[Programmation] afficheur OLED 1306 sur montage DHT22 ventillateur de SDB
    invited9ef34f1
    j'ai réalisé ce montage https://www.instructables.com/id/Aut...-Arduino-Nano/
    avec ce code
    Code HTML:
    // BATHROOM FAN CONTROL
    //  2: SIG DHT22
    // D13: SIG Relay
    // measurement in every 15 seconds
    // average of 3 last measurements provides the trigger
    // to turn on: average must be above 65%
    // to turn off: average must be below 65 %
    // minimum relay time when turned ON is 60 seconds
    // minimum relay off time after turning off is 300 seconds
    #include <avr/wdt.h>
    #include "DHT.h"
    #define DHTPIN  2         // what pin we're connected to
    #define DHTTYPE DHT22
    DHT dht(DHTPIN, DHTTYPE);
    // PARAMETERS
    int hON = 68;                           // Turn Off the fan at humidity
    int hOFF = 68;                          // Turn Off the fan at humidity
    unsigned long MinOFFTime = 300000;      // minimum time after switch Off to turn back ON again
    // VARIABLES
    unsigned long lastmeasurement = 0;
    unsigned long switchedonmillis = 0;
    unsigned long switchedoffmillis = 0;
    float t = 0;
    float h = 0;
    float hone = 0;
    float htwo = 0;
    float hthree = 0;
    byte counter = 0;
    float haverage = 0;
    byte fan = 0;
    void setup()
        Serial.begin(9600);
        pinMode(13, OUTPUT);
        dht.begin();
         wdt_enable(WDTO_8S);              // Start the watchdog timer with 8 seconds
    void measurement()
      if (counter >= 3)
      {counter = 0;}
      counter++;
      h = dht.readHumidity();
      t = dht.readTemperature();
      if (isnan(t) || isnan(h))
            Serial.println("Failed to read from DHT");
        Serial.println(counter);
     if (counter == 1)
     {hone = h;}
     if (counter == 2)
     {htwo = h;}
    if (counter == 3)
     {hthree = h;}
      haverage = (hone+htwo+hthree)/3;
      lastmeasurement = millis();
    void fanon()
               digitalWrite(13, HIGH);
               switchedonmillis = millis(); // eg. 60 seconds - 600000 ms switchon time
               Serial.println("FAN ON");
               fan = 1;
    void fanoff()
              digitalWrite(13, LOW);
              Serial.println("FAN OFF");
              switchedoffmillis = millis();
              fan = 0;
    void loop()
    { wdt_reset();                                  // reset the Watchdog Timer - it starts from 0 again, if it exceeds 8 sec, node will reset
      if ((millis() > 15001) && ((millis()-15000) > lastmeasurement))
        measurement();
        Serial.print("Humidity: ");
        Serial.print(h);
        Serial.print(" %\t");
        Serial.print("Temperature: ");
        Serial.print(t);
        Serial.println(" *C");
        Serial.println(hone);
        Serial.println(htwo);
        Serial.println(hthree);
        Serial.print("h average last 3 measurements: ");
        Serial.println(haverage);
        if (fan == 0)    // if it's OFF
            // CHECK IF IT WAS OFF FOR AT LEAST 120 seconds AND IF it was turned OFF at all
            if ((switchedoffmillis > MinOFFTime) && ((millis()-switchedoffmillis) > MinOFFTime) && (haverage >= hON) && (haverage < 150))
           { fanon(); }
            // IF NOT YET SWITCHED OFF FROM ON (switchedoffmillis is 0 or less than 2 minutes) AND PARAMETERS MET
           if ((switchedoffmillis < MinOFFTime) && (haverage >= hON) && (haverage < 150))
            { fanon(); }
            // if it's working
        if (fan ==1)
           if (((millis()-switchedonmillis) > 60000) && (haverage <= hOFF)) // KEEP IT FOR MINIMUM 60 seconds
              fanoff();
          // Reading temperature or humidity takes about 250 milliseconds!
