problème stk600 et avrdude
    invitec43221e1
    salut,
    je suis sur ubuntu 10.10 64 bit
    j'ai essayé de programmer mon µC avec avrdude et le kit stk600
    sudo avrdude -c stk600 -P /dev/bus/usb/007/012 -p m2560 -U flash:w:atmega2560.hex
    mon problème c'est que j'ai une erreur: inappropriate ioctl for device
    Code:
        lsusb
        Bus 007 Device 012: ID 03eb:2106 Atmel Corp. STK600 development board
        Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
        Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
        Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
        Bus 004 Device 003: ID 046d:c315 Logitech, Inc. Classic New Touch Keyboard
        Bus 004 Device 002: ID 046d:c01e Logitech, Inc. MX518 Optical Mouse
        Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
        Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
        Bus 002 Device 002: ID 046d:09a4 Logitech, Inc. QuickCam E 3500
        Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
        Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
        ~$ dmesg | tail
        [36131.093572] usb 7-3: USB disconnect, address 7
        [36433.740097] usb 7-3: new full speed USB device using ohci_hcd and address 8
        [36618.855264] usb 7-3: USB disconnect, address 8
        [36635.090096] usb 7-3: new full speed USB device using ohci_hcd and address 9
        [36723.551409] usb 7-3: USB disconnect, address 9
        [36757.180909] usb 7-3: new full speed USB device using ohci_hcd and address 10
        [37397.115038] usb 7-3: USB disconnect, address 10
        [37410.740908] usb 7-3: new full speed USB device using ohci_hcd and address 11
        [37603.642147] usb 7-3: USB disconnect, address 11
        [37618.190088] usb 7-3: new full speed USB device using ohci_hcd and address 12
    avez-vous quelques pistes? merci
    invite29971eb1
    Re : problème stk600 et avrdude
    Vu le message d'erreur, c'est un problème de librairies (ou de drivers) qui n'est pas le bon.
    Que dit la doc de ton SDK ou le site Atmel sur l'installation du STK600 sous Linux?
    invite29971eb1
    Bon, recherche Google, premier résultat, on trouve déjà des infos....c'est par là qu'il faut commencer, et pas par les forums:
    http://www.avrfreaks.net/index.php?n...wtopic&t=72987
    Bref, c'est mal barré, ton STK600 est supporté par Windows, pas par Linux. Le reste, c'est de la bidouille qui va te poser bien des problèmes pour pas grand chose
  1. Réponses: 11
    Dernier message: 26/05/2011, 13h27
  2. Problème Equa diff sur problème physique
    Par invite8f59deab dans le forum Mathématiques du supérieur
    Dernier message: 03/12/2010, 21h45
  3. Un petit problème qui me pause problème lol
    Par invitef2853e5d dans le forum Mathématiques du supérieur
    Dernier message: 31/03/2009, 16h28
  4. problème avec un lecteur mp4(le problème vient de l'ordinateur)
    Par inviteaca1b987 dans le forum Matériel - Hardware
    Dernier message: 29/10/2007, 17h53
