salut tout le monde,
s'il vous plaît j'ai besoin d'une correction de mon programme python qui implemente la fonction de hachage sha-3
aprés le test du programme j'obtiens un hash different de celui calculé dans les sites internet.
vous trouverez ci-joint un document pdf contenant un algorithme detaillé de sha-3:
NIST.FIPS.202.pdf
Code:
import numpy as np
from math import log2
int1=np.vectorize(int)
def xor(a,b):
    return int(((not a) and b) or ((not b) and a))
def xors(s,t):
    m=max(len(s),len(t))
    s='0'*(m-len(s))+s
    t='0'*(m-len(t))+t
    X=''
    for i in range(m):
        X=X+str(xor(int(s[i]),int(t[i])))
    return X
def converts_a(s):
    w=len(s)//25
    A=np.zeros((5,5,w))
    for x in range(5):
        for y in range(5):
            for z in range(w):
                A[x][y][z]=s[w*(5*y+x)+z]
    return int1(A)
def converta_s(a):
    w=len(a[0][0])
    s=''
    for y in range(5):
        p=''
        for x in range(5):
            l=''
            for z in range(w):
                l=l+str(a[x][y][z])
            p=p+l
        s=s+p
    return s
def theta(a):
    w=len(a[0][0])
    c=np.zeros((5,w))
    d=np.zeros((5,w))
    A=np.zeros((5,5,w))
    for x in range(5):
        for z in range(w):
            c[x][z]=xor(xor(xor(a[x][0][z],a[x][1][z]),xor(a[x][2][z],a[x][3][z])),a[x][4][z])
    for x in range(5):
        for z in range(w):
            d[x][z]=xor(c[(x-1)%5][z],c[(x+1)%5][(z-1)%w])
    for x in range(5):
        for y in range(5):
            for z in range(w):
                A[x][y][z]=xor(a[x][y][z],d[x][z])
    return int1(A)
def rho(a):
    w=len(a[0][0])
    A=np.zeros((5,5,w))
    for z in range(w):
        A[0][0][z]=a[0][0][z]
    (x,y)=(1,0)
    for t in range(24):
        for z in range(w):
            A[x][y][z]=a[x][y][(z-((t+1)*(t+2))//2)%w]
        (x,y)=(y,(2*x+3*y)%5)
    return int1(A)
def pi(a):
    w=len(a[0][0])
    A=np.zeros((5,5,w))
    for x in range(5):
        for y in range(5):
            for z in range(w):
                A[x][y][z]=a[(x+3*y)%5][x][z]
    return int1(A)
def chsy(a):
    w=len(a[0][0])
    A=np.zeros((5,5,w))
    for x in range(5):
        for y in range(5):
            for z in range(w):
                A[x][y][z]=xor(a[x][y][z],xor(a[(x+1)%5][y][z],1)*a[(x+2)%5][y][z])
    return int1(A)
def rc(t):
    n=t%255
    if n==0: return 1
    R=[1,0,0,0,0,0,0,0]
    for i in range(1,n+1):
        R=[0]+R
        R[0]=xor(R[0],R[8])
        R[4]=xor(R[4],R[8])
        R[5]=xor(R[5],R[8])
        R[6]=xor(R[6],R[8])
        R=R[:8]
    return int(R[0])
def iota(a,i):
    w=len(a[0][0])
    l=int(log2(w))
    A=np.zeros((5,5,w))
    for x in range(5):
        for y in range(5):
            for z in range(w):
                A[x][y][z]=a[x][y][z]
    RC=[0]*w
    for j in range(l+1):
        RC[(2**j)-1]=rc(j+7*i)
    for z in range(w):
        A[0][0][z]=xor(A[0][0][z],RC[z])
    return A
def rnd(a,i):
    return iota(chsy(pi(rho(theta(a)))),i)
def keccakp(b,n,s):
    w=b//25
    l=int(log2(w))
    a=converts_a(s)
    for i in range(12+2*l-n,12+2*l):
        a=int1(rnd(a,i))
    a=int1(a)
    S=converta_s(a)
    return S
def sponge(b,f,pad,r,s,d):
    P=s+pad(r,len(s))
    n=len(P)//r
    c=b-r
    S='0'*b
    for i in range(n):
        S=f(xors(S,P[i*r:i*(r+1)]+'0'*c))
    Z=''
    while len(Z)<d:
        Z=Z+S[:r]
        S=f(S)
    return Z[:d]
def pad101(x,m):
    j=(-m-2)%x
    return '1'+j*'0'+'1'
g=lambda x:keccakp(1600,24,x)
def keccak(c,s,d):
    b=1600
    f=g
    pad=pad101
    r=1600-c
    S=sponge(b,f,pad,r,s,d)
    return S
def binaire(m):
    l=list(m.encode())
    txt=''
    for e in l:
        s=len(bin(e))-2
        txt=txt+(8-s)*'0'+bin(e)[2:]
    return txt
def sha3_224(M):
    S=binaire(M)+'01'
    return keccak(448,S,224)
def sha3_256(M):
    S=binaire(M)+'01'
    return keccak(512,S,256)
def sha3_384(M):
    S=binaire(M)+'01'
    return keccak(768,S,384)
def sha3_512(M):
    S=binaire(M)+'01'
    return keccak(1024,S,512)
merci d'avance
