BASCOM to MIKRO C
BASCOM to MIKRO C
    bilelchk
    BASCOM to MIKRO C
    bonsoir tout le monde
    je veux convertisseur code bascom en mikroC
    est ce quelqu'un peux m'aider
    Code:
    $regfile = “m16def.dat”
    $crystal = 1000000
    Config Kbd = Portb
    Config Lcd = 16 * 2
    Config Lcdpin = Pin , Db4 = Portc.4 , Db5 = Portc.5 , Db6 = Portc.6 , Db7 = Portc.7 , Rs = Portc.0 , E = Portc.1
    Config Portd = Output
    Config Porta = Input
    Dim A As Byte , B As Byte , Key As Byte , C As Byte , D As Byte , E As Byte
    Cls
    Cursor Off
    B = 0
    D = 1
    Q:
    Locate 1 , 1
    Lcd “Direction:”
    Locate 2 , 1
    Lcd “Speed:”
    Do
    ‘************Read Keyboard
    A = Getkbd()
    If A > 15 Then
       Goto Q
    Else
       Key = Lookup(a , Dta)
         If Key <= 9 Then
               B = B * 10
               B = B + Key
    ‘*************Direction
              If D = 0 Then Lcd B
                       Waitms 270
                   Elseif Key = 10 Then
                       Locate 1 , 11
                       Lcd “Left”
                       C = 1
                       D = 0
                       B = 0
                   Elseif Key = 11 Then
                      Locate 1 , 11
                      Lcd “Right”
                      C = 2
                      D = 0
                      B = 0
    ‘****************reset
                   Elseif Key = 13 Then
                      Cls
                      D = 1
                      B = 0
                      Portd.0 = 0
                      Portd.1 = 0
                      Waitms 50
                      Goto Q
    ‘****************Enter key
                   Elseif Key = 14 Then
                       If D = 0 Then
                           Select Case C
                              Case 1 : Gosub R
                              Case 2 : Gosub T
                           End Select
                       End If
             End If
    End If
    Wait 1
    Loop
    End
    Dta:
    Data 7 , 8 , 9 , 10 , 4 , 5 , 6 , 11 , 1 , 2 , 3 , 12 , 13 , 0 , 14 , 15
    R:
    Do
    Portd = &B00000001 : Waitms B
    Portd = &B00000011 : Waitms B
    Portd = &B00000010 : Waitms B
    Portd = &B00000110 : Waitms B
    Portd = &B00000100 : Waitms B
    Portd = &B00001100 : Waitms B
    Portd = &B00001000 : Waitms B
    Portd = &B00001001 : Waitms B
      If Pina.0 = 1 Then
          Locate 2 , 1
          Lcd “Speed:”
          B = 0
          Lcd B ; “          “
          Return
      End If
    Loop
    T:
    Do
       If Pina.0 = 1 Then
           Locate 2 , 1
           Lcd “Speed:”
           B = 0
           Lcd B ; “          “
           Return
       End If
    Loop
    Dernière modification par Antoane ; 29/04/2015 à 17h50. Motif: Remplacement balises quote par code
  1. Bascom
    Par invitedd1dd413 dans le forum Programmation et langages, Algorithmique
    Dernier message: 18/08/2011, 19h29
  2. Compilateur C Mikro C
    Par invited94a265e dans le forum Programmation et langages, Algorithmique
    Dernier message: 12/01/2011, 15h23
  3. mikro tik
    Par invite7bb02486 dans le forum Internet - Réseau - Sécurité générale
    Dernier message: 07/10/2010, 14h05
  4. Bascom vers language C
    Par inviteb7a0f269 dans le forum Électronique
    Dernier message: 20/05/2010, 13h07
  5. Atmega 16 Project / Dust sensor [Bascom]
    Par inviteb127b9ca dans le forum Électronique
    Dernier message: 24/05/2007, 07h26
