Ds1307 ET 18F452
Ds1307 ET 18F452
    invite489d7312
    Ds1307 ET 18F452
    Bonjour, j'ai le programme avec lequel je n'arrive pas à afficher l'heure.
    Code:
    #include <p18f452.h>
    #include <delays.h>
    #include <stdio.h>
    #include <i2c.h>
    #include <xlcd.h>
    #pragma config WDT =OFF
    int octetrecu1;
    int octetrecu2;
    int octetrecu3;
    int octetrecu4;
    int octetrecu5;
    int octetrecu6;
    int octetrecu7;
    int octetrecu8;
    // PROTOTYPE //
    void ack(void);
    void init_I2C(void);
    void read_trameI2C(int *octet1, int *octet2, int *octet3, int *octet4,int *octet5, int *octet6, int *octet7, int *octet8);
    void tempo(unsigned int count);
    unsigned int SWReadI2C( void );
    void SetPosition(unsigned char x, unsigned char y);
    void SetDDRamAddr(PARAM_SCLASS unsigned char);
    void efface (void);
    // read_tram_i2c(); //
    *octet1 = ReadI2C();
    SSPCON2bits.ACKEN = 1;
    ack();
    *octet2 = ReadI2C();
    ack();
    *octet3 = ReadI2C();
    ack();
    *octet4 = ReadI2C();
    ack();
    *octet5 = ReadI2C();
    ack();
    *octet6 = ReadI2C();
    ack();
    *octet7 = ReadI2C();
    ack();
    *octet8 = ReadI2C();
    // TEST ACK //
    void ack(void)
    IdleI2C();
    while (SSPCON2bits.ACKSTAT);
    // TEMPO //
    void tempo(unsigned int compte)
    while (compte--);
    // INITIALISATION I2C //
    void init_I2C(void)
    DDRCbits.RC3=1;
    DDRCbits.RC4=1;
    SSPCON1=0x28;
    SSPSTATbits.SMP=1;
    SSPADD=9;
    // Fonction Principale //
    void main(void)
    int Valeur = 1;
    //InitLCD();
    stdout = _H_USER;
    OpenXLCD(FOUR_BIT & LINES_5X7);	//la librairie XLCD du C
    init_I2C();
    IdleI2C();
    StartI2C();
    while (SSPCON2bits.RSEN);
    WriteI2C(0xD0);
    ack();
    WriteI2C(0x00);
    ack();
    WriteI2C(0x00);
    ack();
    WriteI2C(0x01);
    ack();
    WriteI2C(0x00);
    ack();
    WriteI2C(0x02);
    ack();
    WriteI2C(0x51);
    ack();
    WriteI2C(0x03);
    ack();
    WriteI2C(0x03);
    ack();
    WriteI2C(0x04);
    ack();
    WriteI2C(0x11);
    ack();
    WriteI2C(0x05);
    ack();
    WriteI2C(0x03);
    ack();
    WriteI2C(0x06);
    ack();
    WriteI2C(0x09);
    ack();
    WriteI2C(0x07);
    ack();
    WriteI2C(0x03);
    ack();
    StopI2C();
    while (SSPCON2bits.PEN);
    tempo(60000);
    IdleI2C();
    StartI2C();
    WriteI2C(0xD1);
    ack();
    // lecture de la trame I2C //
    read_trameI2C(&octetrecu1, &octetrecu2, &octetrecu3, &octetrecu4, &octetrecu5, &octetrecu6, &octetrecu7, &octetrecu8);
    // CLOTURATION I2C //
    NotAckI2C(); // transmet l'acquittement du maître
    while (SSPCON2bits.ACKEN); // attend fin de l'acquittement
    StopI2C(); // initialise une stop-condition
    while (SSPCON2bits.PEN); // attend fin de stop-condition
    //void efface(void);
    SetPosition(2,0);
    printf("test\n");
    printf("=%X", octetrecu2);
    printf("=%X", octetrecu3);
    printf("=%X", octetrecu4);
    printf("=%X", octetrecu5);
    SetPosition(0,1);
    printf("=%X", octetrecu6);
    printf("=%X", octetrecu7);
    printf("=%X", octetrecu8);
    //while(1); // boucle infinie
    if (y) SetDDRamAddr(0x40+x);
     else SetDDRamAddr(x);
    void DelayFor18TCY(void)
        Delay10TCYx(2);
    void DelayPORXLCD(void)
     	Delay1KTCYx(15);     //Delai de 15 ms
    void DelayXLCD(void)
