Position du soleil
Position du soleil
    invitefa15af9f
    Position du soleil
    je désire calculer la position du soleil, et parr hazard j'ai trouvé un algorithme sur le net.
    quelqu'un peu m'expliquer cet algorithme .
    que signifie alpha et delta? et est ce qui'ils sont suffisant pour déterminer la position du soleil??
    merci infiniment d'avance
    Code:
    Position of the Sun at 11:00 UT on 1997 August 7th
    1. Find the days before J2000.0 (d) from the table
       d = 11/24 + 212 + 7 - 1096.5 = -877.04167
    2. Find the Mean Longitude (L) of the Sun
       L = 280.461 + 0.9856474 * d
         = -583.99284 + 720
        (add multiples of 360 to bring in range 0 to 360)
         = 136.00716
    3. Find the Mean anomaly (g) of the Sun
       g = 357.528 + 0.9856003 * d
         = -506.88453 + 720
         = 213.11547
    4. Find the ecliptic longitude (lambda) of the sun
       lambda = L + 1.915 * sin(g) + 0.020 * sin(2*g)
              = 134.97925
       (note that the sin(g) and sin(2*g) terms constitute an
        approximation to the 'equation of centre' for the orbit
        of the Sun)
       beta = 0 (by definition as the Sun's orbit defines the
                 ecliptic plane. This results in a simplification
                 of the formulas below)
    5. Find the obliquity of the ecliptic plane (epsilon)
       epsilon = 23.439 - 0.0000004 * d
               = 23.439351
    6. Find the Right Ascension (alpha) and Declination (delta) of
       the Sun
       Y = cos(epsilon) * sin(lambda)
       X = cos(lambda)
       a = arctan(Y/X)
       If X < 0 then alpha = a + 180
       If Y < 0 and X > 0 then alpha = a + 360
       else alpha = a
       Y =  0.6489924
       X = -0.7068507
       a = -42.556485
       alpha = -42.556485 + 180 = 137.44352 (degrees)
       delta = arcsin(sin(epsilon)*sin(lambda))
             = 16.342193 degrees
    Final result
       Right ascension is usually given in hours of time, and both
       figures need to be rounded to a sensible number of decimal
       places.
       alpha =   9.163 hrs      or   9h 09m 46s
       delta = +16.34 degrees   or +16d 20' 32"
       The Interactive Computer Ephemeris gives
       alpha =   9h 09m 45.347s and
       delta = +16d 20' 30.89"
    invitefe6f47fa
    Re : Position du soleil
    Pour t'expliquer tu dois avoir des notions d'astronomie (anomalie vraie, anomalie moyenne, équation du centre, longitude du périgée, obliquité, excentricité, nutation, aberration, temps de propagation, réfraction, équinoxe moyen...) , je te conseille vivement le livre Astronomie Générale (André Danjan).
    sinon alpha : c'est l’ascension droite.
    et delta: la déclinaison.
    Oui c'est suffisant c'est les coordonnées équatoriales du soleil.
    Ciao
    invitefe6f47fa
    L'algorithme que tu as donné fait les opérations suivantes:
    1- calcul du nombre de jour julien écoulé depuis j2000 (1/1/2000). Dans la 1ere equation 11/24 correspond a l'heure (11:00) convertie en fraction de jour, sinon les autres parametres (année, mois, jour) ont été remplacés dans l'équation;
    2- Calcul de longitude moyenne du soleil;
    3- Calcul de l'anomalie moyenne du soleil;
    4- Calcul de la longitude apparente du soleil;
    5- Calcul de l'obliquité;
    6- Calcul de l'ascension droite et de la déclinaison (coordonnées équatoriales desquelles tu peux déduire l'azimut et la hauteur).
    Par contre, je n'aime pas trop cet algorithme et les equations choisies je te conseille Astronomical ALgorithms de Jean Meeus.
    invitefa15af9f
    Merci beaucoup pour votre réponse
    en ce qui concerne le livre Astronomical ALgorithms de Jean Meeus, je doit lire le chapitre Equation of Kepler?
    invitefe6f47fa
    Ben d'abord tu jettes un coup d’œil aux chapitres Julian Day, Nutation and the Obliquity of th Ecliptic, et Solar Coordinates, et tu dois savoir par exemple comment lire les table des éléments de l'orbite.
    Par exemple, pour le chapitre Solar Coordinates la première équation donne la longitude moyenne du soleil rapportée a équinoxe moyen de la date.
    Si tu prends la table 30.A (page 200) "Orbital Elements for the mean equinox of the date", dans les paramètres de la Terre tu retrouve les coefficients utilisés.
    A la première ligne il y a marquer "L" tu retrouve les coefficients de l’équation de "" (au premier paramètre tu dois rajouter 180 degrés).
    On peut voir par exemple que le coefficient de est si tu le rajoute tu aura l’équation:
    (Tout dépend de la précision que tu souhaites avoir).
    Pour obtenir les coefficients de l'anomalie moyenne, toujours dans la même table tu soustrais la dernière ligne a la première ligne et tu auras tes coefficients...
    Voila, juste une petite précision T est en siècle juliens.
    Ciao
  1. Calcul de la position du Soleil
    Par invite8633ed06 dans le forum Archives
    Dernier message: 28/04/2012, 12h32
  2. Position du soleil
    Par invitefa15af9f dans le forum Archives
    Dernier message: 11/03/2012, 01h41
  3. Position du soleil
    Par invite7f0233d4 dans le forum Archives
    Réponses: 17
    Dernier message: 29/03/2009, 21h29
  4. capteur de position du soleil..?
    Par vincent66 dans le forum Électronique
    Dernier message: 15/12/2008, 20h46
  5. Position du soleil
    Par inviteb6ac2ab8 dans le forum Archives
    Dernier message: 03/11/2007, 14h58
