aide au choix d'un processeur
    invite4d0cffa7
    Bonjour a tous,
    Voila cela fait un moment que je me tâte pour changer le processeur de mon pc
    Via CPU Z
    AMD Athlon II X2 250 @ 2992.86 MHz
    Dump [aqh7ir] - Submitted by VINC-ELE - 2017-10-20 15:14:42
    Processor (CPU)
    CPU Name AMD Athlon™ II X2 250 Processor
    Threading 1 CPU - 2 Core - 2 Threads
    Frequency 2992.86 MHz (15 * 199.52 MHz) - Uncore: 1995.2 MHz
    Multiplier Current: 15 / Min: 4 / Max: 15
    Architecture Regor / Stepping: DA-C3 / Technology: 45 nm
    CPUID / Ext. F.6.3 / 10.6
    IA Extensions MMX(+), 3DNow!(+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
    Caches L1D : 64 KB / L2 : 1024 KB
    Caches Assoc. L1D : 2-way / L2 : 16-way
    TDP / Vcore 59.95 Watts / 1.44 Volts
    Temperature 33.3 °C / 92 °F
    Type Retail (Stock Frequency : 3000 MHz)
    Cores Frequencies #00: 2992.86 MHz  #01: 2992.86 MHz 
    Motherboard
    Model ASRock M3A770DE
    Socket Socket AM3 (938)
    North Bridge AMD 770 rev 00
    South Bridge AMD SB700 rev 00
    BIOS American Megatrends Inc. P1.60 (05/20/2010)
    Memory (RAM)
    Total Size 16384 MB
    Type Dual Channel (128 bit) DDR3-SDRAM
    Frequency 665.1 MHz - Ratio 3:10
    Timings 9-12-12-30-33-2 (tCAS-tRC-tRP-tRAS-tCS-tCR)
    Slot #1 Module Kingston 8192 MB (DDR3-1600) - P/N: 99U5403-160.A00LF
    Slot #2 Module Kingston 8192 MB (DDR3-1600) - P/N: 99U5403-160.A00LF
    Graphic Card (GPU)
    GPU Type NVIDIA GeForce 210 (GT218)
    GPU Brand 0x0000 (0x0000)
    Storage (HDD/SSD)
    Model #1 TOSHIBA DT01ABA100
    Capacity #1 1000 GB
    Model #2 HDD 5
    Capacity #2 100 GB
    Model #3 HDD 6
    Capacity #3 160 GB
    Model #4 HDD 8
    Capacity #4 1000 GB
    Display
    Screen #1 Idek Iiyama PL2280H (IVM5620)
    Screen #1 Spec 21.7 inches (55.1 cm) / 1920 x 1080 pixels @ 55-76 Hz
    Miscellaneous
    Windows Version Microsoft Windows 10 (10.0) Professional 64-bit
    Windows Subver. (Build 15063)
    CPU-Z Version 1.81.0 (64 bit)
    http://www.asrock.com/MB/AMD/A790GX128M/index.asp#CPU
    Voici se que j'ai trouvé qui correspondrais a ma carte mère et mon bios P1.60
    sur la liste j'en est trouvé qui correspondrait a la version de mon bios
    Après avoir vérifier je pense prendre celui qui se trouve sur la sixième lignes en partant du haut de la page pas trop de consommation je pense
    que se serai pas mal
    voici le lien de se que j'aimerais installer
    https://fr.aliexpress.com/store/prod...800180409.html
    Si une âme charitable pouvais juste me guider ou me conseiller mieux ou me confirmer que je ne me suis pas tromper
    Vinc49
    bisou10
    Re : aide au choix d'un processeur
    Bon CPU, 2,5x plus puissant en gros.
    Tu passes de 60W TDP a 95W, tu vas consommer un peu plus (si ton alim est trés juste ca peut jouer, sinon ca devrait passer).
    masterclassic
    Je remarque dans la page de vente:
    Condition d' article: D' occasion
    Qu' est-ce qu' on pourrait attendre comme fiabilité ou durée de vie du processeur?
    invite4d0cffa7
    Merci de ta réponse
    Pour le lien que j'ai mie sur mon mp
    J'ai vue un peut tard que se n'était pas la bonne carte mère
    Voici la mienne:
    http://www.asrock.com/mb/amd/m3a770de/
    Ce que je n'arrive pas a comprendre c'est que aucun CPU ne correspond a la version de mon BIOS 1.60
    J'aimerai si possible éviter de flasher le BIOS (un peut peur de cette manipulation !!!)
    en se qui concerne l'alimentation voici une photo:
    Nom : WP_20171021_001.jpg
Affichages : 161
Taille : 280,7 Ko
    350Watt
    Pour la durée de vie du CPU je ne ses pas que dire ?
