cygwin C++ compiler
cygwin C++ compiler
    inviteefb83c40
    Exclamation cygwin C++ compiler
    J'ai cygwin sur mon ordinateur personnel avec windows xp, je lance ./configure et il me renvoit C++ compiler cannot create executables.
    Pourtant j'arrive à utiliser cette commande avec cygwin pour la même installation au travail. Quelqu'un aurait-il une idée d'où peut provenir le bug et comment le solutionner ?
    Ci-dessous le fichier config.log
    Code:
    This file contains any messages produced by compilers while
    running configure, to aid debugging if configure makes a mistake.
    It was created by configure, which was
    generated by GNU Autoconf 2.61. Invocation command line was
    $ ./configure
    ## Platform. ##
    hostname = BETAPLUS
    uname -m = i686
    uname -r = 1.5.25(0.156/4/2)
    uname -s = CYGWIN_NT-5.1
    uname -v = 2008-06-12 19:34
    /usr/bin/uname -p = unknown
    /bin/uname -X = unknown
    /bin/arch = i686
    /usr/bin/arch -k = unknown
    /usr/convex/getsysinfo = unknown
    /usr/bin/hostinfo = unknown
    /bin/machine = unknown
    /usr/bin/oslevel = unknown
    /bin/universe = unknown
    PATH: /usr/local/bin
    PATH: /usr/bin
    PATH: /bin
    PATH: /usr/X11R6/bin
    PATH: /cygdrive/c/texmf/miktex/bin
    PATH: /cygdrive/c/WINDOWS/system32
    PATH: /cygdrive/c/WINDOWS/System32/Wbem
    PATH: /cygdrive/c/Python22
    PATH: /cygdrive/c/matlab6p5/bin/win32
    PATH: /cygdrive/c/Program Files/Microsoft SQL Server/90/Tools/binn/
    PATH: /cygdrive/c/Program Files/QuickTime/QTSystem/
    PATH: /usr/bin
    PATH: /usr/bin
    PATH: /cygdrive/c/Program Files/Microsoft Visual Studio/Common/Tools/WinNT
    PATH: /cygdrive/c/Program Files/Microsoft Visual Studio/Common/MSDev98/Bin
    PATH: /cygdrive/c/Program Files/Microsoft Visual Studio/VC98/bin
    PATH: /cygdrive/c/PROGRA~1/FICHIE~1/MUVEET~1/030625
    PATH: /usr/lib/lapack
    ## Core tests. ##
    configure:2072: checking for a BSD-compatible install
    configure:2128: result: /usr/bin/install -c
    configure:2139: checking whether build environment is sane
    configure:2182: result: yes
    configure:2197: checking for a thread-safe mkdir -p
    configure:2236: result: /usr/bin/mkdir -p
    configure:2249: checking for gawk
    configure:2265: found /usr/bin/gawk
    configure:2276: result: gawk
    configure:2287: checking whether make sets $(MAKE)
    configure:2308: result: yes
    configure:2558: checking for g++
    configure:2574: found /usr/bin/g++
    configure:2585: result: g++
    configure:2616: checking for C++ compiler version
    configure:2623: g++ --version >&5
    g++ (GCC) 4.3.0 20080305 (alpha-testing) 1
    Copyright (C) 2008 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions. There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    configure:2626: $? = 0
    configure:2633: g++ -v >&5
    Using built-in specs.
    Target: i686-pc-cygwin
    Configured with: /gnu/gcc/release/gcc4-4.3.0-1/src/gcc-4.3.0/configure --srcdir=/gnu/gcc/release/gcc4-4.3.0-1/src/gcc-4.3.0 --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --libexecdir=/usr/sbin --localstatedir=/var --sysconfdir=/etc --datadir=/usr/share --infodir=/usr/share/info --mandir=/usr/share/man -v --with-gmp=/usr --with-mpfr=/usr --enable-bootstrap --enable-version-specific-runtime-libs --with-slibdir=/usr/bin --libexecdir=/usr/lib --enable-static --enable-shared --enable-shared-libgcc --enable-__cxa_atexit --with-gnu-ld --with-gnu-as --with-dwarf2 --disable-sjlj-exceptions --enable-languages=ada,c,c++,fortran,java,objc,obj-c++ --disable-symvers --enable-libjava
    Thread model: single
    gcc version 4.3.0 20080305 (alpha-testing) 1 (GCC)
    configure:2636: $? = 0
    configure:2643: g++ -V >&5
    g++: '-V' option must have argument
    configure:2646: $? = 1
    configure:2669: checking for C++ compiler default output file name
    configure:2696: g++ conftest.cpp >&5
    configure:2699: $? = 1
    configure:2737: result:
    configure: failed program was:
    | /* confdefs.h. */
    | #define PACKAGE_NAME ""
    | #define PACKAGE_TARNAME ""
    | #define PACKAGE_VERSION ""
    | #define PACKAGE_STRING ""
    | #define PACKAGE_BUGREPORT ""
    | #define MAJOR_VERSION 3
    | #define MINOR_VERSION 1
    | #define PATCH_VERSION 0
    | #define PACKAGE "getfem++"
    | #define VERSION "3.1"
    | /* end confdefs.h. */
    | int
    | main ()
    | return 0;
    configure:2744: error: C++ compiler cannot create executables
    See `config.log' for more details.
