DEC = 5
    ELSE "1011111" WHEN DEC = 6
    ELSE "1110000" WHEN DEC = 7
    ELSE "1111111" WHEN DEC = 8
    ELSE "1111011" WHEN DEC = 9
    ELSE "-------";--indeterminé
    end ARCH_DEC7SEG4;
    pour le decodeur 7 segments
    compteur:
    LIBRARY ieee;
    PACKAGE cpt_10_pkg IS
    COMPONENT cpt_10
    PORT (
    clk, reset : IN STD_LOGIC;
    dix : OUT STD_LOGIC ;
    output : OUT STD_LOGIC_VECTOR (3 DOWNTO 0));
    END COMPONENT;
    END cpt_10_pkg;
    LIBRARY ieee;
    ENTITY cpt_10 IS PORT (
    END cpt_10;
    ARCHITECTURE compteur OF cpt_10 IS
    BEGIN
    PROCESS(clk,reset)
    VARIABLE inc :STD_LOGIC_VECTOR (3 DOWNTO 0);
    BEGIN
    IF (reset='1') THEN inc:="0000";
    ELSIF (clk'event and clk='1') THEN
    IF (inc="1001") THEN
    inc:="0000";
    dix <= '1';
    ELSE
    inc:=inc+1;
    dix <='0';
    END IF;
    END IF;
    output <=inc;
    END PROCESS;
    END compteur;
    et le tout:
    LIBRARY ieee;
    USE work.all;
    ENTITY cpt_dec IS PORT (
    centaine : OUT STD_LOGIC;
    segm1, segm2 : OUT STD_LOGIC_VECTOR (6 DOWNTO 0));
    ATTRIBUTE PIN_NUMBERS OF cpt_dec : ENTITY IS
    "clk:2 reset:3 centaine:4 segm1(0):5 segm1(1):6 segm1(2):9 segm1(3):10" &
    " segm1(4):11 segm1(5):12 segm1(6):17 segm2(0):18 segm2(1):19 segm2(2):20" &
    " segm2(3):23 segm2(4):24 segm2(5):25 segm2(6):26";
    END cpt_dec;
    ARCHITECTURE compt_decod OF cpt_dec IS
    SIGNAL clock2 : STD_LOGIC;
    SIGNAL output1,output2 : STD_LOGIC_VECTOR (3 DOWNTO 0);
    COMPONENT dec_7_segm
    PORT (
    input : IN STD_LOGIC_VECTOR (3 DOWNTO 0);
    commande : OUT STD_LOGIC_VECTOR (6 DOWNTO 0));
    END COMPONENT;
    COMPONENT cpt_10
    PORT (
    clk,reset : IN STD_LOGIC;
    END COMPONENT;
    BEGIN
    cpt1 :
    cpt_10
    port map(clk,reset,clock2,output1);
    cpt2 :
    cpt_10
    port map(clock2,reset,centaine,outp ut2);
    decodeur1 :
    dec_7_segm
    port map (output1,segm1);
    decodeur2 :
    dec_7_segm
    port map (output2,segm2);
    END compt_decod;
    bon la il ya deux decodeurs en changeant un peu le code ca devrait lmarcher. en esperant que ca t'aide
    Re : code source en vhdl [déplacé]
    Bonjour à toi aussi koko720 et à tout le groupe
    Ton message a été déplacé, car il se trouvait dans le forum réservé aux projets.
    En tête de forum, il y a un message à lire PRIORITAIREMENT avant de poster. Ce message est effectivement à lire prioritairement avant de poster.
    En outre, la charte du forum prévoit de dire bonjour en arrivant.
    Bien entendu, cela ne fait nullement avancer le schmillblick, mais on remarque ici, que cela rapporte beaucoup plus de réponses pertinentes.
  1. Pb code vhdl!!!
    Par invitedf5f6b15 dans le forum Électronique
    Dernier message: 29/05/2008, 23h26
  2. Décryptage de code source JS
    Par invitee17aeca5 dans le forum Logiciel - Software - Open Source
    Dernier message: 07/09/2007, 18h24
  3. Simulation code vhdl
    Par invite232dbe64 dans le forum Électronique
    Dernier message: 30/11/2006, 09h35
  4. Code VHDL pour un SPI
    Par invite003b36af dans le forum Électronique
    Dernier message: 08/04/2006, 22h09
