[Programmation] Commande moteur pas a pas - VHDL
    invite920b52b1
    salut á tous.
    j'ai un devoir donc je devrai regulariser la distance grace á un moteur Pas-á-Pas.
    pour cela je dispose d'un Laser qui me mesure la distance (0 - 255).
    SVP comment pouvoir gerer le moteur en tenant compte aussi de la reponse que je recois du laser.
    voici ce que j'ai fais
    Code:
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    --use IEEE.STD_LOGIC_ARITH.ALL;
    use IEEE.STD_LOGIC_UNSIGNED.ALL;
    use ieee.numeric_std.all;
    entity step_motor is
    port (SW1:in STD_LOGIC; --Reset-Signal
          CW_CCW: in STD_LOGIC; --sens
          clk5: in STD_LOGIC; --clock
          Enaeble: in STD_LOGIC; --permition
          manner: inout STD_LOGIC_VECTOR (1 downto 0); --Erregungsmodus -Wahlschalter
          Resultat : in  STD_LOGIC_VECTOR (7 downto 0); --8 bit ce que je recois du laser
          Phase: out STD_LOGIC_VECTOR (3 downto 0)); --pour les sorties du moteur
    end step_motor;
    architecture stepmotor_arch of step_motor is
    signal angle: integer range 255 downto 0; --
    signal count: integer range 0 to 7; --
    signal cntInc: integer range -2 to 2; --
    signal cc : integer range 0 to 3;
    signal cntIni: integer range -1 to 0; --
    signal angleDnCount: integer range 255 downto 0;  --angle
    signal angleDnCntDec: integer range 2 downto 1;
    begin
    process(clk5,SW1)
    begin
    If SW1='0' then
    	manner<="00";
    elsif(clk5'event and clk5 ='1')then
    	manner <= manner + 1;
    End If;
    end process;
      process(CW_CCW, manner, angle)--, Enaeble)
      begin
          --if Enaeble='1' then
    		angle <= to_integer(unsigned(Resultat));  --Get the input for PID from the 8_bit_Data in integer form
          cc <= to_integer(unsigned(manner));
    	if Enaeble = '1' then
          if CW_CCW='0' then
              case cc is
                  when 1 => -- 1
                      --count<=0;
                      cntIni<=0;
                      cntInc<=2;
                      angleDnCntDec<=2;--"10";
                  when 2 => -- 2
                      --count<=7;
                      cntIni<=-1;
                      cntInc<=2;
                  when 3 => -- 1
                      --count<=0;
                      cntIni<=0;
                      cntInc<=1;
                      angleDnCntDec<=1;--"01";
                  when 0 => --manner="00" autodetect
                      if (angle rem 2) =1 then -- 2-
                      --count<=7;
                      cntIni<=-1;
                          cntInc<=2;
                      else -- 1-
                      --count<=0;
                      cntIni<=0;
                          cntInc<=2;
                      end if; --angle
              end case; --manner
          else -- if CW_CCW='1'
              case cc is
                   when 1 => -- 1-Phase Anregung
                      --count<=0;
                      cntIni<=0;
                      cntInc<=-2;
                  when 2 => -- 2-Phase Anregung
                      --count<=7;
                      cntIni<=-1;
                      cntInc<=-2;
                  when 3 => -- 1-2Phase Anregung
                      --count<=0;
                      cntIni<=0;
                      cntInc<=-1;
                      if (angle rem 2) = 1 then -- 2-Phase Anregung
                          cntIni<=-1;
                          cntInc<=-2;
                      else -- 1 Phase Anregung
                          cntIni<=0;
                          cntInc<=-2;
                      end if; --angle
              end case; --manner
          end if; -- else CW_CCW=0
        end if; -- Enaeble
      end process;
      counting_reset: process(SW1,Enaeble, angle, clk5)
      begin
          if SW1='0' then
             count<=0;
             angleDnCount<=0;
          elsif clk5'event and clk5='1' then
              if Enaeble='0' then
                  count<=0+ cntIni;
                  angleDnCount<= angle;
              else
                  count <= count+cntInc;
                  if angleDnCount > angleDnCntDec then
                      angleDnCount <= angleDnCount-angleDnCntDec;
                  else
                      angleDnCount <= 0;
                  end if;
              end if;
          end if;
      end process;
     Phase <="0000" when angleDnCount=0 else
             "0001" when 		 count=0 else
             "0011" when  		 count=1 else
             "0010" when 		 count=2 else
             "0110" when        count=3 else
             "0100" when			 count=4 else
             "1100" when			 count=5 else
             "1000" when			 count=6 else
             "1001";			-- when count>=7;
    end stepmotor_arch;
    Dernière modification par Antoane ; 22/03/2016 à 07h22. Motif: Ajout balises [code]
  1. [Programmation] Problème en VHDL avec les multi fichiers vhdl
    Par drbug dans le forum Électronique
    Dernier message: 02/02/2016, 11h32
  2. commande d'ascenseur avec VHDL la carte vhdl
    Par invite2b1f3b55 dans le forum Électronique
    Dernier message: 02/06/2014, 02h41
  3. Poignée de commande sur moteur tri, et moteur ? peut être HS ? [résolu]
    Par invite8f68559e dans le forum Bricolage et décoration
    Dernier message: 14/04/2013, 18h11
  4. Moteur DC : commande en PWM ou commande linéaire?
    Par invite5735c9fd dans le forum Électronique
    Dernier message: 03/03/2009, 11h01
  5. Point flottant en VHDL et vhdl-200x
    Par invite6eee6b27 dans le forum Logiciel - Software - Open Source
    Dernier message: 02/09/2008, 19h47
