javascript : script qui bug !!!!
    invitee17aeca5
    Exclamation javascript : script qui bug !!!!
    slt
    voila ,j'ai bricoler ce petit script en js (d'apres un prog en Qb) mais il refuse de marcher !!! et comme je 'débute' bienévidement ,je ne trouve pas la panne ^^ pouriez vous essayer de le débuger ?
    merci d'avence ! Tix.
    Code:
    <html>
    <head>
    <script language="Javascript">
    val x3d
    val y3d
    val z3d
    val rotx
    val roty
    val rotz
    val rx
    val ry
    val rz
    val idr
    val depth = 400
    val zoom = 300
    val pA
    val pB
    val pC
    val pD
    val pE
    val pF
    val pG
    val pH
    function calc3d(x3d, y3d, z3d, rotx, roty, rotz,idr){
    	x2 = (x3d * Math.cos(rotz)) - (y3d * Math.sin(rotz))
    	y2 = (x3d * Math.sin(rotz)) + (y3d * Math.cos(rotz))
    	x3 = (x2 * Math.cos(roty)) - (z3d* Math.sin(roty))
    	z2 = (x2 * Math.sin(roty)) + (z3d * Math.cos(roty))
    	y3 = (y2 *  Math.cos(rotx)) - (z2 * Math.sin(rotx))
    	z3 = (y2 * Math.sin(rotx)) + (z2 * Math.cos(rotx))
    	x2d = zoom * (x3 / (z3 + depth)) + 160
    	y2d = zoom * (y3 / (z3 + depth)) + 100
    	x2d = x2d
    	y2d = y2d
    		document.getElementById[idr].style.top=xm
        		document.getElementById[idr].style.left=ym
    function cube(){
    rx = rx++
    ry = ry++
    rz = rz++
    calc3d( 10, 10, 10, rx, ry, rz,"pA")
    calc3d( -10, 10, 10, rx, ry,rz,"pB")
    calc3d( 10, -10, 10, rx, ry, rz,"pC")
    calc3d( 10, 10, -10, rx, ry, rz,"pD")
    calc3d( -10, -10, 10, rx, ry, rz,"pE")
    calc3d( -10, -10, -10, rx, ry, rz,"pF")
    calc3d( 10, -10, -10, rx, ry, rz,"pG")
    calc3d( -10, 10, -10, rx, ry, rz,"pH")
    setTimeout('cube()',10)
    </script>
    </head>
    <body onload='cube()'>
    <div id="pA" style="{position:absolute}">o</div>
    <div id="pB" style="{position:absolute}">o</div>
    <div id="pC" style="{position:absolute}">o</div>
    <div id="pD" style="{position:absolute}">o</div>
    <div id="pE" style="{position:absolute}">o</div>
    <div id="pF" style="{position:absolute}">o</div>
    <div id="pG" style="{position:absolute}">o</div>
    <div id="pH" style="{position:absolute}">o</div>
    </body>
    </html>
    zoup1
    Re : javascript : script qui bug !!!!
    Bon, c'est bien parceque débugguer me détends et que j'ai besoin de me détendre. mais quand même, il y a la dedans des erreurs qui sont de pur inattention. Comme par exemple l'emploie de val au lieu de var.
    Bon je livre un truc qui fonctionne (au moins chez moi...).
    Code PHP:
    <html>
    head>
    var
    rx=0
    var ry=5
    var rz=0
    var depth 100
    var zoom 400
    var i=20;
    function
    calc3d(x3dy3dz3drotxrotyrotz,idr){
    x2 = (x3d Math.cos(rotz)) - (y3d Math.sin(rotz))
    y2 = (x3d Math.sin(rotz)) + (y3d Math.cos(rotz))
    x3 = (x2 Math.cos(roty)) - (z3dMath.sin(roty))
    z2 = (x2 Math.sin(roty)) + (z3d Math.cos(roty))
    y3 = (y2 *  Math.cos(rotx)) - (z2 Math.sin(rotx))
    z3 = (y2 Math.sin(rotx)) + (z2 Math.cos(rotx))
    x2d zoom * (x3 / (z3 depth)) + 160
        y2d
    zoom * (y3 / (z3 depth)) + 100
        x2d
    x2d
        y2d
    y2d
        document
    .getElementById(idr).style.top=x2d
            document
    .getElementById(idr).style.left=y2d
    function
    cube(){
    rx += 0.2;
    ry += 0;
    rz += 0;
    calc3d101010rxryrz,"pA")
    calc3d( -101010rxry,rz,"pB")
    calc3d10, -1010rxryrz,"pC")
    calc3d1010, -10rxryrz,"pD")
    calc3d( -10, -1010rxryrz,"pE")
    calc3d( -10, -10, -10rxryrz,"pF")
    calc3d10, -10, -10rxryrz,"pG")
    calc3d( -1010, -10rxryrz,"pH")
    function
    moncube(){
        if (
    i>0) {
    i--;
    cube();
    setTimeout('moncube()',100);
    </script>
    </head>
    <body onload='moncube()'>
    </body>
    </html>
    J'ai fait un peu le nettoyage en supprimant ce qui ne servait pas à grand chose (à rien quoi).
    J'ai changé les getElementbyId là encore il y avait des xm, ym qui n'ont pas de sens...
    Sur le setTimeout c'est quelque chose que je n'avais jamais utilisé donc j'ai bricolé un peu, mais je ne sais pas si le truc d'origine fonctionne ou pas.
