Erreur 256 sous Code::Blocks
    invitec86ed256
    Salut à tous,
    Voila, comme l'indique le titre, j'ai une erreur sous Code::Blocks dont je n'arrive malheureusement pas à trouver la solution. Je fait de la programmation pour pic.
    Voici le message exact:
    -------------- Build: Debug in test ---------------
    Compiling: main.c
    at 1: warning 119: don't know what to do with file 'pic16f877a'. file extension unsupported
    + "/usr/bin/sdcpp" -nostdinc -Wall -I"/usr/share/sdcc/include" -I"/usr/share/sdcc/lib" -I"/usr/share/sdcc/scripts" -obj-ext=.o -DSDCC_MODEL_SMALL -DSDCC=290 -DSDCC_REVISION=5416 -DSDCC_pic14 -D__pic14 -DSDCC_PROCESSOR="16f877a" -isystem "/usr/bin/../share/sdcc/include/pic14" -isystem "/usr/share/sdcc/include/pic14" -isystem "/usr/bin/../share/sdcc/include" -isystem "/usr/share/sdcc/include" -isystem "/usr/bin/../share/sdcc/include/pic" -isystem "/usr/share/sdcc/include/pic" "main.c"
    + "/usr/bin/gpasm" -g -c "obj/Debug/main.asm"
    Linking console executable: bin/Debug/test
    message: using default linker script "/usr/share/gputils/lkr/16f877a.lkr"
    warning: relocation of section "UDL_main_0" failed, relocating to a shared memory location
    error: no target memory available for section "UDL_main_0"
    + "/usr/bin/gplink" -I"/usr/bin/../share/sdcc/lib" -I"/usr/share/sdcc/lib" -I"/usr/bin/../share/sdcc/lib/pic" -I"/usr/share/sdcc/lib/pic" -c -w -r -o bin/Debug/test obj/Debug/main.rel /usr/share/sdcc/lib/pic/pic16f877a.lib /usr/share/sdcc/lib/pic/libsdcc.lib libsdcc.lib pic16f877a.lib
    + "/usr/bin/gplink" -I"/usr/bin/../share/sdcc/lib" -I"/usr/share/sdcc/lib" -I"/usr/bin/../share/sdcc/lib/pic" -I"/usr/share/sdcc/lib/pic" -c -w -r -o bin/Debug/test obj/Debug/main.rel /usr/share/sdcc/lib/pic/pic16f877a.lib /usr/share/sdcc/lib/pic/libsdcc.lib libsdcc.lib pic16f877a.lib returned errorcode 256
    Process terminated with status 1 (0 minutes, 0 seconds)
    0 errors, 0 warnings
    Quelqu'un a-t-il déjà eu ce problème ?
    Si vous avez besoin d'une quelconque autre information, n’hésitez pas à ma le faire savoir
    Merci !!!
    invitec86ed256
    Re : Erreur 256 sous Code::Blocks
    apparemment personne n'a jamais eu ce problème...
    (c'était obligé que ça tombe sur moi !!! )
    ce qui est bizard, c'est qu'il me marque qu'il n'y a pas d'erreur ou de warning dans mon code...
  1. problème code blocks
    Par lawliet yagami dans le forum Logiciel - Software - Open Source
    Réponses: 35
    Dernier message: 26/04/2010, 11h48
  2. code:blocks+ gnuplot
    Par invite6f723495 dans le forum Logiciel - Software - Open Source
    Dernier message: 29/03/2010, 15h46
  3. problème ajout de fichier à projet sous code::blocks
    Par inviteead871d5 dans le forum Logiciel - Software - Open Source
    Dernier message: 02/06/2008, 14h46
  4. [programmation] code:blocks C++
    Par chwebij dans le forum Logiciel - Software - Open Source
    Dernier message: 20/03/2008, 19h24
  5. Code::Blocks et Qt
    Par Mendoza dans le forum Logiciel - Software - Open Source
    Dernier message: 20/02/2006, 20h59
