Lcd 2*16 pic c18
Lcd 2*16 pic c18
    cyrildele
    Lcd 2*16 pic c18
    J'ai un petit souci pour afficher du texte sur un afficheur LCD 2x16.
    datasheet: http://www.farnell.com/datasheets/1485447.pdf
    L'erreur doit etre au niveau du programme:
    Code:
    #include <p18f2525.h>
    #include "main.h"
    #include <sw_uart.h>
    #include <stdlib.h>
    #include <string.h>
    #include <timers.h> // Timer library functions
    #include <delays.h>
    #include <math.h>
    #include <stdio.h>
    #include <portb.h>
    #pragma code
    //interruption haute
    #pragma interrupt High_isr
     void High_isr(void)
        unsigned char a;
        if (PIR1bits.RCIF == 1) //interruption voie série 1 réception
            //ceci raz le flag
            // PIR1bits.RCIF = 0;
            a = RCREG;
            // Clear the overrun error condition
            if (RCSTAbits.FERR || RCSTAbits.OERR)
                RCSTAbits.CREN = 0;
                RCSTAbits.CREN = 1;
            if (a != 0xa)
                if (a == 0x0d)
                    *p_ecrit_buffe = 0;
                    p_ecrit_buffe = buffe;
                    flag.b_SERIE_RX = 1;
                else *p_ecrit_buffe++ = a;
    //interruption basse
    #pragma interrupt Low_isr
    void Low_isr(void)  {
    #pragma code
    // LCD
    #define RS PORTBbits.RB2
    #define EN PORTBbits.RB0
    #define LCD_OUT PORTC
    // delay function
    void _delay_us (unsigned char us)
    	while(us--)
    		Nop();
    		Nop();
    void _delay_ms(unsigned char  ms)
    	unsigned char	i, j;
    	while(ms--){
            for (i = 0; i < 20; i++)
            for (j = 0; j < 100; j++)
            Nop();
    // void LCD_STROBE
    void LCD_STROBE()
        EN=1;
        EN=0;
    void LCD_DATA(unsigned char c)
        unsigned char temp, h_nibble, l_nibble;
        RS=1;
        _delay_us(50);           // delay 50us
        temp=LCD_OUT&0xF0;
        h_nibble=(c>>4)&0x0F;
        l_nibble=c&0x0F;
        LCD_OUT = temp|h_nibble;    /// send 4 high bit
        LCD_STROBE();
        LCD_OUT=temp|l_nibble;         // send 4 low bit
        LCD_STROBE();
        _delay_us(50);
    void LCD_CMD(unsigned char c)
        RS = 0;
        _delay_us(50);
        temp=LCD_OUT&0xF0;
        l_nibble=c&0x0F;
        LCD_OUT = temp|h_nibble;    //// send 4 high bit
      //  LCD_STROBE();
      //  LCD_OUT=temp|l_nibble;         // send 4 low bit
       LCD_STROBE();
        _delay_us(50);
    void clear(void) // Clear dislay
        LCD_CMD(0x10);
        _delay_ms(2);
    void LCD_INIT()
        TRISC = 0;
        TRISB = 0;
        RS = 0;
        _delay_ms(100);
        LCD_CMD(0x30);
        _delay_ms(10);
        LCD_CMD(0x30);
        _delay_ms(1);
        LCD_CMD(0x30);
        LCD_CMD(0x20);
        LCD_CMD(0x20);// Function set (4 bit mode)  0010 1000
        LCD_CMD(0x80);
        LCD_CMD(0x00); // Display OFF
        LCD_CMD(0xF0);
        LCD_CMD(0x00);// Display clear
        LCD_CMD(0x10);
        LCD_CMD(0x00); //Entry mode set
        LCD_CMD(0x40);
    void string(const char *q)
        while(*q)
            LCD_DATA(*q++);
    //MAIN
    void main(void)
        RS = 0;
        LCD_INIT();
        string("TEST");
    gabuzo
    Re : Lcd 2*16 pic c18
    Citation Envoyé par cyrildele Voir le message
    Erreur de copier/coller...
    Je suis Charlie
    cyrildele
    ou pas...
    Bien sur je me suis inspiré de code existant mais pas de ctrl+c ctrl+v.
    Une meilleur proposition pour m'aider?
