[linux] video en niveau de gris a la lecture
    Ryback08
    bonsoir tout le monde
    j'ai un petit probleme avec ma mandrake 10.0:
    quand je lit des video ( mpeg, Xvid, DivX....) avec n'importe quel player ( Xine , Totem ) les video son en niveau de gris
    pensant que ca venait du codec, j'ai installer le codec Xvid ( mais ca vient pas de ca, vu que ca le fait aussi au niveau d'un fichier mpeg )
    ma config :
    Asus A7N8X deluxe ( donc, nForce2 )
    GF GForce FX5600 ( driver nvidia installer, ca pourrait venir de ca )
    environement KDE
    fichier /etc/X11/XF86Config-4
    [code:1:22d79a8bdf]# File generated by XFdrake.
    # Refer to the XF86Config man page for details about the format of
    # this file.
    Section "Files"
    # Multiple FontPath entries are allowed (they are concatenated together)
    # By default, Mandrake 6.0 and later now use a font server independent of
    # the X server to render fonts.
    FontPath "unix/:-1"
    EndSection
    Section "ServerFlags"
    #DontZap # disable <Crtl><Alt><BS& gt; (server abort)
    #DontZoom # disable <Crtl><Alt><KP_ +>/<KP_-> (resolution switching)
    AllowMouseOpenFail # allows the server to start up even if the mouse doesn't work
    EndSection
    Section "Module"
    Load "dbe" # Double-Buffering Extension
    Load "v4l" # Video for Linux
    Load "extmod"
    Load "type1"
    Load "freetype"
    Load "glx" # 3D layer
    EndSection
    Section "InputDevice"
    Identifier "Keyboard1"
    Driver "Keyboard"
    Option "XkbModel" "pc105"
    Option "XkbLayout" "fr"
    Option "XkbOptions" ""
    EndSection
    Identifier "Mouse1"
    Driver "mouse"
    Option "Protocol" "ExplorerPS/2"
    Option "Device" "/dev/mouse"
    Option "ZAxisMapping" "6 7"
    EndSection
    Section "Monitor"
    Identifier "monitor1"
    VendorName "Plug'n Play"
    ModelName "Hyundai Deluxscan 14S"
    HorizSync 30-48
    VertRefresh 50-120
    # Sony Vaio C1(X,XS,VE,VN)?
    # 1024x480 @ 85.6 Hz, 48 kHz hsync
    ModeLine "1024x480" 65.00 1024 1032 1176 1344 480 488 494 563 -hsync -vsync
    # TV fullscreen mode or DVD fullscreen output.
    # 768x576 @ 79 Hz, 50 kHz hsync
    ModeLine "768x576" 50.00 768 832 846 1000 576 590 595 630
    # 768x576 @ 100 Hz, 61.6 kHz hsync
    ModeLine "768x576" 63.07 768 800 960 1024 576 578 590 616
    EndSection
    Section "Device"
    Identifier "device1"
    VendorName "NVIDIA Corporation"
    BoardName "NVIDIA GeForce FX (generic)"
    Driver "nvidia"
    Option "DPMS"
    EndSection
    Section "Screen"
    Identifier "screen1"
    Device "device1"
    Monitor "monitor1"
    DefaultColorDepth 24
    Subsection "Display"
    Depth 8
    Virtual 1024 768
    EndSubsection
    Depth 15
    Virtual 1024 768
    EndSubsection
    Depth 16
    Virtual 1024 768
    EndSubsection
    Depth 24
    Virtual 1024 768
    EndSubsection
    EndSection
    Section "ServerLayout"
    Identifier "layout1"
    InputDevice "Keyboard1" "CoreKeyboard"
    InputDevice "Mouse1" "CorePointer"
    Screen "screen1"
    EndSection[/code:1:22d79a8bdf]
    invite504c296f
    Essaye déjà avec un autre logiciel de lecture vidéo comme Mplayer, car Totem s'appuie sur Xine, donc c'est du pareil au même. Si ca venait de ton driver vidéo, tu n'auras pas de couleurs non plus sur ton bureau.
    Ryback08
    oki, je vous dirait ca le week end ( internat oblige )
    pour info, ca le fait aussi pendant la lecture des DVD
    si ca vient pas des driver graphique, alors, c'est logiciel..... mais d'ou
    JP
    Salut tout le monde,
    J'ai le même problème que toi avec la mandrake 10.
    Je vais installer Mplayer, je vous tiens au courant.
    Pour info j'ai un geforce FX 5200
    JP
    Toujours le meme probleme video en noir et blanc
    Ryback08
    lut, apparament, le probleme vient du lecteur "TOTEM"
    en effet... apres vous avoir ecouter, j'installe mplayer... je lit une video : la couleur est la
    ensuite, je lit la meme video avec xine : la couleur es ttoujours la
    je fini par lire la meme avec totem le niveau de gris est la
    et j'ai beau reprendre mpllayer ou xine, la video est toujours en N&B
    bref, pour avoir la couleur, il faut rebooter... et ensuite, ne sourtout pas lancer totem ( ca tombe bien, de toute facon, j'aimait pas ce player )
    reste plus qu'a totem
  1. lecture de fichier video
    Par invited6300e9e dans le forum Matériel - Hardware
    Dernier message: 29/12/2006, 00h24
  2. Lecture vidéo
    Par Lio22 dans le forum Internet - Réseau - Sécurité générale
    Dernier message: 23/10/2005, 05h28
  3. Utilisation des partions Windows avec Linux en lecture et en écriture
    Par Laurentg001 dans le forum Logiciel - Software - Open Source
    Dernier message: 06/04/2005, 11h48
  4. Pbl: Lecture CD Audio sous Linux
    Par invite006f52e9 dans le forum Logiciel - Software - Open Source
    Dernier message: 23/01/2005, 13h24
  5. lecture fichier video
    Par invitebc9d03fc dans le forum Logiciel - Software - Open Source
    Dernier message: 24/09/2004, 18h45
