[Programmation] microcontrolleur stm32 + ugfx
    alakaabar
    alors je suis un debutant en systeme embarque ... j´ai commence avec le code de demonstration que je n´arrive pas a bien saisir
    Code:
    #include "includes.h"
    // start and stop bytes for the UART protocol
    #define ESPL_StartByte 0xAA
    #define ESPL_StopByte 0x55
    QueueHandle_t ESPL_RxQueue; // Already defined in ESPL_Functions.h
    SemaphoreHandle_t ESPL_DisplayReady;
    // Structs defined in Demo.h
    // struct line
    // char x_1;
    // char y_1;
    // char x_2;
    // char y_2;
    //char x_3;
     // char x_3;
    // struct coord
    // char x;
    // char y;
    // Stores lines to be drawn
    QueueHandle_t DrawQueue;
    * Entry function to the example program.
    * Initializes hardware and software.
    * Starts scheduler.
    int main() {
    // Initialize Board functions
    ESPL_SystemInit();
    // Initializes Draw Queue with 100 lines buffer
    DrawQueue = xQueueCreate(100, 4 * sizeof(char));
    // Initializes Tasks with their respective priority
    xTaskCreate(drawTask, "drawTask", 1000, NULL, 4, NULL);
    xTaskCreate(checkJoystick, "checkJoystick", 1000, NULL, 3, NULL);
    xTaskCreate(uartReceive, "queueReceive", 1000, NULL, 2, NULL);
    // Start FreeRTOS Scheduler
    vTaskStartScheduler();
    * Example task which draws to the display.
    static void drawTask() {
    char str[100]; // Init buffer for message
    struct line line; // Init buffer for line
    font_t font1; // Load font for ugfx
    font1 = gdispOpenFont("DejaVuSans24*");
    gdispClear(White);
    for (int i = 0; i < 255; i++) {
    gdispDrawLine(10 + i, 170, 10 + i, 200, ((i >> 3) << 11));
    gdispDrawLine(10 + i, 140, 10 + i, 170, ((i >> 3) << 6));
    gdispDrawLine(10 + i, 110, 10 + i, 140, (i >> 3));
    gdispDrawLine(10 + i, 200, 10 + i, 230, (i >> 3) | ((i >> 3) << 6) | ((i >> 3) << 11));
    // Start endless loop
    while (TRUE) {
    // wait for buffer swap
    while (xQueueReceive(DrawQueue, &line, 0) == pdTRUE) {
    // draw to display
    gdispClear(White);
    if (current_layer == LCD_BACKGROUND_LAYER) {
    gdispFillArea(0, 210, 320, 20, Blue);
    } else {
    gdispFillArea(0, 220, 320, 20, Red);
    gdispDrawLine(0, 0, 10, 10, Yellow );
    // Generate string with current joystick values
    sprintf(str, "Axis 1: %5d|Axis 2: %5d|VBat: %5d", ADC_GetConversionValue(ESPL_ADC_Joystick_1),
    ADC_GetConversionValue(ESPL_ADC_Joystick_2),ADC_GetConversionValue(ESPL_ADC_VBat));
    // Print string of joystick values
    gdispDrawString(0, 0, str, font1, Black);
    sprintf(str, "A: %d|B: %d|C %d|D: %d|E: %d|J: %d",
    GPIO_ReadInputDataBit(ESPL_Register_Button_A, ESPL_Pin_Button_A),
    GPIO_ReadInputDataBit(ESPL_Register_Button_B, ESPL_Pin_Button_B),
    GPIO_ReadInputDataBit(ESPL_Register_Button_C, ESPL_Pin_Button_C),
    GPIO_ReadInputDataBit(ESPL_Register_Button_D, ESPL_Pin_Button_D),
    GPIO_ReadInputDataBit(ESPL_Register_Button_E, ESPL_Pin_Button_E),
    GPIO_ReadInputDataBit(ESPL_Register_Button_K, ESPL_Pin_Button_K));
    gdispDrawString(0, 11, str, font1, Black);
    gdispFillCircle(20+ line.x_2,
    10 + line.y_2, 10, Green);
    gdispDrawBox(40+line.x_2,10+line.y_2 ,10, 10, Red);
    // Wait for display to stop writing
    xSemaphoreTake(ESPL_DisplayReady, 0);
    xSemaphoreTake(ESPL_DisplayReady, portMAX_DELAY);
    // swap buffers
    ESPL_DrawLayer();
    * This task polls the joystick value every 20 ticks
    static void checkJoystick() {
    TickType_t xLastWakeTime;
