  • Login:
+ Répondre à la discussion
coefficient de dilatation des aluminiums 514.0 et 514.2
  1. robibaggio
    Date d'inscription
    avril 2010
    Messages
    2
    quelqu'un peut-il me dire quelles sont les differences principales entre ces 2 materiaux ?
    que signifie le suffixe ".0" ou/et ".2" ?
    ce qui m'interesse la plus dans cette histoire c'est leur coefficient de dilatation thermique.
    merci pour votre aide.
    • Publicité
  2. CLAUUU64
    Date d'inscription
    avril 2010
    Messages
    16
    Re : coefficient de dilatation des aluminiums 514.0 et 514.2
    J'ai trouvé ca pour expliquer les digits:
    The first digit indicates the alloy group according to the major alloying element:
    1xx.x aluminum, 99.0% minimum;
    2xx.x copper (4%...4.6%);
    3xx.x silicon (5%...17%) with added copper and/or magnesium;
    4xx.x silicon (5%...12%);
    5xx.x magnesium (4%...10%);
    7xx.x zinc (6.2%...7.5%);
    8xx.x tin;
    9xx.x others.
    The second two digits identify aluminum alloy or indicate the alloy purity.
    In the alloys of the 1xx.x series the second two digits indicate the level of purity of the alloy – they are the same as the two digits to the right of the decimal point in the minimum concentration of aluminum (in percents): 150.0 means minimum 99.50% of aluminum in the alloy, 120.1 means minimum 99.20% of aluminum in the alloy.
    In all other groups of aluminum alloys (2xx.x through 9xx.x) the second two digits signify different alloys in the group.
    The last digit indicates the product form: casting (designated by “0”) or ingot (designated by “1” or “2” depending on chemical composition limits.)
    A modification of the original alloy or impurity limits is indicated by a serial letter before the numerical designation. The serial letters are assigned in alphabetical order starting with A but omitting I, O, Q, and X (the letter “X” is reserved for experimental alloys).
    Pour la fiche materiaux du 514.0:
    Thermal expansion (20 ºC) : 24.1*10-6 ºCˉ¹
    Voilou, si besoin d'une traduction faut le dire, je le fais sans soucis ^^
    Bonne journée.
    Claude.
  3. Jaunin
    Date d'inscription
    novembre 2006
    Localisation
    Le Muids, Vaud, Suisse
    Âge
    68
    Messages
    7 166
    Bonjour, Robibaggio,
    Encore bienvenu sur le forum de Futura-Sciences.
    Votre désignation 514 représente un Aludur-300 (Al Mg 3) dans un état recuit?
    Jaunin__
  4. robibaggio
    Date d'inscription
    avril 2010
    Messages
    2
    merci à vous 2 pour ces détails.
    concernant le coef de dilatation, j'avais également trouvé cette valeur pour le 514.0 mais malheureusement, pas moyen de mettre la main sur celui du 514.2 !!!!!
    est-ce que l'un d'entre vous a eu plus de chances ?
    merci encore et bon w-e.
  5. Jaunin
    Date d'inscription
    novembre 2006
    Localisation
    Âge
    68
    Messages
    7 166
    Voilà ce que j'ai, si ça peut vous rendre service.
    Jaunin__
    Fichiers attachés
    • Publicité
    • Publicité
Poursuivez votre recherche :
Sur le même thème :
  1. [Blanc] LL HOOVER HNT 514.6 : n'admet pas l'assouplissant.
    Par OBG dans le forum Dépannage
    Dernier message: 25/02/2009, 19h07
  2. [Blanc] PB seche linge Arthur Martin ADC 514 E
    Par Slikus dans le forum Dépannage
    Dernier message: 17/06/2008, 21h17
  3. [Blanc] Panne de froid réfrigérateur whirlpool ARZ 514
    Par gcmomo dans le forum Dépannage
    Dernier message: 13/06/2008, 16h32
  4. [Blanc] Panne seche linge A.M. adc 514 E
    Par nico_2712 dans le forum Dépannage
    Réponses: 23
    Dernier message: 30/01/2008, 09h59
  5. Pb réfrigérateur Whirlpool ARZ 514
    Par hch113 dans le forum Dépannage
    Dernier message: 05/10/2006, 10h28
