Décomposition en curvelet
    faat
    salut,
    J'essaye d'appliquer la décomposition en curvelet pour l'image de huffman,
    Pour cela j'applique un bruit à l'image originale puis je calcul le psnr entre l'image originale et celle débruité.
    Je vous donne le code matlab que j'ai utilisé :
    Code:
    close all; clear all;
    clc
    im = double(imread('C:\Users\user\Desktop\ACTIVITEMULTI\base_originale\Hoffman.jpg'));
    %s = 512;
    sigma = 20; % NV(in);
    noise = randn(size(im));
    noise = sigma.*(noise./(std(noise(:))));
    % cfg =  [4 5 5 6];
    %cfg =  [3 4 4 5];
    cfg =  [2 2 2 2 2];
    alpha = 0.15;
    s = 512;
    resi = false;
    %%%%%%%%%%PDTDFB_WIN   Generate the Freq. windows that used in PDTDFB toolbox%%
    %	F2 = pdtdfb_win(s2, alpha, Lnlev, res)
    % Input:
    %   s : size of the generated window
    %   alpha : paramter for meyer window
    % Output:
    %   FL: 2-D window of low pass function for lower resolution curvelet
    %   F : cell of size n containing 2-D matrices of size s*s
    F = pdtdfb_win(s, alpha, length(cfg), resi);
    disp('Compute all thresholds');
    Ff = ones(s);
    X = fftshift(ifft2(Ff)) * sqrt(prod(size(Ff)));
    % PDTDFBDEC_F   Pyramidal Dual Tree Directional Filter Bank Decomposition
    % using FFT at the multresolution FB and the first two level of dual DFB
    % tree
    %	y2 = pdtdfbdec_f(im, nlevs, F2, alpha, res)
    % Input:
    %   x:      Input image
    %   nlevs:  vector of numbers of directional filter bank decomposition levels
    %           at each pyramidal level (from coarse to fine scale).
    %           0 : Laplacian pyramid level
    %           1 : Wavelet decomposition
    %           n : 2^n directional PDTDFB decomposition
    %   F2:     [optional] Precomputed F window
    %   alpha:  [optional] Parameter for F2 window, incase F2 is not pre-computed
    %   res :   [optional] Boolean value, specify weather existing residual
    %           band
    % Output:
    %   y:      a cell vector of length length(nlevs) + 1, where except y{1} is
    %           the lowpass subband, each cell corresponds to one pyramidal
    %           level and is a cell vector that contains bandpass directional
    %           subbands from the DFB at that level.
    yn = pdtdfbdec_f(noise, cfg, F, alpha, resi);
    y = pdtdfbdec_f(im, cfg, F, alpha, resi);
    clear eng
    for scale = 1:length(cfg)
        for dir = 1:2^cfg(scale)
            Y_coef_real = y{scale+1}{1}{dir};
            % imaginary part
            Y_coef_imag = y{scale+1}{2}{dir};
            % Signal variance estimation
            Y_coef = Y_coef_real+j*Y_coef_imag;
            Y_noise_real = yn{scale+1}{1}{dir};
            % imaginary part
            Y_noise_imag = yn{scale+1}{2}{dir};
            Y_noise = Y_noise_real+j*Y_noise_imag;
            Y_coef = abs(Y_noise).*Y_coef./abs(Y_coef);
            y{scale+1}{1}{dir} = real(Y_coef);
            y{scale+1}{2}{dir} = imag(Y_coef);
        end
    end
    y{1} = zeros(size(y{1}));
    % Inverse Transform
    tic
    pim = pdtdfbrec_f(y, F, alpha,resi);toc
    respdtdfb = psnr(im, pim)
    quand je l'exécute j'ai le message d'erreur suivant
    ?? Error using ==> times
    Matrix dimensions must agree.
    Error in ==> pdtdfbdec_f at 74
    imf2 = imf.*F{1};
    Error in ==> curvelette at 62
    Je serais reconnaissante à vous si vous pouvez m'aider.
    Merci d'avance.
    lou_ibmix_xi
    Re : Décomposition en curvelet
    Le message d'erreur est pourtant explicite, tu essaies de multiplier deux matrices entre elles dont les dimensions ne correspondent pas i.e. le nb de colonne de l'une n'est pas égale au nb de lignes de l'autre et/ou vice-versa
    faat
    oui j'ai compris le message d'erreur mais j'ai pas pu corriger leurs dimension.
    Comment faire??
  1. Décomposition LU
    Par mx6 dans le forum Mathématiques du supérieur
    Dernier message: 07/03/2010, 13h34
  2. décomposition LU et PA LU
    Par neradol dans le forum Mathématiques du supérieur
    Dernier message: 26/01/2010, 21h46
  3. décomposition
    Par invite7b3eba7f dans le forum Mathématiques du supérieur
    Dernier message: 14/09/2008, 10h33
  4. Décomposition!
    Par invitef824ea3c dans le forum Mathématiques du supérieur
    Dernier message: 23/01/2007, 16h21
