P²EACH : un site sur les expériences en astroparticules
    mtheory
    Pour ceux que ça intéresse, il existe maintenant un site où sont répertoriées les grandes expériences (passées ou en cours) en physiques des particules en rapport avec l'astrophysique et la cosmologie. Il s'agit donc d'une façon ou d'une autre de la discipline des astroparticules (matière noire, rayonnement fossile etc...)
    Son nom : P²EACH
    P2EACH is a website developed by Anthony Hillairet (postdoc, UVic) and Sean Bailly that presents most experiments in particle physics, astroparticles, astrophysics and cosmology, such as neutrino or dark matter research, accelerators and cosmic rays experiments, gravitational waves and cosmic microwave background studies.
    An impressive number of experiments have been build to study and test various aspects of our understanding of particle physics and cosmology. It can be quite challenging for someone to get a rapid overview of what has been done in the past, what kind of experiments are operating now and what are the future projects. P2EACH provides a fast insight of experimental efforts by listing the experiments by field of research in an user-friendly environment.
    “I'm smart enough to know that I'm dumb.” Richard Feynman
    Gilgamesh
    Re : P²EACH : un site sur les expériences en astroparticules
    C'est top.
    Ça donne notamment les caractéristiques principales des instruments utilisés pour les expériences.
    Par exemple pour PLANCK:
    PLANCK
    Named after the German Nobel laureate Max Planck (1858-1947)
    categories: [CMB]
    homepage: PLANCK
    location: Lissajous orbit at an average distance of 400 000 km from L2
    status: operating (2009-now)
    scientific objectives:
    Measure CMB anisotropies at all angular scales larger than 5 to 10 arcminutes over the entire sky with a precision of ~2 parts per million
    description:
    Mass: 1.95 tonnes at launch
    Telescope mirror: 1.9 × 1.5 m primary reflector, made of carbon-fiber-reinforced plastic and is coated with a thin reflective layer (reflectivity >99.5%) of aluminium, bumps in the coating are less than 5 microns in size
    The telescope is surrounded by a large baffle that minimises stray light. It also helps radiate excess heat into space
    Low Frequency Instrument (LFI) is designed to produce multi-frequency measurements of the microwave sky in the frequency range of 27 to 77 GHz. The instrument consists of an array of 22 tuned radio receivers located in the focal plane of the telescope
    HFI is designed to produce multi-frequency measurements of the diffuse radiation permeating the sky in all directions in the frequency range of 84 GHz to 1 THz. The instrument consists of an array of 52 bolometric detectors placed in the focal plane of the telescope
    A passive cooling system brings the temperature of the telescope down to around 50 K. The temperature of the detectors is further decreased to levels as low as 0.1 K by a three-stage active refrigeration chain
    a+
    Parcours Etranges
    invite4d7a968b
    En tant qu'auteur du site, je tiens avant tout à remercier mtheory et Gilgamesh.
    J'en profite pour expliquer un peu l'objectif de ce site.
    Les physiciens ont élaboré de nombreuses expériences au cours du XXeme siècle pour étudier la physique des particules, l'astrophysique, les astroparticules et la cosmologie. Bien que travaillant en physique des particules et cosmologie, je ne connaissais qu'une petite portion de ces expériences (nous en avons répertorié environ 400) et je trouvais difficile d'avoir une vue d'ensemble sur ce qui se fait par exemple en détection de matière noire ou dans le domaine des neutrinos.
    L'idée de P²EACH est de donner rapidement les informations principales concernant ces expériences et pour ceux qui veulent en savoir plus, un lien vers le site officiel de l'expérience (quand il existe) et des liens vers des articles scientifiques (assez techniques) décrivant les résultats principaux.
    Nous pensons que ce site peut être utile pour des chercheurs, des doctorants mais aussi des étudiants qui s'intéressent à ces domaines ou en recherche de stage/thèse et également à tout passionné de physique.
    P²EACH est encore tout jeune et a probablement encore quelques défauts. N'hésitez pas à me transmettre toute remarque, correction, oubli d'expérience en message privé ou en utilisant les adresses mails données sur le site.
    S.
    Gilgamesh
    Je n'y manquerais pas. Très bonne initiative et belle réalisation en tout cas.
    a+
    Parcours Etranges
  1. Réponses: 4
    Dernier message: 21/12/2010, 20h12
  2. Expériences sur les colorants
    Par inviteffa8db36 dans le forum Chimie
    Dernier message: 01/05/2008, 14h06
  3. Expériences sur les levures
    Par invite57990ea7 dans le forum TPE / TIPE et autres travaux
    Dernier message: 08/12/2005, 10h18
