[Programmation] Question mystérieuse sans explication
    invite9fc1cd57
    Code:
    package projet.isetn.com.robotandoird;
    import android.graphics.Color;
    import android.support.v7.app.AppCompatActivity;
    import android.os.Bundle;
    import android.view.View;
    import android.widget.Button;
    import android.widget.ImageButton;
    import android.widget.Toast;
    public class MainActivity extends AppCompatActivity {
        ImageButton haut;
        ImageButton bas;
        ImageButton droite;
        ImageButton gauche;
        Button temperature;
        Button gaz;
        Button lum;
        ImageButton micro;
        ImageButton camera;
        @Override
        protected void onCreate(Bundle savedInstanceState) {
            super.onCreate(savedInstanceState);
            setContentView(R.layout.activity_main);
            haut =(ImageButton)findViewById(R.id.haut);
            haut.setOnClickListener(new View.OnClickListener() {
                @Override
                public void onClick(View v) {
                    Toast.makeText(getApplicationContext(), "Faire avancer le Robot", Toast.LENGTH_LONG).show();
            bas =(ImageButton)findViewById(R.id.bas);
            bas.setOnClickListener(new View.OnClickListener() {
                @Override
                    Toast.makeText(getApplicationContext(), "Faire reculer le Robot", Toast.LENGTH_LONG).show();
            droite =(ImageButton)findViewById(R.id.droite);
            droite.setOnClickListener(new View.OnClickListener() {
                @Override
                    Toast.makeText(getApplicationContext(), "Faire tourner le Robot a droite", Toast.LENGTH_LONG).show();
            gauche =(ImageButton)findViewById(R.id.gauche);
            gauche.setOnClickListener(new View.OnClickListener() {
                @Override
                    Toast.makeText(getApplicationContext(), "Faire Tourner Le Robot a gauche", Toast.LENGTH_LONG).show();
            temperature =(Button)findViewById(R.id.temperature);
            temperature.setOnClickListener(new View.OnClickListener() {
                @Override
                    Toast.makeText(getApplicationContext(), "La Temperature est: ", Toast.LENGTH_LONG).show();
            gaz =(Button)findViewById(R.id.gaz);
            gaz.setOnClickListener(new View.OnClickListener() {
                @Override
                    Toast.makeText(getApplicationContext(), "Le Niveau De GAZ est: ", Toast.LENGTH_LONG).show();
            lum =(Button)findViewById(R.id.lum);
            lum.setOnClickListener(new View.OnClickListener() {
                @Override
                    Toast.makeText(getApplicationContext(), "Allumer La lumière", Toast.LENGTH_LONG).show();
            micro =(ImageButton)findViewById(R.id.micro);
            micro.setOnClickListener(new View.OnClickListener() {
                @Override
                    Toast.makeText(getApplicationContext(), "Activer Le Microphone", Toast.LENGTH_LONG).show();
            camera =(ImageButton)findViewById(R.id.camera);
            camera.setOnClickListener(new View.OnClickListener() {
                @Override
                    Toast.makeText(getApplicationContext(), "Activer La Camera", Toast.LENGTH_LONG).show();
        /*public void buttonOnClick(View v) {
            ImageButton button=(Button) v;
            ((Button) v).setText("/");
    Dernière modification par gienas ; 13/12/2015 à 18h14. Motif: Ajouté les balises code, obligatoires pour les programmes
    invite9fc1cd57
    Re : je veux que cette application connecte avec blutooth d'arduino merci d'avance :)
    Code:
    <?xml version="1.0" encoding="utf-8"?>
    <RelativeLayout
        xmlns:android="http://schemas.android.com/apk/res/android"
        xmlns:tools="http://schemas.android.com/tools"
        android:layout_width="match_parent"
        android:layout_height="match_parent"
        android:paddingLeft="16dp"
        android:paddingRight="16dp"
        android:paddingTop="16dp"
        android:paddingBottom="16dp"
        tools:context="projet.isetn.com.robotandoird.MainActivity">
        <ImageButton
            android:layout_width="50dp"
            android:layout_height="50dp"
            android:id="@+id/gauche"
            android:layout_centerVertical="true"
            android:layout_alignParentLeft="true"
            android:layout_alignParentStart="true"
            android:src="@drawable/gauche" />
        <ImageButton
            android:id="@+id/droite"
            android:layout_toEndOf="@+id/haut"
            android:src="@drawable/droite"
            android:layout_alignBottom="@+id/gauche"
            android:layout_toRightOf="@+id/haut" />
        <ImageButton
