[Evolution] explication sur la selection naturelle ?
    invite0c6ab2b7
    bonjour tous le monde
    c'est quoi la selection naturelle négative et positive (je l'est trouvé dans ce texte mais je n'ai pas bien compris
    The Major Types of Natural Selection
    Natural selection can act in a wide range of different manners. The simplest and most relevant
    for this course are listed below:
    • Positive selection occurs when a beneficial mutation occurs in a population and
    increases in frequency. Of course, if this mutationis increasing in frequency, then other
    variation must be concurrently decreasing in frequency. The classic example of positive
    selection is the spread of an antibiotic resistanceallele through a population of bacteria
    that are being exposed to that antibiotic.
    • Negative (purifying)[/B] selection is the opposite of positive selection. It occurs when a
    detrimental mutation is selected out of a population. Since most proteins have
    undergone millions or billions of years of evolution, most mutations that cause a change
    to a protein coding sequence are believed to be detrimental. These detrimental mutations
    will be purged from the population by negative selection. For any protein, the fraction of
    mutations that are detrimental is directly related to the ‘evolutionary conservation’ of
    that protein.
    • Balancing or diversifying selection is selection that favours the maintenance of genetic
    variation at a locus. While both positive and negative selection purge variation (either
    selecting for or against variants), balancing selection actually maintains variation by
    selecting for multiple genetic variants. The easiest way to imagine this happening is to
    consider the case of multiple environments that select for different allelic forms of a
    protein. For example, a receptor protein that is strongly beneficial when a pathogen is
    present in a population, but does nothing but put aload on the system when there is no
    pathogen.
    invite6ecbbd61
    Re : explication sur la selection naturelle ?
    (STP, n'écris plus en vert, ça fait pas du bien pour les yeux!! )
    Alors, on distingue généralement 2 types de sélections: La sélection directionnelle et et la sélection non-linéaire (je fais l'impasse de la sélection fréquence-dépendance qui est à part).
    La sélection directionnelle: Les individus ayant une forte ou une faible valeur de trait seront sélectionnés. Par exemple, chez les oiseaux, la taille de nichée est soumise à une sélection positive (car les grandes tailles de nichée maximisent la fitness). A l'inverse, la date de ponte est soumise à une sélection directionnelle négative, car ce sont les dates de pontes précoces qui maximisent la fitness (ici une faible valeur du trait maximise la fitness).
    Ces deux cas de sélection représentent ce qui dans ton texte est mentionné comme de la sélection positive.
    D'après ton texte, ce qu'ils appellent la sélection négative, c'est simplement de la contre sélection. C'est à dire une mutation arrive, et apporte un désavantage à l'organisme (par rapport aux autres, c'est ça aussi le plus important). Ben là l'organisme sera contre-sélectionné (sélection négative), et donc il disparaît de la population.
    La sélection non linéaire. On en distingue 2 différentes (dont une mentionnées dans ton texte):
    - La sélection stabilisante, qui sélectionne les valeurs de phénotype intermédiaire (les extrèmes sont contre-sélectionné). Par exemple la taille chez la plupart des animaux (il ne faut pas être trop grand, ni trop petit).
    - La sélection diversifiante, comme mentionné dans ton texte. Cette sélection sélectionne les phénotype extrème (l'inverse de la précédente). Donc les plus petits seront sélectionnés, ainsi que les plus gros. Cette sélection amène à une augmentation de la variance phénotypique (contrairement aux sélection précédente). Et dans certains cas peut amener à de la spéciation (car un "fossé adaptatif" se creuse entre les deux sous-populations sui se forment).
    Bref, pour le moment je pense que ça ira.
    Si tu as d'autres questions n'hésites pas (je ne suis pas rentré dans les détails).
    Cendres
    Citation Envoyé par shmikkki Voir le message
    Et le vert est en principe réservé aux actes de modération.
    N'a de convictions que celui qui n'a rien approfondi (Cioran)
    invite179e6258
    On parle de sélection balancée (il faudrait dire équilibrée) quand la sélection tend à augmenter la diversité allélique. Une situation typique est celle où les hétérozygotes sont favorisés.
  1. [Evolution] l'explication par la sélection naturelle des oiseaux qui ne volent pas.
    Par invite6bef72f3 dans le forum Biologie
    Dernier message: 28/02/2013, 23h33
  2. selection naturelle versus selection sexuelle.
    Par invite51d17075 dans le forum Psychologies (archives)
    Réponses: 21
    Dernier message: 21/12/2012, 12h31
  3. TPE : Sélection naturelle
    Par invite525749ae dans le forum TPE / TIPE et autres travaux
    Dernier message: 04/12/2007, 17h56
