Aide pour le calcul de concentration
    Geffen
    Bonjour a tous.
    Je suis actuellement entrain de lire plusieurs protocole d'analyse iso. Et il y en a un qui me pose une difficulte de comprehension de calcul. C'est le protocol pour determiner la concentration d'une solution de HCl a l'aide d'une solution de cabonate de sodium.
    Et le probleme est le suivant. Il prend pour masse molaire du carbonate de sodium 53g/mol. Or si nous la calculons avec le tableau periodique des elements nos obtenons 106g/mol. Au debut je pensais qu'ils effectuaient une simplification par 2. Mais le 2 reste dans la formule.
    Cela est une reaction basique dont l'equation est :
    2 HCl + Na2CO3 -> 2 NaCl + CO2 + H2O
    Ainsi pourriez vous regarder et m'aider a comprendre. Merci.
    Voici le paragraphe en question:
    The exact molar concentration of 0.1 mol/ dm3 of hydrochloric acid solution is determined weekly using potentiometric determination of the end point of titration.
    - Sample of HCl: 25.0 (± 0.1) cm3 (V9) of sodium carbonate solution ([Na2CO3] = 0.025 mol/dm3) is pipetted into the titration container and 75 (± 5) cm3 of distilled water is added. The container is placed on a magnetic stirrer, a magnetic stirrer coated with plastic and pH meter electrodes are lowered into the solution. The stirrer is turned on and stirred at a speed at which the whirlpool is barely noticeable. Titrate the sodium carbonate solution with a hydrochloric acid solution of 0.1 mol / dm3 concentration until the measuring device shows a pH of 4.5 ± 0.05. Register the volume of hydrochloric acid solution consumed for titration (V10).
    -Blank: 100 (± 5) cm3 of distilled water as a blank sample is pipetted into the titration container. The container is placed on a magnetic stirrer, a magnetic stirrer coated with plastic and pH meter electrodes are lowered into the solution. The stirrer is turned on and stirred at a speed at which the whirlpool is barely noticeable. Titrate solution with a hydrochloric acid solution of 0.1 mol / dm3 concentration until the measuring device shows a pH of 4.5 ± 0.05. Register the volume of hydrochloric acid solution consumed for titration (V11).
    The exact molar concentration of hydrochloric acid solution [HCl] mol/dm3, is calculated by the formula:
    [HCl]=(2 ×m_Na2CO3 ×V_9)/(53,0 ×(V_10 - V_11) )
    m_Na2CO3: the mass of sodium carbonate taken to prepare the solution , g
    V_9: the volume of the sodium carbonate solution taken for titration is usually 25 cm3;
    V_10: the volume of hydrochloric acid solution consumed for titration of sodium carbonate, cm3
    V_11: the volume of hydrochloric acid solution consumed for titration of the blank sample, cm3
    53.0 : molar mass of sodium carbonate (equivalent), g/mol
    gts2
    Re : Aide pour le calcul de concentration
    Vous êtes sûr ?
    La formule proposée n'est pas homogène (à gauche des mol/L et à droite des mol)
    Geffen
    Gts,
    Je vous remercie. Malheureusement j'ai le document sous les yeux et je vous confirme que l'ecriture le la fomule est celle que j'ai ecrit plus haut.
    Geffen
    La solution etait vraiment bete. Je l'ai trouver. Merci gts2 pour votre aide.
  1. Besoin d'aide pour calcul concentration
    Par vzl26 dans le forum Chimie
    Réponses: 22
    Dernier message: 24/04/2021, 17h57
  2. Calcul de concentration pour 3 solutions
    Par rlejeune dans le forum Chimie
    Dernier message: 17/07/2017, 17h06
  3. Aide pour calcul de concentration et de dilution
    Par E49mimi56 dans le forum Chimie
    Dernier message: 25/10/2016, 16h38
  4. Aide de calcul pour une concentration
    Par Reit dans le forum Chimie
    Dernier message: 25/10/2015, 18h55
  5. Réponses: 3
    Dernier message: 29/09/2014, 19h35
