J'aurais une petite question pour ceux qui si connais je me pose la question suivante jai 2 sub a 700watt max , 350watt rms a 4 ohm et jai trouver un ampli qui pourait faire la job mais le watt max depasse un peut la capacité de mes sub est ce que sa va l'endommagé ou sa devrait bien fonctionner.
mes sub sont des ts-w255c Pioneer
Specifications
Watts MAX. Music Power 700W
Watts Nominal Power Handling 350W
Frequency Response 18hz ~ 2.5kHz
Sensitivity 87dB
Ohm Rating SVC:4, DVC: 2 or 8
Recommended Enclosure 1.0 Cubic Feet
Accessory Grill UD-G255
et les ampli que jhesite entre sont
*BOSS C900 1600w 2 CHANNEL
1600 watts 2 channel bridgeable car amplifier
800 X 2 @ 2 Ohms Peak output
300 x 2 RMS @ 4 ohms
1600 x 1 bridged @ 4 ohm
MOS-FET Power Supply
Freq Response: 9 HZ - 50 KHz
Aluminum Heat sink to ensure the best quality
Dual Fused
Nickel Plated RCA and Speaker Level Inputs (for a secure connection to your speakers, eliminating unwanted noises)
Built in high/low and bypass crossover network
Adjustable Low Pass Frequency
Soft Turn-on Circuitry
Thermal a/ Short / Overload Protection
0 - 18 dB Bass Boost
Dimensions: 16"L x 11.42"W x 2.78"H
THD: .01% 1W / M
Speaker Level Inputs: Yes
Signal-to-Noise Ratio: 102 dB
Bass Boost: 0 - 18 dB
Tri-Mode Capable
______________________________ ______________________________ _____
*Power Acoustik PS2-1800
The specs are as follows:
2-CHANNEL
4 OHM RMS: 300W X 2
2 OHM RMS: 380W X 2
MONO RMS: 760W
BRIDGED MAX: 1800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
2 OHM STABLE STEREO; TRI-MODE CAPABLE
VARIABLE LOW PASS – 40 HZ–120 HZ
VARIABLE HIGH PASS – 150 HZ–1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 97 DB; THD: 0.02%
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
SPADE TERMINALS
CHROME TOP PLATE
PLATINUM RCA CONNECTORS
LINE OUTPUT
merci d'avance
