[Immunologie] les mécanismes de l'immunité naturelle
    invite50866496
    salut,
    j'aimerai bien savoir pourquoi le complexe d'attaque membranaire attaque les bactéries gram négative?
    merci à l'avance.
    noir_ecaille
    Re : les mécanismes de l'immunité naturelle
    La raison tient à la structure pariétale des Gram-
    Attention cependant :
    https://en.wikipedia.org/wiki/Gram-p...classification
    Citation Envoyé par Wikipédia
    Although the bacteria are traditionally divided into two main groups, Gram-positive and Gram-negative, based upon their Gram-stain retention property, this classification system is ambiguous as it refers to three distinct aspects (staining result, cell-envelope organization, taxonomic group), which do not necessarily coalesce for some bacterial species. The Gram-positive and Gram-negative staining response is also not a reliable characteristic as these two kinds of bacteria do not form phylogenetic coherent groups. However, although Gram-staining response of bacteria is an empirical criterion, its basis lies in the marked differences in the ultrastructure and chemical composition of the two main kinds of prokaryotic cells that are found in nature. These kinds of cells are distinguished from each other based upon the presence or absence of an outer lipid membrane, which is a more reliable and fundamental characteristic of the bacterial cells.
    All Gram-positive bacteria are bounded by a single unit lipid membrane, and they generally contain a thick layer (20-80 nm) of peptidoglycan responsible for retaining the Gram-stain. A number of other bacteria which are bounded by a single membrane, but which stain Gram-negative due to either lack of the peptidoglycan layer (viz., mycoplasmas) or their inability to retain the Gram-stain due to their cell wall composition, also show close relationship to the gram-positive bacteria. For the bacterial (prokaryotic) cells that are bounded by a single cell membrane the term "monoderm bacteria" or "monoderm prokaryotes" has been proposed.
    In contrast to Gram-positive bacteria, all archetypical Gram-negative bacteria are bounded by a cytoplasmic membrane and an outer cell membrane; they contain only a thin layer of peptidoglycan (2-3 nm) between these membranes. The presence of inner and outer cell membranes defines a new compartment in these cells: the periplasmic space or the periplasmic compartment. These bacteria/prokaryotes have been designated as "diderm bacteria". The distinction between the monoderm and diderm prokaryotes is supported by conserved signature indels in a number of important proteins (viz. DnaK, GroEL). Of these two structurally distinct groups of prokaryotic organisms, monoderm prokaryotes are indicated to be ancestral. Based upon a number of observations including that the Gram-positive bacteria are the major producers of antibiotics and that Gram-negative bacteria are generally resistant to them, it has been proposed that the outer cell membrane in Gram negative bacteria (diderms) has as a protective mechanism against antibiotic selection pressure. Some bacteria, such as Deinococcus, which stain Gram-positive due to the presence of a thick peptidoglycan layer and also possess an outer cell membrane are suggested as intermediates in the transition between monoderm (Gram positive) and diderm (Gram-negative) bacteria. The diderm bacteria can also be further differentiated between simple diderms lacking lipopolysaccharide, the archetypical diderm bacteria where the outer cell membrane contains lipopolysaccharide and the diderm bacteria where outer cell membrane is made up of mycolic acid
    Voir aussi :
    https://en.wikipedia.org/wiki/File:Gram-Cell-wall.svg
    De manière générale, une IgG va reconnaître un antigène à la surface de la bactérie et déclencher la cascade du complément.
    invite50866496
    merci beaucoup noir ecaille pour votre informations.
  1. [Immunologie] Questions sur l'immunité et les anticorps.
    Par Rabah-Issa dans le forum Biologie
    Dernier message: 06/03/2012, 16h26
  2. Lacan et les mécanismes de défense
    Par inviteddcbe35f dans le forum Psychologies (archives)
    Dernier message: 19/11/2010, 12h59
  3. Chimie organique : les mécanismes
    Par invite751056e1 dans le forum Chimie
    Dernier message: 26/12/2007, 12h41
  4. les mécanismes moléculaires
    Par invitecceb1161 dans le forum Biologie
    Dernier message: 23/10/2004, 22h17