     	Delay1KTCYx(20);     //Delai de 20 ms
    void efface(void)
    	SetPosition(0,0);
    	printf("                ");
    	SetPosition(1,0);
    	printf("                ");
    }[/quote]
    Et voici un autre programme où j'arrive à afficher "bonjour":
    [quote="code"]
    // CD 01/2005
    // test printf sur PICDEM2+ et MCC18 v2.40
    #include <stdio.h> 	// inclure stdio.h si la fonction printf est appelée
    #include <xlcd.h>  	// inclure xlcd.h pour la déclaration des pattes du pic comme
    		   			// étant reliées aux broches RS,RW,E,Données du LCD
    #include <delays.h>	// bibiothéque contenant des fonctions de temporisations
    #include <spi.h>   //bibliotheque simplifiant l'utilisation du protocole SPI
    unsigned char c;
    int i;
    unsigned char tampon[10];
    rom const unsigned char chrom[]=" en ROM";
    unsigned char chram[]=" en RAM";
    unsigned char * pram;
    rom unsigned char *prom;
    float f;
    char code_test=0b10110110;
    char SSP1BUF=0b00000000;
    void SetPosition(unsigned char x, unsigned char y);	// positionne le curseur sur un n° de colonne puis de ligne
    void efface(void);									// efface lcd
    void touche(void);									// détecte l'appui et attends le relâchement du BP
    void DelayFor18TCY(void);							// temporisations ajustables au type de l'afficheur utilisé
    void DelayPORXLCD(void);							// pour connaître les valeurs des durées d attentes necessaires
    void DelayXLCD(void);								// LIRE la doc de l afficheur LCD!!!
    void main(void)
    	TRISDbits.TRISD4=0;
    	TRISDbits.TRISD5=0;
    	TRISCbits.TRISC1=1;								// PORTC bit1 en entrée pour S2
    	PORTDbits.RD4=1;
    	PORTDbits.RD5=0;
    	ADCON1=6;
    	stdout=_H_USER;	// on affiche vers le LCD
    	OpenSPI(SPI_FOSC_4, MODE_01, SMPEND); //Initialisation du module SPI
    	WriteSPI(code_test); //envoyer la variable code test dans le buffer SPI
    //if((SSPSTATbits.BF==1) && (SSP1BUF==code_test))//information au technicien que le test est un succes
    if((SSPBUF==code_test) && (SSPSTATbits.BF==0))//information au technicien que le test est un succes
    			SetPosition(1,0);
    			printf("bon\n");
    			while(1);
    else//information au technicien que le test décele une anomalie
    			SetPosition(0,0);
    			printf("bonjour \n");
    			while(1);
    /* SetPosition	(colonne, ligne)				*/
    /* rôle: positionne le curseur de l'affichage	*/
    /*		à l'une des 32 adresses d'affichages	*/
    /*		L'affichage débute à partir du curseur	*/
    /* entrées:										*/
    /*  x le n° de la colonne (une adresse)			*/
    /*	ligne 0: de 0x00 à 0x0F	(16 caractères max)	*/
    /*	y le n° de la ligne 						*/
    /*	ligne 1:de 0x40 à 0x4F(addition de 0x40 à x)*/
    /*	sortie: RIEN! sauf sur l'écran...			*/
    void efface(void)
    	SetPosition(0,1);
    	printf("                ");
    	SetPosition(0,0);
    	printf("                ");
    void touche(void)
     while(PORTC & 0x02);
     while(!(PORTC & 0x02));
     efface();
        Delay10TCYx(2);
    invite7a49d0d5
    Tropique
    Re : Ds1307 ET 18F452
    nasserarien,
    Je rappelle que les doublons sont interdits par la charte, et seront sanctionnés à l'avenir.
    invite489d7312
    oui ok je reste que ici, je m'excuse pour les doublons, les gars je suis presque, l'heure tourne mais maladroitement.
