  • Login:
+ Répondre à la discussion
Affichage des résultats 16 à 30 sur 49
Utiliser une pompe pour produire de l'électricité
  1. eulenspi
    Date d'inscription
    avril 2006
    Messages
    33
    Voici ce que je trouve sur un site :
    Pumps as turbines have no variable guide vanes, so they are suitable for sites where it is reasonable to use a fixed flow rate. Pico hydro is a term for very small schemes (less than 5 kW power output) where standardised equipment is used in order to produce a low-cost power supply, primarily for rural communities in developing countries, but applicable elsewhere as explained below.
    For medium head pico hydro sites (6 - 35 m) the best choice of turbine is not obvious. The usual alternatives would be either a crossflow turbine or a multi-jet Pelton turbine. Both of these options run at relatively low speed and would require either a 6-pole generator or a belt drive to produce electric power. Another option is to use a standard pump unit instead of a conventional turbine. Pumps are mass-produced, and have the following advantages for pico-hydro compared with purpose-made turbines:• Integral pump and motor can be used as a turbine and generator set
    • Available for a range of heads and flows
    • Available in a number of standard sizes
    • Short delivery time
    • Spare parts such as seals and bearings are easily available
    • Easy installation - uses standard pipe fittings
    Unless batch produced, multi-jet Pelton and crossflow (Banki) turbines tend to be expensive for pico hydro (5 kW or less). Very small crossflow turbines are not normally made due to the difficulty of fabricating the runner, so a crossflow installation would require a larger turbine running at slower speed than an equivalent pump as turbine (PAT). Multi-jet Pelton turbines have the disadvantage of additional complexity due to the branched manifold and extra valves. The main disadvantage of using a pump as turbine is the difficulty of finding the turbine head and flow, which are much greater than the rated pump head and flow, and are needed to select the correct pump for a particular site.
    Using a pump as turbine (PAT) with an induction generator makes it possible to avoid a belt drive, with further advantages:
    • Less losses in drive (saving up to 5% of output power).• Easier installation - PAT and generator come as one unit.
    Lower cost - no pulleys, smaller baseplate.
    Lower cost - in the case of a ‘monoblock’ design, because of simpler construction, fewer bearings, etc.
    • Longer bearing life - no sideways forces on bearings.
    Most pump units, even for powers of less than 1 kW, are supplied with three-phase induction motors. Fortunately, it is possible to use a three-phase induction motor as a single-phase generator and this is the preferred approach to providing a single-phase supply [1].
    • Publicité
  2. SK69202
    Date d'inscription
    septembre 2006
    Localisation
    Sud Armoricain
    Messages
    10 343
    Re : Voici ce que je trouve sur un site :
    Il faut citer la source
  3. eulenspi
    Date d'inscription
    avril 2006
    Messages
    33
    Re : Utiliser une pompe pour produire de l'électricité
    J'ai oublié de citer ma source pour ce qui précède :
    http://homepage.ntlworld.com/regina....about/i5.htm#r
    Je suis désolé d'avoir mis 2 messages en anglais, mais je ne trove pas l'équivalent en français...
    Eulenspiegel
  4. chatelot16
    Date d'inscription
    juin 2007
    Localisation
    angouleme france
    Âge
    54
    Messages
    9 991
    une pompe centrifuge peu servir de turbine en faisant arriver l'eau sous pression par la sortie
    helas la courbure des aubes de la turbine se trouve dans le mauvais sens : ça produit de la puissance mais avec un mauvais rendement
    pour un bon rendement il faut faire un croisement entre 2 pompe centrifuge qui ont la volute dans des sens different
    ou trouver certaine pompe qui on la volute symetrique : moteur sur une face et aspiration sur l'autre face , et dont on peut inverser le moteur et l'aspiration
  5. f6bes
    Date d'inscription
    février 2005
    Localisation
    Nimes Age:69 237 millions de kms autour du soleil !!
    Messages
    35 244
    Citation Envoyé par eulenspi Voir le message
    Merci F6bes pour ces mises en garde.