    Il faut utiliser la console JavaScript pour debugguer. Cela permet au moins de localiser les problèmes. Ensuite il y a des debbogueur Javascript, par exemple firefox possède une extension qui permet de faire du debogguage. C'est vraiment très utile.
    zoup1
    Ha j'oubliais un truc... à priori getElementById ne fonctionne pas avec internet explorer.
    donc si tu veux que cela tourne avec IE... il faut changer la façon d'identifier l'élément en question...
    Je te donne une idée, tu me donnes une idée, nous avons chacun deux idées.
    zoup1
    Bon, finalement j'ai testé avec IE6 et cela fonctionne aussi...
    ??? Mais alors pourquoi mon vieux script machin chose ne fonctionne pas sous IE6 ???
    Bizarre..
    invitee17aeca5
    merci zoup1 ,ca ne fonctionne toujours pas encor chez moi mais je vais pouvoir continuer sur de bonnes bases ...
    merci infiniment pour la correction ,(ym et xm servait à l'origine de point de repere ....et les val/var ,c'est impardonable ,il était tard quoi ^^j'ai honte hu hu hu....)
    quel résulta obtien tu ???
    merci, @+++++ Tix.
    invitee17aeca5
    ca marche ^^ ,et le script est copyrighté Transisterix© hu hu hu ... lol jdcn
    invitee17aeca5
    je vous fait suivre l'avancement ...(jai rien d'autre à faire ...)
    --> pour que ta sub tourne indéfiniment ,j'ai remplacer ta fonction :
    Code:
    function moncube(){
        if (i>0) {
            i--;
            cube();
    par ca :
    Code:
    function moncube(){
        if (i>0) {
            i;
            cube();
    ca marche sous ie ...
    encor merci ,@++ Tix.
    invitee17aeca5
    encor une petite question :
    je souhaite remplacer les "o" par des images ,seulement ,comme on parle ici de 3D et que si des images s'affiche devan de images sensée etre plus proche ,ca ne marche pas ... est il possible de modifier l'ordre d'affichage des images ? merci ^^
    invitee17aeca5
    bon ,et bien ,ouis-ce que j'y suis ,si vous connaissez la réponses à ca :
    pour simplifier le script ,j'aimerai le mettre dans un fichier "*.js"
    est-ce possible ?,comment fair ?(comment ca marche ^^)
    merci encor ...
    @++ Tix.
    invitee17aeca5
    du coup ,pour le "*.js" ,j'ai trouvé tt seul ^^ ,et j'ai fé une pyramide qui tourne ....(lol)
    si ca intéresse qqun^,juste histoire que je ne discute pas tout seul quoi
    @++ Tix.
    invite4a7ad6a4
    Désolé je taillerais bien la bavette sur js, mais je manque de temps (y en a qui sont pas encore en vacances...).
    Continues et eventuellement, mets ton truc en ligne qu'on puisse voir ce que çà donne (en plus c'est un bon exercice ).
    Si la 3D sur Internet t'intéresse, renseignes toi sur VRML, c'est pas trop compliqué et tu peux obtenir de bons résultats.
    @+ et bon courage
    zoup1
    Pour faire passer les truc devant il y a une propriété z-index qui permet de situer les plans les uns par rapport aux autres. Cela devrait te permettre de travailler avec les images. Par contre si tu veux pouvoir les déformer c'est une autre histoire...
    Pour mettre les trucs dans un fichier .js c'est dans les première pages des tutorials généralement.
    Je te mets quelques un des liens que j'utilise pour me documenter.
    Pour une vue rapide...
    http://www.w3schools.com/
    Pour les références...
    Pour le CSS...
    http://www.yoyodesign.org/doc/w3c/cs...r.html#minitoc
    Pour le DOM
    http://www.mozilla.org/docs/dom/reference/links.html
    invitee17aeca5
    merci à vous ,
    invitee17aeca5
    voila le lien qui mene au résulta :
    --> le cube
    vla ,ca marche sous IE
    qu'en penseriez vous si je le faisait rebondir en meme temps sur les bords de l'écrans ? ^^ (hu hu hu...,j'attaque....)
    invitee17aeca5
    améliorationn°2 : ajout d'icones sur le dessu pour changer le zoom ...
    invitee17aeca5
    à propos de z-index ,est-ce utilisable en dhtml ?(dans notre script quoi ^^) ,j'ai essayé mais je ne suis pas sur de la syntaxe :
    document.getElementById(idr).s tyle.z-index=couche
    ets-ce cela ? merci ,
    invitee17aeca5
    apparement ,la sintaxe ne comporte pas de tiret ,ca marche en partie ,je n'arrive pas à utiliser zindex comme je voudrais ,il me bloque le script !!!! une idée ?
    merci ^^ (squate le fil à mesure ,dsl)
    invitee17aeca5
    tenez ,pour la st valentin ,offrez un lien à votre partenair(e) :
    joli coeur
    lol
    en fait ,je savais pas quoi fair alors j'ai fair une surprise à mlle Tix. ,et comme je trouvais ca jouli ,j'en montre un morceau ,défois que ca puisse servir ^^
    Enjoy
    Tix.
  1. [C]programme graphique qui Bug
    Par invitee17aeca5 dans le forum Logiciel - Software - Open Source
    Dernier message: 09/11/2006, 07h48
  2. Récupérer des variables (HTTP REQUEST, Post, ...) à partir d'un script JAVASCRIPT
    Par invite843f61d9 dans le forum Internet - Réseau - Sécurité générale
    Dernier message: 01/08/2005, 14h31
  3. thermocouple qui bug
    Par petitours dans le forum Électronique
    Dernier message: 11/04/2005, 11h22
  4. Qui connait le langage script LUA???
    Par invite1796a48f dans le forum Logiciel - Software - Open Source
    Dernier message: 16/07/2004, 14h35
