[Exercices] Convertir le code Arduino en code STM
    invite54258bb3
    je veut convertir un code d'ARDUINO en un code STM
    je veut savoir comment on peut réaliser ca
    si il y a un site qui explique la conversion ? svp d'aide
    Code source
    Code:
    #include <LiquidCrystal.h>
    const int sensorIn = A0;
    int mVperAmp = 185; // 5A version SC712 – use 100 for 20A Module or 66 for 30A Module
    int Watt = 0;
    double Voltage = 0;
    double VRMS = 0;
    double AmpsRMS = 0;
    // initialize the library with the numbers of the interface pins
    LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
    void setup() {
    pinMode(6, OUTPUT);
    Serial.begin (9600);
    Serial.println (“Hall sensor”);
    lcd.begin (20, 4); // set up the LCD – number of columns, rows
    lcd.clear ();
    lcd.setCursor (0, 0);
    lcd.print (“Hall sensor”);
    digitalWrite(6, HIGH); // turn the LED on (HIGH is the voltage level)
    void loop() {
    Serial.println (“”);
    Voltage = getVPP();
    VRMS = (Voltage/2.0) *0.707; //root 2 is 0.707 – dealing with sine
    AmpsRMS = (VRMS * 1000)/mVperAmp;
    Serial.print(AmpsRMS);
    Serial.print(” Amps RMS — “);
    Watt = (AmpsRMS*240/1.3);
    // note: 1.3 is my own empirically established calibration factor
    // as the voltage measured at A0 depends on the lenght of the OUT-to-A0 wire
    // 240 is the mean AC grid power voltage – this parameter fluctuates locally
    Serial.print(Watt);
    Serial.println(” W”);
    lcd_control ();
    // ***************** subroutines ****************************
    float getVPP()
    float result;
    int readValue; // value read from the sensor
    int maxValue = 0; // store max value here
    int minValue = 1024; // store min value here
    uint32_t start_time = millis();
    while((millis()-start_time) < 1000) //sample for 1 Sec
    readValue = analogRead(sensorIn);
    // see if you have a new maxValue
    if (readValue > maxValue)
    /*record the maximum sensor value*/
    maxValue = readValue;
    if (readValue < minValue)
    /*record the minimum sensor value*/
    minValue = readValue;
    // Subtract min from max
    result = ((maxValue – minValue) * 5.0)/1024.0;
    return result;
    void lcd_control (){
    lcd.setCursor (5, 2);
    lcd.print (Watt);
    lcd.print (” watt “);
    Dernière modification par gienas ; 12/03/2021 à 16h54. Motif: Ajouté les balises code, obligatoires pour les programmes
    Re : convertir le code arduino en code STM
    C'est quoi un code STM ? Et les STM sont très nombreux !!!
    invite54258bb3
    je veut dire programmer sur STM 32F103RB précisément
    Il n'y a pas de code "STM", sauf à parler d'assembleur.
    Je ne connais pas les convertisseurs, ma réponse voulait te faire dire ce que tu entends par "code STM".
    le seul moyen c'est de recoder en C/C++ classique et de disposer d'un compilateur adapté.
    carcan
    ce petit code est très simple à retranscrire ... Et peut-être même à reprendre totalement : Tu veux mesurer une puissance électrique ? P = U*I*PF ... ici tu négliges PF et tu prends U comme constante ... Autant mesurer la puissance en mesurant l'inclinaison d'une baguette de sourcier, non ???
    Laurent
    umfred
    a priori, le logiciel arduino doit pouvoir gérer certaines cartes à base de STM32. Il faut charger les bonnes librairies.
    le seul truc qui faille aussi faire attention c'est l'affection des pins.
    gts2
    Re : Convertir le code Arduino en code STM
    Pour préciser : stm32f103 arduino
    qui propose de télécharger :
    github ... STM32/package_stm_index.json
  1. Convertir une image RVB en code binaire
    Par invite4d3c0142 dans le forum Programmation et langages, Algorithmique
    Réponses: 27
    Dernier message: 14/09/2017, 06h14
  2. convertir code Python vers code en r
    Par invitecd18378c dans le forum Programmation et langages, Algorithmique
    Dernier message: 08/05/2017, 12h55
  3. Un langage codé léger, 2 caractères non codé=1 caractère codé. Une solution?
    Par invite06e0b926 dans le forum Mathématiques du supérieur
    Dernier message: 30/06/2010, 11h02
  4. convertir un code ASCII en decimal
    Par invitec5b496fb dans le forum Logiciel - Software - Open Source
    Dernier message: 25/11/2009, 10h56
  5. quel logiciel pour convertir du code C ou C++ en flow chart ?
    Par schneiderj dans le forum Logiciel - Software - Open Source
    Dernier message: 15/04/2009, 23h30
