aide envoie de trame
    invitee36498b5
    voici mon programme au complet et voila le pc de supervision doit envoyer une demande et moi je dois lui envoyer la température et humidité comment faire
    Code:
    #include <18F4520.h>
    #use delay(clock=20M)
    #include "LCDTEST.C"
    #include <stdio.h>
    #include <math.h>
    #fuses HS,NOLVP,NOWDT,NOPUT
    #use RS232 (baud = 9600,xmit = PIN_C6, rcv = PIN_C7)
    enum {TEMP,HUMI};
    #define MEASURE_TEMP 0x03
    #define MEASURE_HUMI 0x05
    //#use I2C (master,sda=PIN_C4, scl=PIN_C3)
    #bit sck=0xf82.3
    #bit data=0xf82.4
    #bit sync=0xf82.5
    #bit SENS_DATA = 0xf94.4
    #define ack 1
    #define noack 0
    #define d1 -40.1
    #define d2 0.01
    #define COMMANDE_TEMP 0b00000011
    #define	COMMANDE_HUMID 0b00000101
    #define c1 -2.0468
    #define c2 0.0367
    #define c3 -1.5955e-6
    typedef char bool;
    char temperature;
    char hygrometrie;
    char buffer1[8];
    bool fin = false;
    char carac =0;
    char buffer[8];
    char pos=0x00;
    char trame;
    #int_RDA
    MODBUS_ReceptionCaractere()
    	carac = getchar ();
    	if ( carac == 8)
    		buffer[ pos + 1]= '\n';
    		pos= 0x00;
     		strcpy ( buffer1, buffer);
    		fin = true;
    	else
    		pos++;
    void analysetrame ( char P_Anal )
    	char Adresse;
    	char cf;
    	char taille[2];
    	char message[4];
    	switch (pos)
    		case 0:
    			if (Adresse == 1)
    				pos++ ;
    			else
    				pos= 0x00;
    			break;
    		case 1:
    			if (cf != 0x03)
    				pos= 0x00;
    		break;
    		case 2:
    			if (taille != taille )
    				pos = 0x00;
     void extraireDonnees ( char * trame)
    	trame [4];
    	trame [6];
    void s_transstart(void)
    	sck=1;
    	delay_us(5);
    	data=0;
    	delay_us(1);
    	sck=0;
    	delay_us(1);
    	sck=1;
    	delay_us(1);
    	data=1;
    	delay_us(1);
    	sck=0;
    	delay_us(1);
    	data=0;
    	delay_us(5);
    char s_write_byte(unsigned char value)
    	unsigned char i,error=0;
    	SENS_DATA=0; // data en sortie
    	for( i=0x80;i>0;i/=2)
    		if ( i & value )data=1;
    		 else data =0;
    		 delay_us (1);
    		 sck=1;
    		 delay_us(1);
    		 sck=0;
    		 delay_us (1);
    	SENS_DATA = 1; // data en entrée pour reception ACK
    	 delay_us (3);
    	 sck=1;
    	delay_us (1);
    	 error=data;
    	delay_us (1);
    	 sck=0;
    	 return error;
    char s_read_byte(unsigned char P_ack)
    //ack = 0 read val et ack = 1 pour chksum
    	unsigned char i;
    	unsigned char  value =0;
    	sck = 0;
    	delay_us (5);
    	for(i=0x80;i>0;i/=2)
    		sck =1;
    		 delay_us (1);
    		if (data) value =( value|i);
     		delay_us (1);
    		sck =0;
    //emission ack
    delay_us (1);
    delay_us (1);
    	data=1;
    	delay_us (3);
    	data=P_ack;  // 0 pour lecture val et 1 pour chksum
    	delay_us (1);
    	sck=1;
    	delay_us (1);
    	sck=0;
    	delay_us (1);
    	data=1;
    	return value;
    float Convert_Temp(int16 P_SOT)
    	float L_temp = 0.0f;
    	float d2xSOT;
    	d2xSOT = P_SOT * d2;
    	L_temp = d1 + d2xSOT;
    	return L_temp;
    float Convert_Humidite(int16 P_SOH)
    	float L_humid_lin = 0.0f;
    	float C2xSOH;
    	float C3xSOHcarre;
    	C2xSOH = P_SOH * c2;
    	C3xSOHcarre = c3*P_SOH*P_SOH;
    	L_humid_lin = c1 + C2xSOH + C3xSOHcarre;
    	if(L_humid_lin<0)
    		L_humid_lin=0;