    Merci.
    paulfjujo
    pourquoi n'envoyer qu'un quartet pour la commande ?
    Schema ?
    Ou sont connecter les 4 bits du port C sur le LCD
    verifier si il n'y a pas une config analogique par defaut sur le PORTC et PORTB
    Code:
        RS = 0;
        _delay_us(50);
        temp=LCD_OUT&0xF0;
        l_nibble=c&0x0F;
        LCD_STROBE();
       LCD_STROBE();
        _delay_us(50);
    cyrildele
    Je reposte mon code un peu modifié:
    Code:
    #include "main.h"
    #include <stdlib.h>
    #include <string.h>
    #include <delays.h>
    #include <math.h>
    #include <stdio.h>
    #include <portb.h>
    #pragma code
     void High_isr(void)
        unsigned char a;
            //ceci raz le flag
            a = RCREG;
                RCSTAbits.CREN = 0;
                RCSTAbits.CREN = 1;
            if (a != 0xa)
                if (a == 0x0d)
                    *p_ecrit_buffe = 0;
    #pragma code
    // LCD
    // delay function
    	while(us--)
    		Nop();
    		Nop();
    	unsigned char	i, j;
    	while(ms--){
            Nop();
    // void LCD_STROBE
    void LCD_STROBE()
        EN=1;
        EN=0;
        RS=1;
        temp=LCD_OUT&0xF0;
        l_nibble=c&0x0F;
        LCD_STROBE();
        LCD_STROBE();
        _delay_us(50);
        RS = 0;
        _delay_us(50);
        temp=LCD_OUT&0xF0;
        l_nibble=c&0x0F;
        LCD_STROBE();
       LCD_STROBE();
        _delay_us(50);
        LCD_CMD(0x10);
        _delay_ms(2);
    void LCD_INIT()
        TRISC = 0;
        TRISB = 0;
        RS = 0;
        _delay_ms(100);
        LCD_CMD(0x30);
        _delay_ms(10);
        LCD_CMD(0x30);
        _delay_ms(1);
        LCD_CMD(0x30);
        LCD_CMD(0x20);
        LCD_CMD(0x28);// Function set (4 bit mode)  0010 1000
        LCD_CMD(0x0F); // Display OFF
        LCD_CMD(0x01);// Display clear
        LCD_CMD(0x04); //Entry mode set
        while(*q)
            LCD_DATA(*q++);
    //MAIN
    void main(void)
        LCD_INIT();
        string("3X");
    J'arrive à déplacer le curseur sur l'écran mais je n'arrive pas à écrire...
    Merci.
    cyrildele
    DB4...DB7 -> RC0...RC3
    En -> RB0
    RS -> RB2
    Ca semble bon pour l'initialisation, il ne doit pas y avoir d'erreur au niveau hardware.
    Le problème doit etre dans la routine d'écriture de caractère... j'oublie certainement qq chose...
    paulfjujo
    Code:
    void main(void)
        LCD_INIT();
        string("3X");
       while(1);
    cyrildele
    J'ai essayé mais ca ne marche pas.
    Après "init" j'ai le curseur au 1er caractère qui clignote.
    et après "string("3X")" j'ai les caractères de la 1ere ligne noir et la seconde ligne les 3 lignes du haut noir sur les 16 caractères...
    Merci pour ton aide.