    xLastWakeTime = xTaskGetTickCount();
    struct coord joystick_now = { 0, 0 }, joystick_last = { 0, 0 };
    while (TRUE) {
    // Remember last joystick values
    joystick_last = joystick_now;
    joystick_now.x = (uint8_t) (ADC_GetConversionValue(ESPL_ADC_Joystick_2) >> 4);
    joystick_now.y = (uint8_t) 255 - (ADC_GetConversionValue(ESPL_ADC_Joystick_1) >> 4);
    // Send over UART
    sendLine(joystick_last, joystick_now);
    // Execute every 20 Ticks
    vTaskDelayUntil(&xLastWakeTime, 20);
    * Example function to send data over UART
    void sendLine(struct coord coord_1, struct coord coord_2) {
    char checksum;
    // Generate simple error detection checksum
    checksum = coord_1.x ^ coord_1.y ^ coord_2.x ^ coord_2.y;
    // Structure of one packet:
    // Start byte
    // 4 * line byte
    // checksum (all xor)
    // End byte
    UART_SendData((uint8_t) ESPL_StartByte);
    UART_SendData((uint8_t) coord_1.x);
    UART_SendData((uint8_t) coord_1.y);
    UART_SendData((uint8_t) coord_2.x);
    UART_SendData((uint8_t) coord_2.y);
    UART_SendData((uint8_t) checksum);
    UART_SendData((uint8_t) ESPL_StopByte);
    * Task which receives data via UART and decodes it.
    static void uartReceive() {
    char input;
    uint8_t pos = 0;
    char checksum;
    char buffer[7]; // Start byte,4* line byte, checksum (all xor), End byte
    struct line line;
    while (TRUE) {
    // wait for data in queue
    xQueueReceive(ESPL_RxQueue, &input, portMAX_DELAY);
    // decode package by buffer position
    switch (pos) {
    // start byte
    case 0:
    if (input == ESPL_StartByte) {
    buffer[0] = input;
    pos = 1;
    break;
    // line bytes
    case 1:
    case 2:
    case 3:
    case 4:
    // Check sum
    case 5:
    buffer[pos] = input;
    pos++;
    break;
    // Last byte should be stop byte
    case 6:
    if (input == ESPL_StopByte) {
    // Check if checksum is accurate
    checksum = buffer[1] ^ buffer[2] ^ buffer[3] ^ buffer[4];
    // Decode packet to line struct
    if (buffer[5] == checksum) {
    line.x_1 = buffer[1] / 2;
    line.y_1 = buffer[2] / 2;
    line.x_2 = buffer[3] / 2;
    line.y_2 = buffer[4] / 2;
    // Send line to be drawn
    xQueueSend(DrawQueue, &line, 100);
    pos = 0;
    } else {
    // Reset buffer
    pos = 0;
    } else {
    pos = 0;
    * Idle hook, definition is needed for FreeRTOS to function.
    void VApplicationIdleHook() {
    while (TRUE) {
    enfaite je dois normalement dans ce programme , inserer un cube et un triangle grace a la librarie ugfx et faire la rotation autour d´un cercle ... mais jn´arrive pas bien comprendre comment utiliser les fonctions de Gdisp : http://api.ugfx.org/master/group___g...8eba8cd565e04f
    en plus je ne comprend pas ce que c´est line.x_2 et line.y_2
    Si quelqu´un pourrait aider j´en serai tres reconaissant
    Merci !
    Dernière modification par Antoane ; 14/11/2015 à 10h25. Motif: Remplacement balises html par url
  1. Help me please STM32
    Par ragnotti406 dans le forum Électronique
    Dernier message: 28/04/2014, 18h46
  2. Stm32
    Par etudiant_isi dans le forum Électronique
    Réponses: 34
    Dernier message: 10/02/2014, 19h21
  3. Commander un gyrometre avec microcontrolleur STM32
    Par inviteabf616ac dans le forum Électronique
    Dernier message: 18/04/2013, 15h18
  4. stm32
    Par invite2a8e3215 dans le forum Électronique
    Dernier message: 10/12/2011, 08h30
  5. stm32
    Par wajdibh dans le forum Électronique
    Dernier message: 11/03/2011, 09h38
