erreur_code_FPGA
erreur_code_FPGA
    elec_cup
    erreur_code_FPGA
    la compilation est ok.
    Par contre, lorsque je lance la simulation, j'ai une erreur du type:
    vsim work.test_bench work.sinus work.is_main
    # vsim work.test_bench work.sinus work.is_main
    # Loading std.standard
    # Loading ieee.std_logic_1164(body)
    # Loading work.test_bench(test)
    # ** Fatal: (vsim-3370) Top-level design unit 'sinus' must be an ENTITY, CONFIGURATION , MODULE or PROGRAM
    # Time: 0 ps Iteration: 0 Instance: / File: NOFILE
    # FATAL ERROR while loading design
    # Error loading design
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_unsigned.all;
    use ieee.numeric_std.all;
    use work.sinus.all;
    entity is_main is
    port(
    impulsion : in std_logic;
    clock : in std_logic;
    retard : in std_logic_vector (3 downto 0);
    wave_out : out std_logic_vector (4 downto 0)
    end entity;
    architecture main of is_main is
    signal comptage : std_logic_vector (3 downto 0);
    signal b : integer :=0;
    begin
    process
    begin
    b<=to_integer(unsigned(retard) );
    wait until impulsion'event and impulsion='1';
    for i in 0 to b loop
    wait until clock'event;
    comptage<=comptage+1;
    end loop;
    comptage<="0000";
    end process;
    process
    variable table_value:table_value_type;
    variable table_index:table_index_type;
    begin
    while comptage=retard loop
    for i in 0 to max_table_index loop
    table_value:=get_table_value(t able_index);
    table_index:=table_index+1;
    --wave_out<=table_value;
    wave_out<=std_logic_vector(to_ unsigned(table_value,sine_vect or_type'length));
    end loop;
    table_index:=0;
    end loop;
    end process;
    end architecture main;
    library ieee;
    entity test_bench is
    end entity;
    architecture test of test_bench is
    signal impulsion : std_logic :='0';
    signal clock : std_logic :='0';
    signal retard : std_logic_vector (3 downto 0) :="1110";
    component is_main is
    port(
    end component;
    begin
    porte : is_main
    port map(impulsion=>impulsion,clock =>clock,retard=>retard);
    process
    begin
    wait for 60 ns;
    impulsion<='1';
    wait for 10 ns;
    impulsion<='0';
    end process;
    process
    begin
    wait for 1 ns;
    clock<='1';
    wait for 1 ns;
    clock<='0';
    end process;
    end architecture test;
    library ieee;
    package sinus is
    constant max_table_value:integer:=5;
    subtype table_value_type is integer range 0 to max_table_value;
    constant max_table_index:integer:=5;
    subtype table_index_type is integer range 0 to max_table_index;
    subtype sine_vector_type is std_logic_vector (4 downto 0);
    function get_table_value (table_index:table_index_type) return table_value_type;
    end;
    package body sinus is
    function get_table_value (table_index:table_index_type) return table_value_type is
    begin
    case table_index is
    when 0 =>
    table_value:=0;
    when 1 =>
    table_value:=1;
    when 2 =>
    table_value:=2;
    when 3 =>
    table_value:=3;
    when 4 =>
    table_value:=4;
    when 5 =>
    table_value:=5;
    end case;
    return table_value;
    end;
    end;
    Quelle est la source d'erreur ? Je ne vois pas !
    DELALIN Ambroise
    Re : erreur_code_FPGA
    manifestement tu sembles vouloir simuler "sinus" c'est pas possible.
    Il faudrait que tu prennes l'habitude de faire un fichier séparé pour les package, cela permet de les compiler séparément, ici je me demande comment modelsim s'en tire car ton code semble être autoréférent au niveau de la library work s'il n'y a qu'un seul fichier.
    elec_cup
    en effet il ne faut pas compiler le package.
    En ce qui concerne la séparation des fichiers (test_bench, is_main et package), c'est déjà fait.
    J'ai juste copier coller les trois programmes sur ce forum.
    Merci de ton aide !
    DELALIN Ambroise
