probleme avec kopete (Linux)
    bird12358
    Je viens d'installer recemment kubuntu 7.10 ,et je viens d'essayé de lancer kopete mais il a bugger
    "en raison du signal 11 (SIGSEGV)"
    (no debugging symbols found)
    Using host libthread_db library "/lib/tls/i686/cmov/libthread_db.so.1".
    [Thread debugging using libthread_db enabled]
    [New Thread -1241617936 (LWP 7346)]
    [KCrash handler]
    #6 0xb5a8e11a in MSNAccount::slotNotifySocketCl osed ()
    from /usr/lib/libkopete_msn_shared.so.0
    #7 0xb5a96668 in MSNAccount::qt_invoke ()
    #8 0xb6886893 in QObject::activate_signal () from /usr/lib/libqt-mt.so.3
    #9 0xb6887338 in QObject::activate_signal () from /usr/lib/libqt-mt.so.3
    #10 0xb5a9f8dc in MSNSocket::socketClosed ()
    #11 0xb5ab34cd in MSNNotifySocket::disconnect ()
    #12 0xb5aaff3b in MSNNotifySocket::sslLoginFaile d ()
    #13 0xb5ab60f5 in MSNNotifySocket::qt_invoke ()
    #14 0xb6886893 in QObject::activate_signal () from /usr/lib/libqt-mt.so.3
    #15 0xb6887338 in QObject::activate_signal () from /usr/lib/libqt-mt.so.3
    #16 0xb5ad016c in MSNSecureLoginHandler::loginFa iled ()
    #17 0xb5ad040f in MSNSecureLoginHandler::slotTwe enerReceived ()
    #18 0xb5ad15a6 in MSNSecureLoginHandler::qt_invo ke ()
    #19 0xb6886893 in QObject::activate_signal () from /usr/lib/libqt-mt.so.3
    #20 0xb74c1021 in KIO::Job::result () from /usr/lib/libkio.so.4
    #21 0xb75198cd in KIO::Job::emitResult () from /usr/lib/libkio.so.4
    #22 0xb7519d2e in KIO::SimpleJob::slotFinished () from /usr/lib/libkio.so.4
    #23 0xb751a43d in KIO::TransferJob::slotFinished () from /usr/lib/libkio.so.4
    #24 0xb7519301 in KIO::SimpleJob::qt_invoke () from /usr/lib/libkio.so.4
    #25 0xb7519363 in KIO::TransferJob::qt_invoke () from /usr/lib/libkio.so.4
    #26 0xb6886893 in QObject::activate_signal () from /usr/lib/libqt-mt.so.3
    #27 0xb6c128ec in QSignal::signal () from /usr/lib/libqt-mt.so.3
    #28 0xb68a6842 in QSignal::activate () from /usr/lib/libqt-mt.so.3
    #29 0xb68ae258 in QSingleShotTimer::event () from /usr/lib/libqt-mt.so.3
    #30 0xb681daf0 in QApplication::internalNotify () from /usr/lib/libqt-mt.so.3
    #31 0xb681f91f in QApplication::notify () from /usr/lib/libqt-mt.so.3
    #32 0xb6fe3ca2 in KApplication::notify () from /usr/lib/libkdecore.so.4
    #33 0xb67b0209 in QApplication::sendEvent () from /usr/lib/libqt-mt.so.3
    #34 0xb681053b in QEventLoop::activateTimers () from /usr/lib/libqt-mt.so.3
    #35 0xb67c4d49 in QEventLoop:rocessEvents () from /usr/lib/libqt-mt.so.3
    #36 0xb68381ce in QEventLoop::enterLoop () from /usr/lib/libqt-mt.so.3
    #37 0xb6837fde in QEventLoop::exec () from /usr/lib/libqt-mt.so.3
    #38 0xb681f699 in QApplication::exec () from /usr/lib/libqt-mt.so.3
    #39 0x0807f95c in ?? ()
    #40 0xbfe3c034 in ?? ()
    #41 0xbfe3c02c in ?? ()
    #42 0xbfe3c024 in ?? ()
    #43 0x00000000 in ?? ()
    Voila ce qu'il me met dans le Backtrace.Si quelqu'un a deja eu le probleme et a su le resoudre ca serait sympa de ma filler un coup de main .D'avance merci.
    invite88ef51f0
    Re : probleme avec kopete (Linux)
    Le backtrace n'est pas très pratique à moins de faire du debuggage pur et dur.
    Essaye de lancer Kopete depuis une console, ça te permettra d'avoir les messages d'erreurs.
    invite26b4ec3b
    Je ne suis pas sur qu'il existe un paquetage kopete pour kubuntu 7.10.
    http://doc.ubuntu-fr.org/kopete
    Comment a été réalisée l'installation ?
    Au pire, tu peux essayer Psi ou Pidgin...
    invite09c249d5
    Citation Envoyé par Coincoin Voir le message
    Oui. et en plus, je doute que les paquets ubuntu soient compilés avec les options debug, gdb et sans stripper.
    invite09c249d5
    Ne serait-ce pas un bug qui arrive lorsque tu te connectes sur msn? Si c'est ça, il faut télécharger un patch de kdelib.
  1. Barre de menu sous Kopete
    Par invite87912a33 dans le forum Logiciel - Software - Open Source
    Dernier message: 12/06/2006, 12h46
  2. usb bluetooth ... avec Linux
    Par invite79643b60 dans le forum Matériel - Hardware
    Dernier message: 24/02/2005, 08h50
  3. Problème avec ancienne partition de LINUX
    Par invitee9f65207 dans le forum Logiciel - Software - Open Source
    Dernier message: 08/02/2005, 18h35
  4. pb avec kopete
    Par invite20125fd9 dans le forum Internet - Réseau - Sécurité générale
    Dernier message: 31/10/2004, 00h15
  5. Suppression totale avec Linux?
    Par invite242c100d dans le forum Logiciel - Software - Open Source
    Dernier message: 02/09/2004, 11h43
