Tracé fonction
Tracé fonction
    pierre57570
    Tracé fonction
    Bonsoir je voudrai savoir comment tracé ces fonctions du code ci-joint sur matlab ?
    Merci beaucoup
    pierre57570
    Re : Tracé fonction
    voila le code:
    Code:
    function [L2_error_w] = beam_loadsteps(N,LS)
        % problem parameters
        param.L  = 1;
        param.EA = 10^5;
        param.EI = 20;
        param.p1 = 0;
        param.p3 = 10;
        param.num_load_steps = linspace(0,1,LS);
        F1crit=403.814571;
        F1=0.50*F1crit;
        % problem kinematic and static boundary conditions
        bc.u_idx   = [1 ];
        bc.u_val   = [0 ];
        bc.w_idx   = [2 3*N-1];
        bc.w_val   = [0 0];
        bc.phi_idx = [3];
        bc.phi_val = [0];
        bc.F1_idx  = [3*N-2];
        bc.F1_val  = [-F1];
        bc.F3_idx  = [ ];
        bc.F3_val  = [ ];
        bc.M_idx   = [ ];
        bc.M_val   = [ ];
        % define number of points for evaluating exact solution
        E = N*100;
         % obtain exact and approximate solution
        %[x_exact ,U_exact ] = beam_exact(E, param, bc);
        [x_exact ,U_exact ] = beam_exact_loadsteps(E, param, bc);
        [x_approx,U_approx] = beam_approx_loadsteps(N, param, bc);
        % prepare plotting
        close all hidden; figure('DefaultAxesFontSize',18); clf; hold on;
        set(gca,'Ydir','reverse');
        % get sub-element values (for plotting and error computation)
        u_exact = U_exact(1,:);
        w_exact = U_exact(2,:);
        u_approx_m = interp1       (x_approx,U_approx(1,:,end),                  x_exact);
        w_approx_m = interp1hermite(x_approx,U_approx(2,:,end),U_approx(3,:,end),x_exact);
        % plot exact and approximate solution graph
        plot(x_exact ,u_exact   , 'b--');
        plot(x_exact ,u_approx_m, 'b-' );
        plot(x_exact ,w_exact   , 'r--');
        plot(x_exact ,w_approx_m, 'r-' );
        plot(x_approx,U_approx(1,:,end),'bo');
        plot(x_approx,U_approx(2,:,end),'ro');
        axis([0 param.L -0.005 +0.015]);
        xlabel('coordinate x [m]');
        ylabel('displacement [m]');
        title('beam 2nd order theory');
        legend('u_{exact}^{2nd order}', 'u_{approx}^{2nd order}', 'w_{exact}^{2nd order}', 'w_{approx}^{2nd order}', 'Location','SouthWest');
        grid on;
        print('beam_2ndorder.png','-dpng');
        % plot lambda-deformation curve
        phi = squeeze(U_approx(3,end,:));
        plot(phi, param.num_load_steps, 'b-*');
        xlabel('deformation value (end point rotation) [rad]');
        ylabel('load factor [-]');
        set(gca,'Xdir','reverse');
        title('beam 2nd order theory: load-deformation curve');
        grid on;
        print('beam_2ndorder_loadcurve.png','-dpng');
        % compute L_2 error w
        L2_error_w = sqrt( trapz( (w_approx_m - w_exact).^2 ) / trapz(w_exact.^2) );
    end
    Dernière modification par Antoane ; 19/12/2016 à 21h45. Motif: Ajout balises code
  1. Fonction de partition : Trace
    Par igbe dans le forum Physique
    Dernier message: 06/11/2013, 22h38
  2. tracé de la fonction f(x)=pi/2 + x
    Par frankcity dans le forum Mathématiques du supérieur
    Dernier message: 28/01/2013, 21h02
  3. Tracé fonction gamma
    Par invite8d54258a dans le forum Mathématiques du supérieur
    Dernier message: 12/02/2010, 00h38
  4. trace fonction matlab
    Par invitee98002ab dans le forum Mathématiques du supérieur
    Dernier message: 21/06/2007, 17h11
