[Programmation] Altitude Sensor MPL3115A2
    mohamed_ali
    I'm working on my final school project and I'm using the MPL3115A2. The sensor communicate via I2C, i wrote a code but it didn't work. Can you help me by telling me what's wrong with it?
    here is the code.
    Thank you!
    Code:
    #include "stm32f4xx.h"
    GPIO_InitTypeDef GPIO_InitStruct;
    I2C_InitTypeDef I2C_InitStruct;
    void I2C_Configuration(void)
    	// enable APB1 peripheral clock for I2C1
    	RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
    	// enable clock for SCL and SDA pins
    	RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
    	/* setup SCL and SDA pins
    	 * You can connect I2C1 to two different
    	 * pairs of pins:
    	 * 1. SCL on PB6 and SDA on PB7
    	 * 2. SCL on PB8 and SDA on PB9
    	GPIO_InitStruct.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9; // we are going to use PB6 and PB7
    	GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;			// set pins to alternate function
    	GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;		// set GPIO speed
    	GPIO_InitStruct.GPIO_OType = GPIO_OType_OD;			// set output to open drain --> the line has to be only pulled low, not driven high
    	GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP;			// enable pull up resistors
    	GPIO_Init(GPIOB, &GPIO_InitStruct);					// init GPIOB
    	// Connect I2C1 pins to AF
    	GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_I2C1);	// SCL
    	GPIO_PinAFConfig(GPIOB, GPIO_PinSource9, GPIO_AF_I2C1); // SDA
    	// configure I2C1
    	I2C_InitStruct.I2C_ClockSpeed = 100000; 		// 100kHz
    	I2C_InitStruct.I2C_Mode = I2C_Mode_I2C;			// I2C mode
    	I2C_InitStruct.I2C_DutyCycle = I2C_DutyCycle_2;	// 50% duty cycle --> standard
    	I2C_InitStruct.I2C_OwnAddress1 = 0x00;			// own address, not relevant in master mode
    	I2C_InitStruct.I2C_Ack = I2C_Ack_Disable;		// disable acknowledge when reading (can be changed later on)
    	I2C_InitStruct.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit; // set address length to 7 bit addresses
    	I2C_Init(I2C1, &I2C_InitStruct);				// init I2C1
    	// enable I2C1
    	I2C_Cmd(I2C1, ENABLE);
    void Write_IIC1(uint8_t SlaveAddress,uint8_t REG_Address,uint8_t REG_data)
        while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY));
        I2C_GenerateSTART(I2C1,ENABLE);
        while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
        I2C_Send7bitAddress(I2C1,SlaveAddress,I2C_Direction_Transmitter);
        while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
        I2C_SendData(I2C1,REG_Address);
        while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
        I2C_SendData(I2C1,REG_data);
    uint8_t Read_IIC1(uint8_t SlaveAddress, uint8_t REG_Address)
        uint8_t REG_data;
        I2C_AcknowledgeConfig(I2C1, ENABLE);
        while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
        while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
        I2C_Send7bitAddress(I2C1,SlaveAddress,I2C_Direction_Receiver);
        while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
        while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED));
        REG_data = I2C_ReceiveData (I2C1);
        return REG_data;
    int main(void)
    	int i;
    	RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
    	GPIO_InitStruct.GPIO_Pin=GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
    	GPIO_InitStruct.GPIO_Mode=GPIO_Mode_OUT;
    	GPIO_InitStruct.GPIO_OType=GPIO_OType_PP;
    	GPIO_Init(GPIOD, &GPIO_InitStruct);
    	I2C_Configuration();
    	while (1)
    		Write_IIC1(0x60,0x26,Read_IIC1(0x60, 0x0C)&0x1E);//stand by
    		Write_IIC1(0x60,0x26,Read_IIC1(0x60, 0x0C)|0xC8);//activate altimeter mode ans flags
    		Write_IIC1(0x60,0x26,Read_IIC1(0x60, 0x0C)|0x01);//wake sensor
    		//Write_IIC1(0x60,0x13,0x07);
    		if(Read_IIC1(0x60, 0x0C))
    		  GPIO_SetBits(GPIOD,GPIO_Pin_13);
    Dernière modification par Antoane ; 15/04/2016 à 17h55. Motif: Intégration du code au corps du message.
    Re : Altitude Sensor MPL3115A2
    Bsr,
    ce forum est en langue française. Je pense que cette discussion sera close si tu persistes en Anglais.
    Désolé
    [this forum is french speaking. I feel that this discussion will be closed if you continue with english language.
    Sorry]
    cordialement,
    [best regards]
    mohamed_ali
    On vient de m'avertir par message privé, mais merci d'avoir pris la peine de me rectifier.
    Dois-je comprendre que je devrais reposer ma question en français? Ou est ce que ça va le faire pour cette fois?
    Citation Envoyé par mohamed_ali Voir le message
    ce serait mieux de traduire. (pas le code, le message !)
  1. sensor photo et arduino
    Par maxelectronique dans le forum Électronique
    Dernier message: 29/10/2015, 08h20
  2. Test knock sensor
    Par koyla1982 dans le forum Électronique
    Dernier message: 30/10/2013, 19h19
  3. Arnie sensor/controller
    Par hugo13127 dans le forum Électronique
    Dernier message: 04/01/2013, 12h24
  4. Sensor
    Par du1 dans le forum Électronique
    Dernier message: 07/09/2010, 08h22
  5. moteur sensor less
    Par michel dhieux dans le forum Électronique
    Dernier message: 12/10/2006, 07h51