    ## Cache variables. ##
    ac_cv_env_CCC_set=
    ac_cv_env_CCC_value=
    ac_cv_env_CC_set=
    ac_cv_env_CC_value=
    ac_cv_env_CFLAGS_set=
    ac_cv_env_CFLAGS_value=
    ac_cv_env_CPPFLAGS_set=
    ac_cv_env_CPPFLAGS_value=
    ac_cv_env_CPP_set=
    ac_cv_env_CPP_value=
    ac_cv_env_CXXCPP_set=
    ac_cv_env_CXXCPP_value=
    ac_cv_env_CXXFLAGS_set=
    ac_cv_env_CXXFLAGS_value=
    ac_cv_env_CXX_set=
    ac_cv_env_CXX_value=
    ac_cv_env_F77_set=
    ac_cv_env_F77_value=
    ac_cv_env_FCFLAGS_set=
    ac_cv_env_FCFLAGS_value=
    ac_cv_env_FC_set=
    ac_cv_env_FC_value=
    ac_cv_env_FFLAGS_set=
    ac_cv_env_FFLAGS_value=
    ac_cv_env_LDFLAGS_set=
    ac_cv_env_LDFLAGS_value=
    ac_cv_env_LIBS_set=
    ac_cv_env_LIBS_value=
    ac_cv_env_PYTHON_VERSION_set=
    ac_cv_env_PYTHON_VERSION_value=
    ac_cv_env_build_alias_set=
    ac_cv_env_build_alias_value=
    ac_cv_env_host_alias_set=
    ac_cv_env_host_alias_value=
    ac_cv_env_target_alias_set=
    ac_cv_env_target_alias_value=
    ac_cv_path_install='/usr/bin/install -c'
    ac_cv_path_mkdir=/usr/bin/mkdir
    ac_cv_prog_AWK=gawk
    ac_cv_prog_ac_ct_CXX=g++
    ac_cv_prog_make_make_set=yes
    ## Output variables. ##
    ACLOCAL='${SHELL} /home/HP_Propriétaire/getfem++-3.1/missing --run aclocal-1.10'
    AMDEPBACKSLASH=''
    AMDEP_FALSE=''
    AMDEP_TRUE=''
    AMTAR='${SHELL} /home/HP_Propriétaire/getfem++-3.1/missing --run tar'
    AR=''
    AUTOCONF='${SHELL} /home/HP_Propriétaire/getfem++-3.1/missing --run autoconf'
    AUTOHEADER='${SHELL} /home/HP_Propriétaire/getfem++-3.1/missing --run autoheader'
    AUTOMAKE='${SHELL} /home/HP_Propriétaire/getfem++-3.1/missing --run automake-1.10'
    AWK='gawk'
    BLAS_LIBS=''
    BUILDDATE=''
    BUILDER=''
    BUILDMEXRPC_FALSE=''
    BUILDMEXRPC_TRUE=''
    BUILDMEX_FALSE=''
    BUILDMEX_TRUE=''
    BUILDPYTHON_FALSE=''
    BUILDPYTHON_TRUE=''
    CC=''
    CCDEPMODE=''
    CFLAGS=''
    CONFIGURE_ARGS=''
    CPP=''
    CPPFLAGS=''
    CXX='g++'
    CXXCPP=''
    CXXDEPMODE=''
    CXXFLAGS=''
    CYGPATH_W='cygpath -w'
    DEFS=''
    DEPDIR=''
    DISTCLEANMESH=''
    ECHO='echo'
    ECHO_C=''
    ECHO_N='-n'
    ECHO_T=''
    EGREP=''
    EXEEXT=''
    F77=''
    FC=''
    FCFLAGS=''
    FCLIBS=''
    FFLAGS=''
    GETFEM_SERVER=''
    GFSERVERFLAGS=''
    GREP=''
    INSTALL_DATA='${INSTALL} -m 644'
    INSTALL_PROGRAM='${INSTALL}'
    INSTALL_SCRIPT='${INSTALL}'
    INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
    LDFLAGS=''
    LIBOBJS=''
    LIBS=''
    LIBTOOL=''
    LIBTOOL_DEPS=''
    LIBTOOL_VERSION_INFO=''
    LN_S=''
    LTLIBOBJS=''
    MAKEINFO='${SHELL} /home/HP_Propriétaire/getfem++-3.1/missing --run makeinfo'
    MATLAB_COM_EXT=''
    MATLAB_INC_DIR=''
    MATLAB_RELEASE=''
    MATLAB_ROOT=''
    MEX=''
    MPI_CLAGS=''
    MPI_LIBS=''
    MUMPS_CFLAGS=''
    MUMPS_LIBS=''
    OBJEXT=''
    PACKAGE='getfem++'
    PACKAGE_BUGREPORT=''
    PACKAGE_NAME=''
    PACKAGE_STRING=''
    PACKAGE_TARNAME=''
    PACKAGE_VERSION=''
    PATH_SEPARATOR=':'
    PYTHON=''
    PYTHON_CPPFLAGS=''
    PYTHON_EXEC_PREFIX=''
    PYTHON_EXTRA_LDFLAGS=''
