Salut tout le monde j'ai créer un logiciel et il ne fonctionne pas c'est un logiciel de type framwork voici le code serveur et client
serveur :
Code:Private Sub ReactorButton1_Click_1(sender As System.Object, e As System.EventArgs) Handles ReactorButton1.Click Winsock1.LocalPort = 8080 Winsock1.Listen() End Sub Private Sub Winsock1_ConnectionRequest(sender As Object, e As AxMSWinsockLib.DMSWinsockControlEvents_ConnectionRequestEvent) Handles Winsock1.ConnectionRequest Winsock1.Close() Winsock1.Accept(e.requestID) End Sub Private Sub Winsock1_DataArrival(sender As Object, e As AxMSWinsockLib.DMSWinsockControlEvents_DataArrivalEvent) Handles Winsock1.DataArrival Dim data As String = "" Dim opt() As String Winsock1.GetData(data) opt = Split(data, "||") Select Case opt(0) Case "connecté" Me.Text = "Connecté !" PictureBox1.BackColor = Color.Lime Case "MSG" If ReactorMultiLineTextBox1.Text = "" Then ReactorMultiLineTextBox1.Text = (ReactorMultiLineTextBox1.Text & "Message de " & opt(1)) Else ReactorMultiLineTextBox1.Text = (ReactorMultiLineTextBox1.Text & vbCrLf & "Message de " & opt(1)) End If MsgBox("Message de " & opt(1), MsgBoxStyle.Exclamation, "Nouveau Message") Case "déconecté" Me.Text = "Cuisine " PictureBox1.BackColor = Color.Red End Select End Sub
et voici le client :
part1 :
part2 :Code:Private Sub Button40_Click(sender As System.Object, e As System.EventArgs) Handles Button40.Click If Button1.Text = "Se connecter" Then On Error Resume Next Winsock1.Close() Winsock1.Connect(TextBox2.Text, TextBox5.Text) End If End Sub Private Sub Winsock1_ConnectEvent(sender As Object, e As System.EventArgs) Handles Winsock1.ConnectEvent Me.Text = "Caisse connecté !" Button40.BackColor = Color.Lime Winsock1.SendData("connecté" & "||") End Sub
Code:Dim txtpsd As String = ("Caisse" & " : " & Form3.RichTextBox1.Text) Dim txtmy As String = ("Moi" & " : " & Form3.RichTextBox1.Text) On Error Resume Next Winsock1.SendData("MSG" & "||" & txtpsd)
