Etoile laser au sodium
    invite91cb62e0
    Dans plusieurs thèses, il est dit que le laser au sodium est le meilleur choix pour la création d'une étoile laser dans la mesosphère.
    Voila ce qu'on me dit :
    Section effiace :
    Na :
    K :
    Fe :
    Densité surfacique :
    Na :
    K :
    Fe :
    Alors il apparait que la densité de Fer est plus importante d'un facteur 2 par rapport au sodium mais que sa section efficace est inférieur d'un facteur 10 environ.
    Pourquoi prend-on l'élément qu'il a la plus grande section efficace ?
    Skops :P
    Gilgamesh
    Re : Etoile laser au sodium
    Dernière modification par Gilgamesh ; 02/01/2011 à 23h30.
    Parcours Etranges
    Gilgamesh
    Il manque les unités à ces données.
    Sections efficaces :
    Source : Lidar: range-resolved optical remote sensing of the atmosphere By Claus Weitkamp
    Densités :
    Pour le fer :
    Iron atom densities in the polar mesosphere from lidar observations
    Between March 24 and April 6, 1990, we performed lidar measurements of iron densities above Andøtya, Norway (69° N). In each of the five nights of measurements we observed a regular Fe layer which was confined to the altitude region between 80 and 100 km. Its peak Fe densities occurred at (84.5 ±1) km or approximately 6 km lower than the peak of the sodium layer as observed by us two weeks earlier. The regular Fe layer exhibited column densities of (9 ± 4) ·109 cm-2 and maximum number densities close to 7,000 cm-3. In addition, sporadic Fe layers were observed frequently between 88 and 108 km, one of which reached a maximum number density of 78,000 cm-3 near 97 km altitude. Properties of the Fe layers as observed by us are compared to those observed by Granier et al. [1989] and by Bills and Gardner [1990].
    Pour le sodium :
    Lidar observations of substantial sodium depletion in the summertime Arctic mesosphere
    The chemistry and dynamics of the mesospheric sodium layer have been studied extensively with lidar (laser radar) techniques since the late 1960s. Meteoric ablation is generally regarded as the dominant source of all mesospheric alkali metals including sodium. The Na layer is typically confined to the region between 80 and 110 km with a peak near the mesopause at 90 km, where the density ranges from 103 to 104 cm-3. The Na column abundance at mid-latitudes in the Northern Hemisphere varies from a summer minimum of 3.109 cm-2 to a winter maximum of 1010 cm-2 in December and January
    Je vérifie pas pour le Potassium je te fais confiance mais avec tout ça, le produit de la densité surfacique par la section efficace justifie bien le choix du sodium, il me semble. En plus, le doublet de ses raies est très caractéristique.
    a+
    Parcours Etranges
  1. Laser game ; cosmic laser ; laser quest ...
    Par invite256fae87 dans le forum Électronique
    Dernier message: 16/02/2010, 17h26
  2. hydroxyde de sodium, de potassium et coco sulfalte de sodium
    Par invite11e24f29 dans le forum Chimie
    Dernier message: 31/08/2009, 08h59
  3. TIPE Imprimante laser : miroir et laser
    Par invite210441ae dans le forum TPE / TIPE et autres travaux
    Dernier message: 20/03/2007, 16h27
  4. TPE ; vitesse de rotation d'une étoile et masse d'une étoile
    Par invitec14342b6 dans le forum TPE / TIPE et autres travaux
    Dernier message: 20/02/2006, 19h00
