CVS Cedega probleme
CVS Cedega probleme
    invite79643b60
    CVS Cedega probleme
    Bonjours,
    Voila , je tourne sous Mandrake 10.1 (c'est une question serieuse et pas un débat débile Linux vs. Windows ou Mac)
    J'ai un problème pour installer CVS Cedega en effet tout ce passe bien jusqu'au make: il me sort un rapport que je ne sait pas lire:
    WineCVS.sh - Progress(u) : Green is current
    0 = Uninstall
    1 = Cleanup
    2 = CVS checkout
    3 = Configure
    4 = Make depend
    5 = Make
    6 = Make install
    7 = Finish up
    Compiling ...
    --------- Error log - file /root/.WineCVS/sources/cvscedega/ErrorLog : ---------
    ts_xlib.c:1175: warning: return type defaults to `int'
    ts_xlib.c: In function `TSXOpenIM':
    ts_xlib.c:1176: error: `XIM' undeclared (first use in this function)
    ts_xlib.c:1176: error: syntax error before "r"
    ts_xlib.c:1178: error: `r' undeclared (first use in this function)
    ts_xlib.c:1178: warning: implicit declaration of function `XOpenIM'
    ts_xlib.c:1178: error: `a0' undeclared (first use in this function)
    ts_xlib.c:1178: error: `a1' undeclared (first use in this function)
    ts_xlib.c:1178: error: `a2' undeclared (first use in this function)
    ts_xlib.c:1178: error: `a3' undeclared (first use in this function)
    ts_xlib.c: At top level:
    ts_xlib.c:1183: error: syntax error before "TSXCheckIfEvent"
    ts_xlib.c:1183: error: syntax error before '*' token
    ts_xlib.c:1183: warning: type defaults to `int' in declaration of `TSXCheckIfEvent'
    ts_xlib.c:1183: error: `TSXCheckIfEvent' declared as function returning a function
    ts_xlib.c:1183: warning: type defaults to `int' in declaration of `XPointer'
    ts_xlib.c:1183: error: syntax error before "a3"
    ts_xlib.c:1186: warning: type defaults to `int' in declaration of `wine_tsx11_lock'
    ts_xlib.c:1186: error: 'wine_tsx11_lock' redeclared as different kind of symbol
    ../include/ts_xlib.h:19: error: previous declaration of 'wine_tsx11_lock' was here
    ts_xlib.c:1186: warning: data definition has no type or storage class
    ts_xlib.c:1187: warning: type defaults to `int' in declaration of `r'
    ts_xlib.c:1187: warning: implicit declaration of function `XCheckIfEvent'
    ts_xlib.c:1187: error: `a0' undeclared here (not in a function)
    ts_xlib.c:1187: error: `a1' undeclared here (not in a function)
    ts_xlib.c:1187: error: `a2' undeclared here (not in a function)
    ts_xlib.c:1187: error: `a3' undeclared here (not in a function)
    ts_xlib.c:1187: error: initializer element is not constant
    ts_xlib.c:1187: warning: data definition has no type or storage class
    ts_xlib.c:1188: warning: type defaults to `int' in declaration of `wine_tsx11_unlock'
    ts_xlib.c:1188: error: 'wine_tsx11_unlock' redeclared as different kind of symbol
    ../include/ts_xlib.h:20: error: previous declaration of 'wine_tsx11_unlock' was here
    ts_xlib.c:1188: warning: data definition has no type or storage class
    ts_xlib.c:1189: error: syntax error before "return"
    ts_xlib.c:1192: error: syntax error before '*' token
    ts_xlib.c: In function `TSXSynchronize':
    ts_xlib.c:1194: error: syntax error before '*' token
    ts_xlib.c:1196: warning: implicit declaration of function `XSynchronize'
    ts_xlib.c:1196: warning: assignment makes pointer from integer without a cast
    ts_xlib.c:1201: error: syntax error before '*' token
    ts_xlib.c:1203: error: syntax error before '*' token
    make[1]: *** [ts_xlib.o] Erreur 1
    make[1]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/tsx11'
    make: *** [tsx11/libwine_tsx11.so] Erreur 2
    Error in Make
    Try fixing the error based on the output above, and
    run the script again, without paramaters (Eg: WineCVS.sh)
    Quelqu'un peut me décripter ceci ???
    invite8699bde6
    Re : CVS Cedega probleme
    apt-get install x-window-system-dev
    j'avais exactement cette erreur, et mon make a marché...
    salutations
  1. Réponses: 11
    Dernier message: 26/05/2011, 13h27
  2. Un petit problème qui me pause problème lol
    Par invitef2853e5d dans le forum Mathématiques du supérieur
    Dernier message: 31/03/2009, 16h28
  3. problème avec un lecteur mp4(le problème vient de l'ordinateur)
    Par inviteaca1b987 dans le forum Matériel - Hardware
    Dernier message: 29/10/2007, 17h53
  4. TPE : le problème de la problématique... pose problème
    Par invitedea46a4f dans le forum TPE / TIPE et autres travaux
    Dernier message: 21/09/2006, 19h45