    cyrildele
    Voici mon code un peu simplifié mais il ne fonctionne toujours pas :s
    #include "main.h"
    #include <stdlib.h>
    #include <string.h>
    #include <delays.h>
    #include <math.h>
    #include <stdio.h>
    #include <portb.h>
    #pragma code
    void High_isr(void)
    unsigned char a;
    //ceci raz le flag
    a = RCREG;
    RCSTAbits.CREN = 0;
    RCSTAbits.CREN = 1;
    if (a != 0xa)
    if (a == 0x0d)
    *p_ecrit_buffe = 0;
    #pragma code
    // LCD
    // delay function
    while(us--)
    Nop();
    Nop();
    unsigned char i, j;
    while(ms--)
    Nop();
    // void LCD_STROBE
    void LCD_STROBE()
    EN=1;
    _delay_us(5);
    EN=0;
    RS = 1;
    _delay_us(50);
    PORTC = (c >> 4);
    LCD_STROBE();
    PORTC = (c);
    LCD_STROBE();
    RS = 0;
    _delay_us(50);
    PORTC = (c >> 4);
    LCD_STROBE();
    PORTC = (c);
    LCD_STROBE();
    LCD_CMD(0x01);
    _delay_ms(2);
    void LCD_INIT()
    TRISC = 0;
    TRISB = 0;
    PORTBbits.RB1 = 0;
    RS = 0;
    _delay_ms(100);
    LCD_CMD(0x30);
    _delay_ms(10);
    LCD_CMD(0x30);
    _delay_ms(1);
    LCD_CMD(0x30);
    LCD_CMD(0x20);
    LCD_CMD(0x0C); // Display OFF
    LCD_CMD(0x06); //Entry mode set
    while(*q)
    LCD_DATA(*q++);
    //MAIN
    void main(void)
    PORTBbits.RB1 = 0;
    LCD_INIT();
    LCD_DATA('X');
    while(1);
    _asm_
    Salut
    Essaye d'ajouter LCD_CMD(0x80); à la fin de l'init.
    cyrildele
    POur mettre adresse DDRAM à 0?
    J'ai essayé ca ne fonctionne pas :s
    cyrildele
    une petite idée ça fait des heures que je bloque dessus?
    je ne comprends pas pourquoi ça n'écrit pas sur le lcd...
    merci.
    _asm_
    Peux-mettre un schéma et l'initialisation du pic ?
    cyrildele
    Nom : Sans titre.png
Affichages : 49
Taille : 29,8 Ko
    voici la config:
    Code:
     * File:   main.h
     * Author: Cyril
     * Created on 28 avril 2014, 11:27
    #ifndef MAIN_H
    #define	MAIN_H
    #ifdef	__cplusplus
    extern "C" {
    #endif
    #ifdef	__cplusplus
    #endif
    #endif	/* MAIN_H */
    char *p_ecrit_buffe;
    char buffe[60];
    struct
        unsigned 	b_SERIE_RX:1;
    }flag;
    // CONFIG1H
    #pragma config OSC = INTIO7     // Oscillator Selection bits (Internal oscillator block, CLKOUT function on RA6, port function on RA7)
    #pragma config FCMEN = OFF      // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
    #pragma config IESO = OFF       // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
    // CONFIG2L
    #pragma config PWRT = OFF       // Power-up Timer Enable bit (PWRT disabled)
    #pragma config BOREN = SBORDIS  // Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
    #pragma config BORV = 3         // Brown Out Reset Voltage bits (Minimum setting)
    // CONFIG2H
    #pragma config WDT = OFF         // Watchdog Timer Enable bit (WDT enabled)
    #pragma config WDTPS = 32768    // Watchdog Timer Postscale Select bits (1:32768)
    // CONFIG3H
    #pragma config CCP2MX = PORTC   // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
    #pragma config PBADEN = ON      // PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
    #pragma config LPT1OSC = OFF    // Low-Power Timer1 Oscillator Enable bit (Timer1 configured for higher power operation)
    #pragma config MCLRE = ON       // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
    // CONFIG4L
    #pragma config STVREN = ON      // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
    #pragma config LVP = OFF         // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled)
    #pragma config XINST = OFF      // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
    // CONFIG5L
    #pragma config CP0 = OFF        // Code Protection bit (Block 0 (000800-003FFFh) not code-protected)
    #pragma config CP1 = OFF        // Code Protection bit (Block 1 (004000-007FFFh) not code-protected)
    #pragma config CP2 = OFF        // Code Protection bit (Block 2 (008000-00BFFFh) not code-protected)
    // CONFIG5H
    #pragma config CPB = OFF        // Boot Block Code Protection bit (Boot block (000000-0007FFh) not code-protected)