    	if(L_humid_lin>100)
    		L_humid_lin=100;
    	return L_Humid_lin;
    void init_bus_repos()
    	//***** mise en place signaux au repos
    	data=1;
    	sck=0;
    	delay_ms(100);
    char emettre_commande(unsigned char P_mode)
    {   char L_ret;
    	L_ret = s_write_byte(P_mode);
    	return L_ret;
    void attendre_fin_mesure()
    	unsigned char fin;
    	SENS_DATA=1;   //data en entree
    	delay_ms(80);
    	do
    		fin = data;
    	}while(data &0x00010000 != 0);
    	delay_ms(1);
    float Acquerir_temperature()
    	unsigned char L_Msb_Temp;
    	unsigned char L_Lsb_Temp;
    	unsigned char L_ChkSum;
    	int16 L_SOT;
    	L_Msb_Temp= s_read_byte(0);
    	L_Lsb_Temp= s_read_byte(0);
    	L_ChkSum= s_read_byte(1);
    //	printf(lcd_putc,"MSB:%0x LSB:%0x\n",L_Msb_Temp,L_Lsb_Temp);
    	L_SOT = L_Msb_Temp * 256 + L_Lsb_Temp;
    	delay_ms(1);
    	L_Temp = Convert_Temp(L_SOT);
    	return L_temp;
    float acquerir_humidite_lin()
    	float L_humid=0.0f;
    	unsigned char L_Msb_Umid;
    	unsigned char L_Lsb_Umid;
    	unsigned int16 L_SOH;
    	float L_Humid_lin=0.0f;
    	L_Msb_Umid= s_read_byte(0);
    	L_Lsb_Umid= s_read_byte(0);
    //	printf (lcd_putc,"M=%x L=%x \n",L_Msb_Umid,L_Lsb_Umid);
    	L_SOH = L_Msb_Umid *256 + L_Lsb_Umid;
    	L_Humid_lin = Convert_Humidite(L_SOH);
    	return L_humid_lin;
    void main()
     //température & hygrométrie
    	float L_Humid;
    	float L_Humid_lin;
    //transfert
    	char temperature;
    	char hygrometrie;
    	char donnees;
    	char chaine;
    	char trame_utile[];
    	char donnes[2];
    	enable_interrupts(GLOBAL);
    	enable_interrupts(INT_RDA);
    	 lcd_init();
    	set_tris_c(0b11000111); //c3 et c4 en sortie
    	// c5 en sortie pour synchro
    	sync =0;
    	init_bus_repos();
    	while(1)
    	 if ( fin != true);
    // emision start
    	s_transstart();
    sync= 1;
    // emission commande mesure temp
    	emettre_commande(COMMANDE_TEMP);
    sync = 0;
    // attente mesure ok
    	attendre_fin_mesure();
    	L_Temp = Acquerir_temperature();
    	//printf (lcd_putc,"\fT= %5.2f\n",L_Temp);
    	printf ("\fT= %5.2f\n",L_Temp);
    	delay_ms(2000);
    	s_transstart();
    	sync= 1;
    	emettre_commande(COMMANDE_HUMID);
    	sync = 0;
    	L_Humid_lin=acquerir_humidite_lin();
    	//printf (lcd_putc,"h= %5.2f\n",L_Humid_lin);
    	printf ("h= %5.2f\n",L_Humid_lin);
    	delay_ms(2000);
     	if (strcmp (chaine,donnees)==0x00)
    		extraireDonnees(trame_utile);
    		// température
    		strncpy ( trame_utile,temperature ,1);
    		//hygrométrie
    		strncpy (trame_utile,hygrometrie , 2);
    Dernière modification par JPL ; 15/04/2013 à 16h44. Motif: Ajout de la balise Code (#) pour garder l'indentation
  1. Envoie d'une trame usb Labview
    Par invite2f7b8032 dans le forum Électronique
    Dernier message: 04/10/2012, 11h10
  2. envoie de trame par le pic
    Par invitec8c13b53 dans le forum Électronique
    Dernier message: 21/07/2010, 10h12
  3. envoie de donnée midi
    Par invitefdead068 dans le forum Électronique
    Dernier message: 21/06/2009, 10h38
  4. envoie de mail
    Par invite83292bd7 dans le forum Internet - Réseau - Sécurité générale
    Dernier message: 18/07/2008, 01h21
  5. envoie de photo impossible
    Par sambungle dans le forum Logiciel - Software - Open Source
    Dernier message: 27/04/2008, 14h21