        // Sensor readings may also be up to A0 seconds 'old' (its a very slow sensor)
        // h = h+6;
        // t = t-2;
        // check if returns are valid, if they are NaN (not a number) then something went wrong!
    je voudrais ajouter un afficheur OLED 1306 I2C 128x32 j'ai fait des recherches sur le net
    je rame, je patauge je lis je cherche je n'arrive a rien
    quelqu'un aurais il pitié d'un vieux plomb?
    maintenant j'ai deux codes qui fonctionne bien individuellement: BATHROOM_FAN_CONTROL.ino et oled.ino
    Code HTML:
    #include <Wire.h>
    #include <Adafruit_GFX.h>
    #include <Adafruit_SSD1306.h>
    #include <DHT.h>
    //#define DHTTYPE DHT11   // DHT 11
    #define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
    //#define DHTTYPE DHT21   // DHT 21 (AM2301)
    #define OLED_RESET 4
    Adafruit_SSD1306 display(OLED_RESET);
    // Initialize DHT sensor for normal 16mhz Arduino
    void setup()
      Wire.begin();
      dht.begin(); // initialize dht
      display.begin(SSD1306_SWITCHCAPVCC, 0x3C);// initialize with the I2C addr 0x3C (for the 128x32)(initializing the display)
      Serial.begin(9600);
    void displayTempHumid(){
      delay(2000);
      // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
      float h = dht.readHumidity();
      // Read temperature as Celsius
      float t = dht.readTemperature();
      // Check if any reads failed and exit early (to try again).
      if (isnan(h) || isnan(t) ) {
        display.clearDisplay(); // clearing the display
        display.setTextColor(WHITE); //setting the color
        display.setTextSize(1); //set the font size
        display.setCursor(5,0); //set the cursor coordinates
        display.print("Failed to read from DHT sensor!");
        return;
      display.setCursor(0,0);
      display.print("Humidity: ");
      display.print(h);
      display.print(" %\t");
      display.setCursor(0,10);
      display.print("Temperature: ");
      display.print(t);
      display.print(" C");
    void loop()
      displayTempHumid();
      display.display();
    comment les mixer, fusionner, compiler? avec l'IDE? pouvez vous me le faire?
    par avance Merci
    jojo150393
    Re : afficheur OLED 1306 sur montage DHT22 ventillateur de SDB
    Il faut juste copier le contenu du setup dans l'autre code, copier displayTempHumid dans l'autre code et copier le loop dans un else dans l'autre code. C'est quoi le problème ?
    invited9ef34f1
    ben, tous ca justement:le contenu du setup dans l'autre code, copier displayTempHumid dans l'autre code et copier le loop dans un else dans l'autre code
    et mettre les bibliothèques ?
    pour moi du chinois
    merci de me faire un exemple
    invited9ef34f1
    Re : (resolu) afficheur OLED 1306 sur montage DHT22 ventillateur de SDB
    jojo150393
    Comment faire sans apprendre a faire ...
    Arduino m'énerve de plus en plus...
    Si vous ne voulez pas apprendre à programmer, et simplement qu'on le fasse a votre place, autant l'acheter directe votre station météo...
    invited9ef34f1
    merci pour la réponse
    mais même si vous le faite a ma place, j'apprends
  1. carte arduino et 3 afficheur oled ou lcd
    Par invite30bba24e dans le forum Électronique
    Dernier message: 15/02/2015, 14h58
  2. Programmation afficheur OLED
    Par invite1ae0a8ed dans le forum Électronique
    Dernier message: 06/06/2014, 14h12
  3. Afficheur Oled
    Par invitedd1dd413 dans le forum Électronique
    Dernier message: 24/01/2012, 14h51
  4. afficheur LCD / OLED
    Par inviteeba449d3 dans le forum Électronique
    Dernier message: 30/12/2009, 06h07
  5. Connecteur afficheur OLED
    Par invitee3db1039 dans le forum Électronique
    Dernier message: 22/10/2007, 15h10