    Il n'est pas dans mon intention de me relier au réseau, mais d'utiliser l'énergie pour un radiateur à bain d'huile et (ou) un ballon d'eau avant entrée dans LE ballon d'eau chaude.
    C'est donc bien ses désistances que je veux faire fonctionner.
    Bjr à toi,
    Entre s'éclairer en AFRIQUE ( 2 centaines de watts ..MAXI) et..
    ."...d'utiliser l'énergie pour un radiateur à bain d'huile et (ou) un ballon d'eau avant entrée dans LE ballon d'eau chaude."
    quelques KILOWATTS ça fait une SACREE différence.
    Je vais etre gentil je vais prendre un rendement de 33 %.
    Soit à produire SEULEMENt ..1 kW te faut que ta pompe en fournisse...3 kw.
    Et avec1 kW on est loin du compte pour ton radiateur et ton ballon d'eau chaude.
    Donc....conclusion !!
    Bonnes fétes
    "Bonjour" et "Merci" (pour ceux qui oublient!!)
  6. eulenspi
    Date d'inscription
    avril 2006
    Messages
    33
    F6bes, ne confondez-vous pas puissance et travail ?
    Partons sur 33% de rendement (les expériences menées - voir plus haut - sont toutes à + de 50 %).
    Si mon ruisseau produit 1000 W et qu'il m'en reste 330 W, cela me produit près de 8KWH, ce qui suffit pour un ballon de 200 l pour une famille de 4 personnes !
  7. f6bes
    Date d'inscription
    février 2005
    Localisation
    Messages
    35 244
    Bjr à toi,
    Il est vrai que ton ruisseau est "fonctionnel" 24/24 donc tu récupéreras toujours de l'énergie en continu.
    Reste néammoins un détail " administratif " vis à vis du cours d'eau en question: avoir l'aval (autorisation ) pour pose de
    ton sytéme et SECURITE ( électricité ) vis à vis du quidam.
    Bien sur si en privatif, j'ai rien dit.
    De meme va pas falloir exciter les convoitises ( plus de matos ).
    Dernière modification par f6bes ; 31/12/2012 à 14h07.
  8. f6bes
    Date d'inscription
    février 2005
    Localisation
    Messages
    35 244
    Remoi,
    Maintenant si tu veux réliser ta turbine, voir là:
    http://www.google.fr/url?sa=t&rct=j&...55534169,d.d2k
  9. eulenspi
    Date d'inscription
    avril 2006
    Messages
    33
    Merci F6bes du lien pour ce site que je connais depuis le débute de la réalisation de la turbine.
    Mais je rappelle que je recherche une pompe pouvant faire office de turbine.
    Quant aux détails administratifs et de sécurité, ils sont réglés.
    Je veux donc juste trouver un modéle de pompe centrifuge bon marché, y compris d'occasion, donnant un rendement acceptable.
    Bonne fin d'année.
    Eulenspiegel
  10. plantefol-C-car
    Date d'inscription
    novembre 2012
    Messages
    75
    Bjr eulenspi, je ne comprends pas ton obstination après tous les conseils pour certains très éclairés ( sans euphemisme ).
    C'est un peu comme vouloir faire tourner un moteur auto en soufflant de l'air par le carburateur ou l'échappement avec tout le vent dont on dispose.
    Pour des pompes à turbines tu n'as qu'à te baisser pour en cueillir ; pompe de lave vaisselle , soufflante de forge, vieux turbo moteur ! (double puique Admiss /échapp), etc... Cdt
  11. chatelot16
    Date d'inscription
    juin 2007
    Localisation
    angouleme france
    Âge
    54
    Messages
    9 991
    suivant la puissance que tu veux ça serait du genre pompe de lave vaisselle ou pompe de filtre de piscine
    le probleme des pompes les plus courante , c'est que les diametre de tuyaux sont trop petite
    quand une pompe gaspille la moitié de la puissance a bourrer dans un tuyaux trop petit , personne ne se plaint : ça fait un rendement de 50% et on s'en contente ... mais monté en turbine ce diametre de passage trop petit fait perdre toute la puissance utile de l'eau
    il faut donc chercher des vieilles pompe en fonte qui avaient des volute plus grosse ... et il faut aussi en trouver une qui puisse se monter a l'envers
    autre solution : faire la volute sois même en polyester ou en beton , pour y monter un moteur et une turbine de pompe centrifuge courante genre pompe de piscine
    Dernière modification par chatelot16 ; 31/12/2012 à 15h13.