    PYTHON_EXTRA_LIBS=''
    PYTHON_LDFLAGS=''
    PYTHON_PLATFORM=''
    PYTHON_PREFIX=''
    PYTHON_SITE_PKG=''
    PYTHON_VERSION=''
    QHULL_FALSE=''
    QHULL_TRUE=''
    RANLIB=''
    RPC_INC_DIR=''
    RPC_LIB=''
    SED=''
    SET_MAKE=''
    SHELL='/bin/sh'
    STDCPP_STATICLIBS=''
    STRIP=''
    SUPERLU_CPPFLAGS=''
    SUPLDFLAGS=''
    TOOLBOXDIR=''
    USEBLASLITE_FALSE=''
    USEBLASLITE_TRUE=''
    USE_MINGW_MEX_FALSE=''
    USE_MINGW_MEX_TRUE=''
    VERSION='3.1'
    ac_ct_CC=''
    ac_ct_CXX='g++'
    ac_ct_F77=''
    ac_ct_FC=''
    am__fastdepCC_FALSE=''
    am__fastdepCC_TRUE=''
    am__fastdepCXX_FALSE=''
    am__fastdepCXX_TRUE=''
    am__include=''
    am__isrc=''
    am__leading_dot='.'
    am__quote=''
    am__tar='${AMTAR} chof - "$$tardir"'
    am__untar='${AMTAR} xf -'
    bindir='${exec_prefix}/bin'
    build=''
    build_alias=''
    build_cpu=''
    build_os=''
    build_vendor=''
    datadir='${datarootdir}'
    datarootdir='${prefix}/share'
    docdir='${datarootdir}/doc/${PACKAGE}'
    dvidir='${docdir}'
    exec_prefix='NONE'
    host=''
    host_alias=''
    host_cpu=''
    host_os=''
    host_vendor=''
    htmldir='${docdir}'
    includedir='${prefix}/include'
    infodir='${datarootdir}/info'
    install_sh='$(SHELL) /home/HP_Propriétaire/getfem++-3.1/install-sh'
    libdir='${exec_prefix}/lib'
    libexecdir='${exec_prefix}/libexec'
    localedir='${datarootdir}/locale'
    localstatedir='${prefix}/var'
    mandir='${datarootdir}/man'
    mkdir_p='/usr/bin/mkdir -p'
    oldincludedir='/usr/include'
    pdfdir='${docdir}'
    pkgpyexecdir=''
    pkgpythondir=''
    prefix='NONE'
    program_transform_name='s,x,x,'
    psdir='${docdir}'
    pyexecdir=''
    pythondir=''
    sbindir='${exec_prefix}/sbin'
    sharedstatedir='${prefix}/com'
    sysconfdir='${prefix}/etc'
    target_alias=''
    ## confdefs.h. ##
    configure: exit 77
    Merci d'utiliser la balise "code" dans ce genre de cas.
    yoda1234.
    Dernière modification par yoda1234 ; 29/10/2008 à 06h21.
    Towl
    Re : cygwin C++ compiler
    Tu n'as pas du installer g++ qui correspond au compilateur c++
    The only limiting factor of the Linux operating system, is his user. - Linus Torvalds
    inviteefb83c40
    Merci pour ta réponse rapide. Suppossons que ça soit ça, comment est ce que je fais pour déterminer le g++ qui correspond à mon compilateur c++ ?
  1. Problème avec Cygwin
    Par inviteb187782c dans le forum Logiciel - Software - Open Source
    Dernier message: 16/02/2008, 20h31
  2. Après installation de Cygwin
    Par invite73751fa5 dans le forum Logiciel - Software - Open Source
    Dernier message: 02/02/2006, 17h28
  3. cygwin en mode comande ?
    Par invite0fc58940 dans le forum Logiciel - Software - Open Source
    Dernier message: 03/02/2005, 13h59
  4. Probleme Avec Cygwin... et la compilation...
    Par invite3f2e2a6f dans le forum Logiciel - Software - Open Source
    Réponses: 18
    Dernier message: 09/10/2004, 15h56
  5. Cygwin-Unix-Utiliser GCC
    Par JP dans le forum Logiciel - Software - Open Source
    Dernier message: 28/10/2003, 19h22
