menace sur mon compte yahoo
    invitefa4d5f91
    Bsr
    Voici le message que je viens de recevoir dans ma boite yahoo, et je ne sais quoi faire , c,est la raison pour laquelle je m,adresse à vous:
    Vilmer Vacca <[email protected]>
    À :
    ‎1‎ ‎août à ‎18‎:‎31
    I'm going to cut to the chase. I know that mariam is your pass word. More importantly, I know about your secret and I've evidence of this. You do not know me and no one hired me to investigate you.
    It's just your misfortune that I stumbled across your bad deeds. Actually, I placed a malware on the adult videos (porn material) and you visited this site to experience fun (you know what I mean). While you were busy watching video clips, your internet browser started out operating as a Rdp (Remote desktop) having a key logger which gave me access to your display as well as webcam. After that, my software program gathered all of your contacts from your fb, and mailbox.
    Next, I put in more time than I probably should have into your life and generated a two screen video. 1st part shows the video you had been watching and next part shows the capture from your web cam (its you doing inappropriate things).
    Frankly, I'm ready to forget about you and let you move on with your regular life. And I will give you 2 options that can accomplish this. The two options are to either ignore this letter, or just pay me $ 1900. Let us examine above two options in details.
    First Option is to ignore this e mail. Let me tell you what will happen if you take this option. I will certainly send out your video to your contacts including close relatives, coworkers, etc. It will not save you from the humiliation your household will must face when relatives and buddies learn your unpleasant videos from me.
    Other Option is to send me $ 1900. We will call it my “confidentiality tip”. Let me tell you what will happen if you choose this path. Your secret will remain your secret. I'll delete the video immediately. You continue on with your routine life as though nothing ever happened.
    At this point you may be thinking, “I will complain to the police”. Let me tell you, I have covered my steps in order that this mail can't be tracked time for me plus it will not stop the evidence from destroying your lifetime. I am not seeking to dig a hole in your pocket. I just want to be compensated for time I placed into investigating you. Let's assume you decide to make all this go away and pay me the confidentiality fee. You'll make the payment via Bitcoin (if you do not know how, search "how to buy bitcoins" in search engine)
    Amount to be sent: $ 1900
    Send To This Bitcoin Address: 1PSyzsCnJjq*HsWX3mJcUrpcx5pi82 ghNkh (You must Delete * from it then copy and paste it)
    Tell no person what you will be using the Bitcoins for or they possibly will not offer it to you. The task to get bitcoin may take a day or two so do not put it off.
    I've a unique pixel within this email, and now I know that you've read through this message. You have 2 days to make the payment. If I don't receive the BitCoin, I will certainly send out your video to your entire contacts including close relatives, coworkers, and so forth. You better come up with an excuse for friends and family before they find out. Nevertheless, if I receive the payment, I'll destroy the recording immediately. It's a non-negotiable one time offer, so do not waste my personal time and yours. Your time has started. Well, my tracker will be tracking what action you adopt when you're done looking over this email. Swear to god, If you search anything inappropriate then I will share your sextape to your family members, coworkers before your your deadline.
    Merci de m'aider
    Dernière modification par mh34 ; 03/08/2018 à 09h07.
    LongaRipa
    Re : menace sur mon compte yahoo
    Ce message est du pipeau , du bluff .
    Ca traine en ce moment , avec des variantes .
    Il suffit de l'ignorer .
    On va quand meme vérifier votre systeme , par précaution.
    Nous allons commencer par établir un diagnostic du PC . Pour cela ,
    Télécharger Farbar Recovery Scan Tool (de Farbar) sur le Bureau.(IMPORTANT)
    Attention: Il faut lancer la version compatible avec le système : 32 ou 64bits.
    Cliquer ici pour la version 32 bits
    Cliquer ici pour la version 64 bits
    Info : comment savoir quelle version de Windows j'utilise ?
    Sous IE9 ou IE10, le filtre SmartScreen déclenche une alerte. Cliquer sur Actions puis sur Exécuter quand même
    • Faire un click droit sur l'outil, puis executer en tant qu'administrateur pour le lancer. Quand l'outil se lance, cliquer sur Oui pour accepter le disclaimer.
    • Cliquer sur le bouton Analyser.
    • L'outil va créer un rapport nommé FRST.txt, enregistré dans le même dossier que l'outil.
    • A son premier lancement, l'outil va aussi créer un fichier nommé Addition.txt.
    Poster les deux rapports générés.
    Dans un souci de confidentialité, les rapports doivent être postés en pièces jointes
    Sont attendus les rapports :
    frst.txt
    addition.txt
    longaripa
    invite9ce22e65
    petit passage (Bonjour LongaRipa)
    Arnaque bien sûr
    --> https://www.bleepingcomputer.com/new...n-adult-sites/
    --> traduction --> https://translate.google.fr/translat...s/&prev=search
    Ce mot de passe a peut être été utilisé dans le passé,
    Tu peux aussi vérifier ton adresse mail via: https://haveibeenpwned.com/
    invitefa4d5f91
    bsr LongaRipa,
    Merci de prendre mes inquiétudes en compte, c'est grandement apprécié.
    Comme vous l'avez demandé , veuillez trouvez ci-joint les deux rapports demandés.
    bamidou
    LongaRipa
    Re
    Comme confirmé par xsun (hello ...) , c'est une arnaque .
    Concernant les rapports , vous utilisez un programme pour activer illégalement windows et/ou Microsoft Office
    Pour des raisons éthiques, légales et techniques, et conformément aux règles de cette section et comme sur la plupart des forums, nous ne prenons pas en charge des systèmes comportant cracks et logiciels installés illégalement.
    C'est un risque majeur pour la sécurité.
    D'autre part, les outils de désinfection que nous utilisons sont puissants et peuvent avoir des effets inattendus sur des systèmes illégaux.
    Mon intervention s'arrête donc là.
    Il n'y a pas d'infection visible , à part l'activateur illégal ......
    longaripa
    invitefa4d5f91
    Bonjour LongaRipa,
    Merci beaucoup car votre reponse me rassure"
    Concernant l'activation illégal, je vais corriger cela car notre institut inphb vient de signer un contrat avec Microsoft qui nous permet d'activer en sécurité tous les produits office.
    Est-ce nécessaire de vous recontacter lorsque ce sera réalisé ???
    bamidou
    Cheers
    LongaRipa
    C'est l'activation de Office qui est illégale , ou celle de Windows ?
    Si c'est Windows ,il faut réinstaller .
    Si c'est office , il faut désinstaller KMSpico .
    Si vous le désirez , vous faites la désinstallation , et revenez pour vérifier si il reste des résidus qu'on pourra virer alors ..
    longaripa
  1. gérer un compte externe dans Yahoo mails
    Par invite0aa5b1c7 dans le forum Internet - Réseau - Sécurité générale
    Dernier message: 09/08/2015, 15h53
  2. Compte Local / Compte Microsoft
    Par invite6bc0c7b8 dans le forum Logiciel - Software - Open Source
    Dernier message: 26/08/2014, 10h55
  3. Mon compte yahoo utilisé pour du phishing
    Par invite162d8c4b dans le forum Sécurité et malwares : désinfectez votre machine
    Dernier message: 09/10/2010, 00h58