  12. chatelot16
    Date d'inscription
    juin 2007
    Localisation
    angouleme france
    Âge
    54
    Messages
    9 991
    les conseil eclairé du genre c'est pas fait pour donc ça ne marche pas ne font pas beaucoup avancer ...
    le turbo compresseur est le bon exemple de pompe centrifuge dont l'une marche en compresseur et l'autre en turbine
    les different turbocompresseur montrent aussi une autre difference ... les vieux turbo compresseur on la turbine sur l'echappement simple comme une pompe centrifuge ... les turbo plus moderne on des ailette fixe orientable permettant de modifier la puissance de la turbine , pour mieux s'adapter aux different regime du moteur
    pour les turbine a eau c'est pareil : une simple pompe centrifuge fait la puissance qu'elle veut ... avec des aube directrice ça devient une turbine francis , qui permet d'economiser l'eau quand on veut reduire la puissance
  13. f6bes
    Date d'inscription
    février 2005
    Localisation
    Messages
    35 244
    Citation Envoyé par plantefol-C-car Voir le message
    t
    Bjr à toi,
    Ben "l'obtination" est facile à comprendre en consultant les...tarifs.
    Ca demande ...réflexion..avant de se jeter à l'eau !
    http://www.google.fr/url?sa=t&rct=j&...55534169,d.ZG4
    Y a probablement un peu moins couteux , mais ça doit rester dans la fourchette de prix !!
  14. chatelot16
    Date d'inscription
    juin 2007
    Localisation
    angouleme france
    Âge
    54
    Messages
    9 991
    je crois que je vais me mettre a vendre des turbine !
    une pompe a eau de se genre
    http://www.google.fr/products/catalo...ed=0CFkQ8wIwAQ
    a un carter inadapté a une turbine , avec un venturi pour augmenter la pression et etre autoamorcante ... mais il suffirait de faire un autre carter avec la volute dans le bon sens pour faire quelque chose
  15. eulenspi
    Date d'inscription
    avril 2006
    Messages
    33
    Merci Chatelot de me comprendre...
    Je voudrais bien sortir 300 à 500 W ; il me faudrait donc une pompe d'1cv, voire 1.25 cv.
    Les entrées et sorties sont en 50 mm de diamètre, ce qui devrait éviter des pertes decharge trop importantes.
    Je vois des pompes bon marché de ce type : http://www.distripool.fr/produit-184...y-1-25-CV.html
    Est-il préférable pour produire de l'électricité que la pompe soit triphasée ou monophasée ?
    J'ai lu des choses à ce sujet mais sans bien comprendre.
    En cas de pompe triphasée, comment récupérer l'électricité sur par exemple un radiateur à bain d'huile ?
    L'électricité produite sera uniquement utilisée pour une ou plusieurs résistances.
    Quen pensez-vous ?
    • Publicité
Poursuivez votre recherche :
Sur le même thème :
  1. Plaque Peltier pour produire de l'électricité...
    Par Yex2 dans le forum Électronique
    Réponses: 22
    Dernier message: 24/11/2012, 14h42
  2. Utiliser une écluse pour produire de l’électricité ?
    Par neo765 dans le forum Environnement, développement durable et écologie
    Réponses: 20
    Dernier message: 02/11/2011, 20h56
  3. Réponses: 14
    Dernier message: 15/09/2010, 13h12
  4. Une nouvelle façon de produire de l'électricité ! ! !
    Par Jacques dans le forum Actualités
    Dernier message: 22/10/2003, 12h52
  5. produire de l'électricité avec une explosion
    Par Tesla dans le forum Physique
    Dernier message: 16/03/2003, 10h45
