probleme de declaration des timers et des interruption
    invite27bceb15
    slt tout le monde,
    je vous présente mon projet qui permet la
    détermination de la fréquence d'un signal d'entrée analogique par un pic 16f877,
    le résultat s' affiche sur un écran lcd 2x16,
    Code:
    const char TIMER_START_VALUE = 8;
    const char TIMER_RELOAD_VALUE = 125;
    char sec, updateDisplay, reload;
    long bat;
    char bat_str [] = "     ";
    // LCD module connections
    sbit LCD_RW at RB2_bit;
    sbit LCD_RS at RB1_bit;
    sbit LCD_EN at RD3_bit;
    sbit LCD_D4 at RD4_bit;
    sbit LCD_D5 at RD5_bit;
    sbit LCD_D6 at RD6_bit;
    sbit LCD_D7 at RD7_bit;
     sbit LCD_RW_Direction at TRISB2_bit;
    sbit LCD_RS_Direction at TRISB1_bit;
    sbit LCD_EN_Direction at TRISB3_bit;
    sbit LCD_D4_Direction at TRISD4_bit;
    sbit LCD_D5_Direction at TRISD5_bit;
    sbit LCD_D6_Direction at TRISD6_bit;
    sbit LCD_D7_Direction at TRISD7_bit;
    // End LCD module connections
    void main() {
      TrisA = 0xFF;
      TrisC = 0;
      PortC = 0;
      TrisD = 0;
      PortD = 0;
      ADCON0 = 0;
      ADCON1 = 0x0F;
      Lcd_Init();                        // Initialize LCD
      Lcd_Cmd(_LCD_CLEAR);               // Clear display
      Lcd_Cmd(_LCD_CURSOR_OFF);// Cursor off
      Lcd_Out(1,1,"Wireless ECG");
      delay_ms(4000);
      LCD_Out(1,1,"Heartbeats :");                 // Write text in first row
      updateDisplay = 0; sec = 0; reload = 0; bat = 0;
      INTCON = 0xC0;       // Set GIE, PEIE
      INT0IE_bit = 1;
      TMR0ON_bit = 0;      // turn off the timer during setup
      TMR0IE_bit = 1;      // Enable TMRO interrupt
      T08BIT_bit = 1;      // Enable 8 bit control (as opposed to 16-bit)
      T0CS_bit = 0;        // use internal clock to trigger timer to count
      PSA_bit = 0;         // Use the prescaler to slow the timer down
      T0PS0_bit = 1;
      T0PS1_bit = 0;
      T0PS2_bit = 1;
      TMR0L = TIMER_START_VALUE;
      reload = TIMER_RELOAD_VALUE;
      TMR0ON_bit = 1;      // start the timer
      while (1) {
              if (UpdateDisplay == 1) {
                 UpdateDisplay = 0;
                 WordToStr (bat, bat_str); bat = 0;
                 LCD_Out(2,1,bat_str);
    void Interrupt (void) {
     if (INTCON.TMR0IF) {
            T0IF_bit = 0;
            if(reload == 0) {
                reload = TIMER_RELOAD_VALUE + 1;
                sec = sec + 1;
                if (sec == 15)  {
                 updateDisplay = 1; sec = 0;
            reload = reload - 1;
     if (INTCON.INT0IF) {
       bat = bat + 1; INT0IF_bit = 0;
    lors de la compilation avec le mikro C il me demande la délaration des timers et des interruptions,
    comment corriger ce probleme?
    umfred
    Re : probleme de declaration des timers et des interruption
    Je crois que le problème vient du fait que le compilateur est "case sensitive" pour les noms de registres et autres mots clés, c'est-à-dire qu'il fait la différence entre minuscule et majuscule et que, par exemple, TRISA n'est pas la même chose que TrisA
  1. Où trouver des 555 timers ?!?
    Par invite2160f20c dans le forum Électronique
    Dernier message: 07/03/2012, 11h46
  2. Qualité des images pour déclaration
    Par kinette dans le forum Archéologie
    Dernier message: 27/03/2011, 17h02
  3. Bourse et déclaration des revenus
    Par invite748f3bf4 dans le forum Orientation après le BAC
    Dernier message: 04/04/2009, 13h35
  4. besoin d'aide sur la programmation des TIMERs du PIC svp !!!
    Par invite17e62166 dans le forum Électronique
    Dernier message: 02/04/2006, 23h24