    A part en trouvé un neuf se qui n'est pas chose aisée
    Je regarderai sa de plus près
    Cordialement Vinc49
    masterclassic
    Il est vrai que les pannes des processeurs sont assez rares. Les plus fréquentes doivent être celles de l' alimentation et des lecteurs cd/dvd. Puis, parfois les mémoires vives, plus rarement les cartes mères. Les processeurs sont plus résistants, parait-il. Si le ventilateur crève, le processeur s' arrête et il a de bonnes chances de survie. Je mets à part le clavier, surtout s' il a l' habitude de boire des tasses de café
    invite4d0cffa7
    Bonjour a tous,
    Merci pour la précision sur la duré de vie d'un processeur masterclassic
    Autre question qui me vient a l'esprit
    Y'aurais t'il une compatibilité entre la compatibilité des CPU de ses deux carte mère
    http://www.asrock.com/mb/amd/m3a770de/#CPU et celle ci http://www.asrock.com/MB/AMD/A790GX128M/index.asp#CPU
    ci ces le cas je pourrais prendre le CPU de l'un et l'installer sur l'autre carte mère et vise et versa
    Enfin ci cela est possible
    Merci de m'aider a élucidé ma question
    Cordialement Vinc49
    masterclassic
    A propos des versions BIOS: le BIOS initial de ces cartes est numéroté 1. Chaque mouvelle version prend un nouveau numéro comme 1.10, 1.20 etc. Un processeur supporté à partir de la version 1.20 veut dire qu' il fonctionne sous 1.20, 1.40, 1.50, 1.60 aussi. Mais un processeur supporté à partir de 1.50 fonctionnera avec 1.60 mais pas avec disons 1.20 ou 1 initial. Dans ce cas il faudra "firmware update".
    Avec les Athlons II X2 250 je vois deux versions: revision C3 et revision C2. Le C3 (plus récent) nécessite un BIOS P1.50. Le C2 nécessite P1.20. Une carte à 1.60 pourra recevoir les deux. Je pense que c' est le cas de la ASRock M3A770DE.
    invite4d0cffa7
    Mais quand est il de se qui on la révision E 0
    serais t'il possible qu'un de ses processeurs, supporte une carte a 1.60 version C 3 ou C 2 en se basant sur une carte M 3 A 770 D E http://www.asrock.com/mb/amd/m3a770de/#CPU
    masterclassic
    Citation Envoyé par vinc49 Voir le message
    Ce n' est pas le processeur qui suppore la carte, mais l' inverse. La version firmware 1.60 couvre ce que supportent les versions 1.50 et avant, jusqu' à version 1.
    La revision E0 concerne non pas les Athlon II mais les Phenom II X6 et certains X4.
    Le processeur Phenom II X6 dans la photo du link d' aliexpress est celui de la 8ème ligne du tableau de ton dernier lien ci-dessus, et il doit être très probablement une revision E0 (je lis PH-E0 dans l'image de cpuz). Dans ce cas il doit être supporté par la M3A770DE à P1.60.
    Je pense que je ne me trompe pas (je ne suis pas guru de hardware). Est-ce que quelqu'un des experts peut confirmer?
    invite4d0cffa7
    Citation Envoyé par masterclassic Voir le message
    Un grand merci pour toutes ses précisions
    Et du temps consacré
    Comme dit masterclassic
    J'attendrais qu'un experts veuille bien confirmer
    PS:
    oui tout à fait c'est la carte mère qui supporte le processeur erreur de ma part
    Cordialement vinc49
    invite4d0cffa7
    Bonsoir a tous,
    J'ai fini par acheter ce processeur https://fr.aliexpress.com/store/prod...2db79a7fbce138
    petit soucis quand je regarde avec cpu z nouveau processeur.jpg ou msconfig il me dit qu'il n'y a que deux cœurs
    donc j'ai fini par alimenter ma carte mère avec 4 pin au lieu de deux se qui na rien changer
    a gauche des cette photo qui suit se que je devrai avoir a droite se que j'ai
    voici des photos de mon bios
    Merci de m'aider
    Cordialement vinc
    invite4d0cffa7
    Bonsoir a tous,
    Problème réglée après mainte manipulation
    J'ai fini par démarrer en mode sans échec
    Appuyer sur Windows+R Taper MSCONFIG/démarrer/option avancées cocher nombre de processeurs
    cocher rendre permanents tous les paramètres de démarrage
    Appliquer OK Puis redémarrer
    Et voila le tour est jouet
    Merci a tous
    Cordialement Vinc49
  1. [Autre] Choix entre un microcontrôleur ou processeur
    Par invite352bbdac dans le forum Électronique
    Dernier message: 22/12/2015, 20h34
  2. Choix de techno de processeur selon applications
    Par invitea2e9c011 dans le forum Matériel - Hardware
    Dernier message: 13/01/2015, 20h31
  3. besoin de conseil choix ordinateur, processeur....!!!
    Par invite30aabd10 dans le forum Matériel - Hardware
    Dernier message: 09/06/2009, 23h50
  4. choix de processeur la suite
    Par invite7cbbc409 dans le forum Matériel - Hardware
    Dernier message: 16/01/2003, 12h46
  5. choix et compatibilité de processeur
    Dernier message: 13/01/2003, 07h51