            android:id="@+id/bas"
            android:src="@drawable/down"
            android:layout_below="@+id/gauche"
            android:layout_toRightOf="@+id/gauche"
            android:layout_toEndOf="@+id/gauche" />
        <ImageButton
            android:id="@+id/haut"
            android:src="@drawable/up"
            android:layout_above="@+id/gauche"
        <Button
            android:layout_width="wrap_content"
            android:layout_height="wrap_content"
            android:text="T°"
            android:id="@+id/temperature"
            android:layout_alignTop="@+id/gaz"
            android:layout_toLeftOf="@+id/gaz"
            android:layout_toStartOf="@+id/gaz" />
        <Button
            android:text="Gaz"
            android:id="@+id/gaz"
            android:layout_alignTop="@+id/lum"
            android:layout_toLeftOf="@+id/lum"
            android:layout_toStartOf="@+id/lum" />
        <Button
            android:text="Lum"
            android:id="@+id/lum"
            android:layout_below="@+id/bas"
            android:layout_toLeftOf="@+id/micro"
            android:layout_toStartOf="@+id/micro" />
        <ImageButton
            android:id="@+id/micro"
            android:src="@android:drawable/presence_audio_online"
            android:layout_below="@+id/videoView"
            android:layout_toLeftOf="@+id/camera"
            android:layout_toStartOf="@+id/camera"
            android:layout_alignBottom="@+id/lum"
            android:onClick="buttonOnClick" />
        <ImageButton
            android:id="@+id/camera"
            android:src="@android:drawable/presence_video_online"
            android:layout_alignTop="@+id/micro"
            android:layout_alignParentRight="true"
            android:layout_alignParentEnd="true"
            android:layout_alignBottom="@+id/micro"
        <VideoView
            android:id="@+id/videoView"
            android:layout_above="@+id/lum"
            android:layout_toEndOf="@+id/droite"
            android:layout_alignTop="@+id/haut"
            android:layout_alignLeft="@+id/temperature"
            android:layout_alignStart="@+id/temperature" />
        <TextView
            android:textAppearance="?android:attr/textAppearanceMedium"
            android:text="Batterie 1"
            android:id="@+id/textView"
            android:layout_alignParentTop="true"
            android:layout_alignParentEnd="true" />
        <TextView
            android:text="Batterie 2"
            android:id="@+id/textView2"
            android:layout_alignTop="@+id/textView"
            android:layout_toRightOf="@+id/gaz"
            android:layout_toEndOf="@+id/gaz" />
        <ProgressBar
            style="?android:attr/progressBarStyleHorizontal"
            android:id="@+id/progressBar"
            android:layout_above="@+id/haut"
            android:layout_toLeftOf="@+id/videoView"
            android:layout_toStartOf="@+id/videoView" />
        <ImageView
            android:id="@+id/imageView"
            android:src="@drawable/batterie"
            android:layout_above="@+id/videoView"
            android:layout_alignLeft="@+id/textView2"
            android:layout_alignStart="@+id/textView2" />
        <ImageView
            android:id="@+id/imageView2"
            android:layout_alignLeft="@+id/textView"
            android:layout_alignStart="@+id/textView" />
    </RelativeLayout>
    Dernière modification par gienas ; 13/12/2015 à 18h16. Motif: Ajouté les balises code, obligatoires pôur les programmes
    Bonjour à toi aussi selimo888, et à tout le groupe
    Déterrer une vieille discussion pour la squatter en "posant" une question dans le titre par les mots je veux n'est pas convenable. Il faut:
    1- ouvrir une discussion avec un titre explicite.
    2- dire bonjour en arrivant et merci en partant. C'est inscrit dans la charte que tu as acceptée pour pouvoir t'inscrire.
    3- poser une question clairement, en définissant le contexte.
    4- choisir le bon forum où poser la question. Celle que l'on croit deviner, n'est pas de nature algorithmique, aussi, elle va être déplacée vers le forum généraliste.
  1. Ecg:formule sans explication
    Par invitebef019eb dans le forum Santé et médecine générale
    Dernier message: 04/11/2015, 22h09
  2. Maison humide sans explication!
    Par invitec2690768 dans le forum Habitat bioclimatique, isolation et chauffage
    Réponses: 32
    Dernier message: 29/05/2009, 11h03
  3. experience sans explication
    Par invitea4589a60 dans le forum Chimie
    Dernier message: 20/06/2005, 15h53
  4. Une question bête mais tellement mystérieuse :)
    Par invited757719e dans le forum Logiciel - Software - Open Source
    Dernier message: 02/10/2003, 08h05
