Je cherche à piloter un afficheur dont le contrôleur est un T6963C
J'ai récupérer les drivers ici
http://www.mikroe.com/eng/products/v...adapter-board/
voila le source
Code:
#include <p18f452.h>
#include <stdlib.h>
#include <stdio.h>
#include "T6963C.h"
 * bitmap pictures stored in ROM
extern  const   char mc[] ;
extern  const   char einstein[] ;
void main(void)
        unsigned char   panel ;         // current panel
        unsigned int    i ;             // general purpose register
        unsigned char   curs ;          // cursor visibility
        unsigned int    cposx, cposy ;  // cursor x-y position
        TRISC = 0 ;                     // port C is output only
        PORTC = 0b00000000 ;            // chip enable, reverse on, 8x8 font
         * init display for 240 pixel width and 128 pixel height
         * 8 bits character width
         * data bus on PORTD
         * control bus on PORTC
         * bit 3 is !WR
         * bit 2 is !RD
         * bit 1 is C!D
         * bit 5 is RST
        //T6963C_Init_240x128();
        T6963C_init(240, 128, 8, &PORTD, &PORTC, 2, 1, 0, 4) ;
         * enable both graphics and text display at the same time
        T6963C_graphics(1) ;
        T6963C_text(1) ;
        panel = 0 ;
        i = 0 ;
        curs = 0 ;
        cposx = cposy = 0 ;
         * text messages
        T6963C_write_text(" GLCD LIBRARY DEMO, WELCOME !", 0, 0, T6963C_ROM_MODE_XOR) ;
        T6963C_write_text(" EINSTEIN WOULD HAVE LIKED mC", 0, 15, T6963C_ROM_MODE_XOR) ;
         * cursor
        T6963C_cursor_height(8) ;       // 8 pixel height
        T6963C_set_cursor(0, 0) ;       // move cursor to top left
        T6963C_cursor(0) ;              // cursor off
         * draw rectangles
        T6963C_rectangle(0, 0, 239, 127, T6963C_WHITE) ;
        T6963C_rectangle(20, 20, 219, 107, T6963C_WHITE) ;
        T6963C_rectangle(40, 40, 199, 87, T6963C_WHITE) ;
        T6963C_rectangle(60, 60, 179, 67, T6963C_WHITE) ;
         * draw a cross
        T6963C_line(0, 0, 239, 127, T6963C_WHITE) ;
        T6963C_line(0, 127, 239, 0, T6963C_WHITE) ;
         * draw solid boxes
        T6963C_box(0, 0, 239, 8, T6963C_WHITE) ;
        T6963C_box(0, 119, 239, 127, T6963C_WHITE) ;
         * draw circles
        T6963C_circle(120, 64, 10, T6963C_WHITE) ;
        T6963C_circle(120, 64, 30, T6963C_WHITE) ;
        T6963C_circle(120, 64, 50, T6963C_WHITE) ;
        T6963C_circle(120, 64, 70, T6963C_WHITE) ;
        T6963C_circle(120, 64, 90, T6963C_WHITE) ;
        T6963C_circle(120, 64, 110, T6963C_WHITE) ;
        T6963C_circle(120, 64, 130, T6963C_WHITE) ;
        T6963C_sprite(76, 4, einstein, 88, 119) ;                       // draw a sprite
        T6963C_setGrPanel(1) ;          // select other graphic panel
        T6963C_image(mc) ;              // fill the graphic screen with a picture
        for(;;)
                 * if RB1 is pressed, toggle the display between graphic panel 0 and graphic 1
                if(PORTB & 0b00000010)
                        panel++ ;
                        panel &= 1 ;
                        T6963C_displayGrPanel(panel) ;
                        Delay_ms(300) ;
                 * if RB2 is pressed, display only graphic panel
                else if(PORTB & 0b00000100)
                        T6963C_text(0) ;
                        Delay_ms(300) ;
                 * if RB3 is pressed, display only text panel
                else if(PORTB & 0b00001000)
                        T6963C_graphics(0) ;
                        T6963C_text(1) ;
                        Delay_ms(300) ;
                 * if RB4 is pressed, display text and graphic panels
                else if(PORTB & 0b00010000)
                        T6963C_text(1) ;
                        Delay_ms(300) ;
                 * if RB5 is pressed, change cursor
                else if(PORTB & 0b00100000)
                        curs++ ;
                        if(curs == 3) curs = 0 ;
                        switch(curs)
                                case 0:
                                        // no cursor
                                        T6963C_cursor(0) ;
                                        break ;
                                case 1:
                                        // blinking cursor
                                        T6963C_cursor(1) ;
                                        T6963C_cursor_blink(1) ;
                                        break ;
                                case 2:
                                        // non blinking cursor
                                        T6963C_cursor(1) ;
                                        T6963C_cursor_blink(0) ;
                                        break ;
                        Delay_ms(300) ;
                 * move cursor, even if not visible
                cposx++ ;
                if(cposx == T6963C_txtCols)
                        cposx = 0 ;
                        cposy++ ;
                        if(cposy == T6963C_grHeight / T6963C_CHARACTER_HEIGHT)
                                cposy = 0 ;
                T6963C_set_cursor(cposx, cposy) ;
                Delay_ms(100) ;
voila les erreurs renvoyés par mon compilateur MCC18
Code:
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:33:Warning [2066] type qualifier mismatch in assignment
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:37:Error [1151] struct or union object designator expected
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:38:Error [1151] struct or union object designator expected
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:48:Warning [2054] suspicious pointer conversion
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:49:Warning [2054] suspicious pointer conversion
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:56:Error [1151] struct or union object designator expected
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:106:Warning [2058] call of function without prototype
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:114:Error [1151] struct or union object designator expected
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:115:Error [1151] struct or union object designator expected
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:116:Warning [2058] call of function without prototype
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:124:Error [1151] struct or union object designator expected
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:125:Error [1151] struct or union object designator expected
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:126:Warning [2058] call of function without prototype
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:134:Error [1151] struct or union object designator expected
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:135:Error [1151] struct or union object designator expected
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:136:Warning [2058] call of function without prototype
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:150:Error [1151] struct or union object designator expected
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:154:Error [1151] struct or union object designator expected
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:155:Error [1151] struct or union object designator expected
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:159:Error [1151] struct or union object designator expected
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:160:Error [1151] struct or union object designator expected
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:163:Warning [2058] call of function without prototype
F:\Documents\Electronique\Datasheets\lcd\programme principal\t6963C\T6963Cdemo.c:181:Warning [2058] call of function without prototype
Je ne sais pas d'ou peut venir l'erreur
Avez vous une idee ?
