programme_vhdl
programme_vhdl
    elec_cup
    programme_vhdl
    la compilation est ok.
    Par contre, lorsque je simule, j'ai bien la visualisation de mon clock, mais le signal wave_out reste constant ("00000").
    Je pense que le problème vient de l'architecture de sine_wave.
    En effet, ne faudrait-il pas définir {table_index:table_index_type} en tant que signal ?
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_unsigned.all;
    use ieee.numeric_std.all;
    use work.sinus.all;
    entity sine_wave is
    port(
    wave_out: out sine_vector_type
    end;
    architecture arch1 of sine_wave is
    --signal table_index:table_index_type;
    signal clock : std_logic :='0';
    begin
    process
    begin
    wait for 10 ns;
    clock<='1';
    wait for 10 ns;
    clock<='0';
    end process;
    process(clock)
    variable table_value:table_value_type;
    variable table_index:table_index_type;
    begin
    if clock'event and clock='1' then
    if table_index=max_table_index then
    table_index:=0;
    else table_value := get_table_value (table_index);
    end if;
    end if;
    wave_out<=std_logic_vector(to_ unsigned(table_value,sine_vect or_type'length));
    end process;
    end arch1;
    library ieee;
    package sinus is
    constant max_table_value : integer := 15;
    subtype table_value_type is integer range 0 to max_table_value;
    constant max_table_index : integer :=15;
    subtype table_index_type is integer range 0 to max_table_index;
    subtype sine_vector_type is std_logic_vector (4 downto 0);
    function get_table_value (table_index:table_index_type) return table_value_type;
    end;
    package body sinus is
    function get_table_value (table_index:table_index_type) return table_value_type is
    begin
    case table_index is
    when 0=>
    table_value:=0;
    when 1=>
    table_value:=1;
    when 2=>
    table_value:=2;
    when 3=>
    table_value:=3;
    when 4=>
    table_value:=4;
    when 5=>
    table_value:=5;
    when 6=>
    table_value:=6;
    when 7=>
    table_value:=7;
    when 8=>
    table_value:=8;
    when 9=>
    table_value:=9;
    when 10=>
    table_value:=10;
    when 11=>
    table_value:=11;
    when 12=>
    table_value:=12;
    when 13=>
    table_value:=13;
    when 14=>
    table_value:=14;
    when 15=>
    table_value:=15;
    end case;
    return table_value;
    end;
    end;
    DELALIN Ambroise
    invitecb7f24bc
    Re : programme_vhdl
    Vous avez oublié d'incrémenter la variable d'index, tout simplement.
    Re : programme_vhdl
    en effet.
    elec_cup
    Re : programme_vhdl
    En effet, c'est bon.
    Je vous remercie !
    DELALIN Ambroise
