Modelsim post place and route simulation
    invite1e0f022e
    Hi,
    I am trying to synthesize a filter and it works out fine in Xilinx ISE
    9.1i for Synthesize and Implement.However when I create a test
    bench and try to see a Post-Place & Route simulation result, I get
    warnings about unbound components. Following is the warning and the
    snippet of code that Im using.What am I doing wrong here....Any help
    is appreciated!!!
    I am getting the following warnings(a lot of them) when I synthesize
    the following code for the filter. What am I doing wrong?
    On a post translate or a post place and route simulation, I get a 'U'
    on my output pin...
    The error I see looks something like
    # ** Warning: (vsim-3473) Component instance 'tt_out_0_obuf : x_obuf' is not bound.
    # Time: 0 ps Iteration: 0 Region: /tt_tbw_vhd/uut File: C:/Xilinx91i/PFE/test/netgen/par/tt_timesim.vhd
    # ** Warning: (vsim-3473) Component instance 'tt_out_0_output_off_o1inv : x_buf' is not bound.
    # ** Warning: (vsim-3473) Component instance 'tt_out_0_output_off_oceinv : x_buf' is not bound.
    # ** Warning: (vsim-3473) Component instance 'tt_out_0_output_off_omux : x_buf' is not bound.
    # ** Warning: (vsim-3473) Component instance 'tt_out_0_output_otclk1inv : x_buf' is not bound.
    # ** Warning: (vsim-3473) Component instance 'tt_out_1_obuf : x_obuf' is not bound.
    # ** Warning: (vsim-3473) Component instance 'tt_out_1_output_off_o1inv : x_inv' is not bound.
    # ** Warning: (vsim-3473) Component instance 'tt_out_1_output_off_oceinv : x_buf' is not bound.
    # ** Warning: (vsim-3473) Component instance 'tt_out_1_output_off_omux : x_buf' is not bound.
    # Time: 0 ps Iteration: 0 Region: /tt_tbw_vhd/uut File: C:/Xilinx91i/PFE/test/netgen/par/tt_timesim.vhd....
    and so on
    Code snippet for filter:
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    use IEEE.NUMERIC_STD.ALL;
    ---- Uncomment the following library declaration if instantiating
    ---- any Xilinx primitives in this code.
    --library UNISIM;
    --use UNISIM.VComponents.all;
    entity filter is
    Port ( clk : in std_logic;
    rst : in std_logic;
    en : in std_logic;
    filter_in : in std_logic;
    filter_out : out std_logic_vector (13 downto 0)
    end filter;
    architecture Behavioral of filter is
    -- Filter Order
    constant K : integer := 18;
    -- New types to use
    type tab6x13 is array (5 downto 0) of signed (12 downto 0); -- 6 coefficients under 13 bits
    type tab6x15 is array (5 downto 0) of signed (14 downto 0); -- 6 additions under 15 bits
    type tab6x28 is array (5 downto 0) of signed (27 downto 0); -- 6 multiplications under 28 bits
    type tab19x14 is array (K downto 0) of signed (13 downto 0); -- shifted inputs under 14 bits
    -- Intermediate signals
    signal COEFF : tab6x13;
    signal REG1,REG2 : tab19x14;
    signal SUM : tab6x15;
    signal PROD : tab6x28;
    -- Input buffer
    signal INPUT : std_logic_vector (13 downto 0);
    -- Output buffer
    signal OUTPUT : signed (13 downto 0);
    -- Temporary signals
    signal sum1_1 : signed (28 downto 0);
    signal sum1_2 : signed (28 downto 0);
    signal sum1_3 : signed (28 downto 0);
    signal sum2 : signed (29 downto 0);
    signal sum3 : signed (30 downto 0);
    begin
    main : process (clk, rst, en)
    begin
    if (rst = '1') then
    COEFF(5) <= to_signed (33, 13);
    COEFF(4) <= to_signed (-78, 13);
    COEFF(3) <= to_signed (172, 13);
    COEFF(2) <= to_signed (-376, 13);
    COEFF(1) <= to_signed (1283, 13);
    COEFF(0) <= to_signed (2048, 13);
    INPUT <= (others => '0');
    filter_out <= (others => '0');
    REG1(K) <= (REG1(K)'range => '0');
    REG2(K) <= (REG2(K)'range => '0');
    elsif (CLK'event and CLK = '1') then
    if (en = '1') then
    if (filter_in = '0') then
    INPUT <= '11111111111111';
    else
    INPUT <= '00000000000001';
    end if;
    REG1(K) <= signed(INPUT);
    REG2(K) <= signed(INPUT);
    filter_out <= std_logic_vector(OUTPUT);
    end if;
    end if;
    end process main;
    shifting:for j in K-1 downto 0 generate
    stages: process(rst,clk,en)
    begin
    if (rst='1') then
    REG1(j) <= (REG1(j)'range=>'0');
    REG2(j) <= (REG2(j)'range=>'0');
    elsif (clk'event and clk = '1') then
    if (en = '1') then
    REG1(j) <= REG2(j+1);
    REG2(j) <= REG1(j+1);
    end if;
    end if;
    end process;
    end generate;
    summing : for j in 9 downto 5 generate
    SUM(j-4) <= REG1(2*j)(13) & REG1(2*j) + REG1(K - 2*j);
    end generate;
    SUM(0) <= REG1(9)(13)®1(9);
    multiplying : for j in 5 downto 0 generate
    PROD(j) <= SUM(j)*COEFF(j);
    end generate;
    -- Tree adder
    sum1_1 <= PROD(5)(27) & PROD(5) + PROD(4);
    sum1_2 <= PROD(3)(27) & PROD(3) + PROD(2);
    sum1_3 <= PROD(1)(27) & PROD(1) + PROD(0);
    sum2 <= sum1_1(28) & sum1_1 + sum1_2;
    sum3 <= sum2(29) & sum2 + sum1_3;
    OUTPUT <= sum3(13 downto 0);
    end Behavioral;
    Thanks in advance.
    umfred
    Re : Modelsim post place and route simulation
    Hi,
    It seems to be a problem of a simulation with a missing ressource library.
    See the page 50 of this document and follow the step to link a ressource step.
    hello
    As Umfred said there is one (or more) missing library wich are instanciated by the post layout writer, that seems to be a gate level library . As i am not very familiar with xylinx i am unable to say more.
  1. Détermination de la route fond
    Par invite8ba42bb3 dans le forum Mathématiques du collège et du lycée
    Dernier message: 19/08/2007, 19h38
  2. Librairie Modelsim/Quartus
    Par invite27471be0 dans le forum Électronique
    Dernier message: 10/08/2007, 17h02
  3. route mystérieuse
    Par invite58742c0e dans le forum Physique
    Dernier message: 03/02/2007, 23h16
  4. Finlandaise cherchant post de post doc en France
    Par invite317d0c7a dans le forum Orientation après le BAC
    Dernier message: 11/04/2005, 13h36
  5. probabilité et accidents de la route
    Par inviteb1a6da1f dans le forum Mathématiques du supérieur
    Dernier message: 14/02/2005, 16h03