    Citation Envoyé par code
    #include <stdlib.h>
    #include <stdio.h>
    #include <xlcd.h>
    #include <delays.h>
    #include <i2c.h>
    #pragma config OSC = HS, FCMEN=OFF, IESO=OFF
    //type oscillateur HS,
    //Fail Safe clock Monitor Enabled OFF
    //intern extern switch over mode OFF
    #pragma config PBADEN = OFF
    //PORTB ADc pins enabled OFF
    #pragma config WDT = OFF,WDTPS=512
    //Wtchdog Timer OFF mais Watchdogprescaler=512
    #pragma config LVP = OFF
    // Low Program Voltage OFF
    #pragma config PWRT = OFF , BOREN=OFF
    //PowerUpTimer ??? OFF, Brown Out Reset OFF
    #pragma config MCLRE = ON,CCP2MX = PORTC
    //MasterClearEnabled RE3 disabled ON
    //CCP2 MUX oui RC1
    unsigned char sec,min,hrs,day,wkd,mes,yer;
    /*void DelayFor18TCY(void); // temporisations ajustables au type de l'afficheur utilisé
    void DelayXLCD(void);*/
    void main(void)
    ADCON1=0x0f; //...........
    stdout=_H_USER; //..........
    SetPosition(0,0);
    TRISCbits.TRISC3=1; //.............
    TRISCbits.TRISC4=0; //.............
    Delay10KTCYx(50);
    OpenI2C(MASTER, SLEW_OFF);
    SSPADD=0x09;
    EEByteWrite(0xd0, 0x00, 0x00);
    EEByteWrite(0xd0, 0x01, 0x59);
    EEByteWrite(0xd0, 0x02, 0x59);
    EEByteWrite(0xd0, 0x03, 0x23);
    EEByteWrite(0xd0, 0x04, 0x08);
    EEByteWrite(0xd0, 0x05, 0x01);
    EEByteWrite(0xd0, 0x06, 0x09);
    EEByteWrite(0xd0, 0x07, 0x10);
    while(1)
    IdleI2C();
    sec=EERandomRead(0xd0,0x01); //...........
    IdleI2C();
    min=EERandomRead(0xd0,0x02); //...........
    IdleI2C();
    hrs=EERandomRead(0xd0,0x03); //...........
    IdleI2C();
    wkd=EERandomRead(0xd0,0x04); //............
    IdleI2C();
    day=EERandomRead(0xd0,0x05); //............
    IdleI2C();
    mes=EERandomRead(0xd0,0x06); //............
    IdleI2C();
    yer=EERandomRead(0xd0,0x07); //............
    IdleI2C();
    SetPosition(0,0);
    printf("%d/%d/%d",day,mes,yer); //............
    SetPosition(0,1);
    printf("%d:%d:%d",hrs,min,sec) ; //............
    printf(" ");
    Delay10KTCYx(50);
    /*void efface(void)
    SetPosition(0,0);
    printf(" ");
    SetPosition(0,1);
    printf(" ");
    Delay10TCYx(2);
    en utilisant un pic18f452 et un lcd
  1. Horloge ds1307
    Par inviteb5437249 dans le forum Électronique
    Réponses: 44
    Dernier message: 24/05/2011, 08h51
  2. Programme à convertir de ... à C18, ds1307, 18f6627 or 18f452,
    Par invite489d7312 dans le forum Électronique
    Dernier message: 24/03/2010, 09h10
  3. souci ds1307
    Par invite4cba64e8 dans le forum Électronique
    Dernier message: 22/06/2009, 08h38
  4. ds1307 algorithme
    Par invitec4b571da dans le forum Électronique
    Dernier message: 14/03/2008, 00h42
  5. Ds1307
    Par invite369c4784 dans le forum Électronique
    Dernier message: 11/02/2007, 21h18