    #pragma config CPD = OFF        // Data EEPROM Code Protection bit (Data EEPROM not code-protected)
    // CONFIG6L
    #pragma config WRT0 = OFF       // Write Protection bit (Block 0 (000800-003FFFh) not write-protected)
    #pragma config WRT1 = OFF       // Write Protection bit (Block 1 (004000-007FFFh) not write-protected)
    #pragma config WRT2 = OFF       // Write Protection bit (Block 2 (008000-00BFFFh) not write-protected)
    // CONFIG6H
    #pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
    #pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
    #pragma config WRTD = OFF       // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
    // CONFIG7L
    #pragma config EBTR0 = OFF      // Table Read Protection bit (Block 0 (000800-003FFFh) not protected from table reads executed in other blocks)
    #pragma config EBTR1 = OFF      // Table Read Protection bit (Block 1 (004000-007FFFh) not protected from table reads executed in other blocks)
    #pragma config EBTR2 = OFF      // Table Read Protection bit (Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks)
    // CONFIG7H
    #pragma config EBTRB = OFF      // Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
    mon programme:
    Code:
    #include "main.h"
    #include <stdlib.h>
    #include <string.h>
    #include <delays.h>
    #include <math.h>
    #include <stdio.h>
    #include <portb.h>
    #pragma code
     void High_isr(void)
        unsigned char a;
            //ceci raz le flag
            a = RCREG;
                RCSTAbits.CREN = 0;
                RCSTAbits.CREN = 1;
            if (a != 0xa)
                if (a == 0x0d)
                    *p_ecrit_buffe = 0;
    #pragma code
    // LCD
    // delay function
        while(us--)
            Nop();
            Nop();
        unsigned char i, j;
        while(ms--)
        Nop();
    // void LCD_STROBE
    void LCD_STROBE()
        EN = 1;
        _delay_us(20);
        EN = 0;
        RS = 1;
        _delay_us(50);
        PORTC = (c >> 4);
        LCD_STROBE();
        PORTC = (c);
        LCD_STROBE();
        RS = 0;
        _delay_us(50);
        PORTC = (c >> 4);
        LCD_STROBE();
        PORTC = (c);
        LCD_STROBE();
        LCD_CMD(0x01);
        _delay_ms(2);
    void LCD_INIT()
        TRISCbits.RC0 = 0;
        TRISCbits.RC1 = 0;
        TRISCbits.RC2 = 0;
        TRISCbits.RC3 = 0;
        TRISBbits.RB0 = 0;
        TRISBbits.RB1 = 0;
        TRISBbits.RB2 = 0;
        PORTBbits.RB1 = 0;
        RS = 0;
        _delay_ms(50);
        LCD_CMD(0x30);
        _delay_ms(5);
        LCD_CMD(0x30);
        _delay_ms(1);
        LCD_CMD(0x30);
        _delay_ms(1);
        LCD_CMD(0x20);
        _delay_ms(1);
        _delay_ms(1);
        _delay_ms(1);
        _delay_ms(1);
        _delay_ms(1);
        LCD_CMD(0x0F); // Display ON
        _delay_ms(1);
        while(*q)
            LCD_DATA(*q++);
    //MAIN
    void main(void)
        PORTBbits.RB1 = 0;
        LCD_INIT();
    //    LCD_CMD(0x80);
        LCD_DATA('Y');
        while(1);
    Merci.
    cyrildele
    Je pense avoir trouvé le problème, mais pas la solution:
    problème:
    RS passe à l'état bas quand EN passe à l'état haut (vu sur oscilloscope)
    void LCD_STROBE()
    EN = 1; <-- RS passe à 0 ici pourquoi?
    _delay_us(20);
    EN = 0;
    Alors que je l'ai mis à 1 avant:
    RS = 1; <-- état haut de RS
    _delay_us(50);
    d = (c >> 4);
    PORTC = d;
    LCD_STROBE();
    paulfjujo
    Code:
    comme ce sont des sorties essaie avec LAT
    Code:
    #define RS LATBbits.LATB2
    #define EN LATBbits.LATB0
    cyrildele
    Super ca fonctionne! merci!!
    LCD_DATA('Y'); <-- cette fonction écrit bien
    string("OK"); <-- mais celle ci ne fonctionne pas...
    while(*q)
    LCD_DATA(*q++);
    paulfjujo
    y a pas de raison.... c'est OK avec un envoi sur UART1_Write-*q++);
    et peut etre une petite tempo entre chaque caractere?
    si ce n'est qu'il faut aussi LAT au lieu de PORT ICI
    Code:
        RS = 1;
        _delay_us(50);
        LATC = (c >> 4);
        LCD_STROBE();
        LATC = (c);
        LCD_STROBE();
    while(*q)
    LCD_DATA(*q++);
    Delay_ms(10); // utile ?
